2007 5.7 Lights on after fluid changes
Discussion in 'New Member Introductions' started by Sandersox, Sep 3, 2025.
  1. Sep 3, 2025 at 6:11 PM
    Sandersox
    Sandersox [OP] New Member
    Oz
    2007 Tundra 5.7 V8 TRD Off Road
    None
    Hi,
    First of all, I would like to thank everyone for posting valuable information on here. My name is Oz, and I am new to Tundras.
    I am going to post my problem right away and am looking for some input.
    thanks all
    2mchfun likes this.
  2. Sep 3, 2025 at 6:21 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Did you unplug anything?
    Sandersox[OP] and 2mchfun like this.
  3. Sep 3, 2025 at 6:22 PM
    Welcome from NY.
  4. Sep 3, 2025 at 6:27 PM
    2mchfun
  5. Sep 3, 2025 at 7:01 PM
    Sandersox
    Oz
    None
    Didn’t unplug anything at all. The description is in the post I just posted.
  6. Sep 4, 2025 at 4:32 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Sandersox[OP] likes this.
  7. Sep 5, 2025 at 12:57 PM
    Sandersox
    Oz
    None
    Anyway, here is my scenario.
    Recently I bought a 2007 with 170,000 miles on it. I replaced a leaky high pressure PS line. I then did the oil, coolant, front and rear diffs, and transfer case.
    I used Toyota super long life coolant and house brand synthetic 75w90 on both diffs and the T case. 2 days later the Engine light and traction control lights came on along with flashing VSC off and 4LO lights. This happened while I was driving. Could it be the fluid used for the diff?
    Before the lights came on, the truck started shifting weird when picking up speed at around 45 MPH. I didn’t think too much of it then about 20 miles down the road the lights came on.
    I was driving in some knee high brush and on a grid road at the time of the occurrence. So maybe I bumped something underneath? I checked and there is nothing obvious.
    i pulled out my $30 scan tool and pulled the code P0976. I have searched for answers before making this post and found only similar posts with no luck to my case.
    I tried disconnecting the battery for 15 minutes twice. As soon as I in leave the house the lights come on. It feels like the truck is starting off in second gear.
    thanks all
    2mchfun likes this.
  8. Sep 5, 2025 at 1:08 PM
    2mchfun
    T
    Your code is for a transmission solenoid issue and will affect the shifting. Watch "Car Care Nut" channel on YT and learn how to drain and fill the tranny fluid with Toy WS fluid while the truck is cool. Don't forget to pin the cooler thermostat open during the process. Also open fill plug prior to drain plug to make certain you can fill it. A hose and a funnel from the engine bay or a large syringe will help you fill. A pump sprayer type tank also works.
    If that don't help, you need to check the wire harness to the tranny for damages or loose connectors. Either way, your tranny is due for a drain and fill. Do not flush!
  9. Sep 5, 2025 at 1:12 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    You didn’t accidentally drain your transmission pan instead of the engine oil pan when doing your oil change, did you?
  10. Sep 5, 2025 at 1:19 PM
    2mchfun
  11. Sep 5, 2025 at 4:26 PM
    Sandersox
    Oz
    None
    Ok, I will try this first. Thanks for the suggestion. I appreciate it.
    2mchfun[QUOTED] likes this.
  12. Sep 5, 2025 at 4:33 PM
    Sandersox
    Oz
    None
    Hi, no. I made sure that I drained the right things. This wasn’t my first time servicing all of these things. I have done all before except the transmission on other vehicles. I may have overfilled the transfer case but I’m usually careful on these procedures. I will double check the level.
  13. Sep 5, 2025 at 6:14 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    FYI. You’re not supposed to put 75w90 in the transfer case. Only the differentials. Only 75W goes in the transfer case.
  14. Sep 5, 2025 at 6:20 PM
    2mchfun
    I thought I read the older transfer cases were specd differently, no? Pretty sure OP is correct.
  15. Sep 5, 2025 at 6:21 PM
    2mchfun
    Who has a 2007 manual?
  16. Sep 5, 2025 at 6:29 PM
    Danman34
    Danman34 New Member
    Danny
    That may be possible.
  17. Sep 5, 2025 at 6:53 PM
    Mr Badwrench
    Mr Badwrench New Member
    There is really nothing that you have done that would cause any issues. You mentioned that you just purchased it, did the previous owner mention any known issues?
  18. Sep 5, 2025 at 7:00 PM
    Jefejrs
    Jefejrs New Member
  19. Sep 6, 2025 at 8:15 AM
    Sandersox
    Oz
    None
    He didn’t mention anything about the power train at all.
    2mchfun likes this.
  20. Sep 14, 2025 at 5:04 PM
    Sandersox
    Oz
    None
    Hello everyone,
    well today I finally found time to do the drain and fill as per the Carcarenut on YouTube. Just under 3 quarts came out. I took the truck for a test drive without doing anything else and the lights are still the same and everything else seems to still be the same.
    I will check the wire harness to the transmission tomorrow and will let you know how that goes.
