  1. Sep 13, 2025 at 4:19 PM
    Vizsla
    Vizsla pretend2send
    No Baja trip plans. If we do a Baja trip it would likely be truck campers, so no Tundras.
    BiggHertz and reywcms[QUOTED] like this.
  2. Sep 13, 2025 at 6:09 PM
    AZTundra
    Paul
    Phoenix, AZ
    Installed the OEM power tailgate lock kit I picked up from @Jchetty today. I could have taken the easy route and just mounted the actuator and tapped into the wiring I had previously run from the KTJO kit, but I don’t like to half ass anything so I removed the KTJO kit entirely and then rerouted the OEM harness to complete the install. Pretty simple job with the biggest hassle being that I had to lower the spare tire to cut some of the old zip ties that I couldn’t otherwise access. The OEM kit is much quieter that the KTJO kit. My KTJO actuator broke after only a few months of use. I think the way it was mounted put too much stress on the end of the actuator and caused it to snap. Much happier with this kit and it also includes built in fuses where power gets tapped behind the kick panel.
    bulldog93, mqqn, Boneskull420 and 9 others like this.
  3. Sep 13, 2025 at 6:16 PM
    Jchetty
    Jchetty New Member
    NJ, Middlesex County
    :hearteyes: :bananadance:
    Awesome install. That OEM kit is worth it weight in gold. Should outlast the truck.
  4. Sep 14, 2025 at 11:02 AM
    SND Racing
    SND Racing New Member
    2020 Tundra Limited TRD Off Road Crewmax
    2 inch lift, Fuel wheels, cat back exhaust, Diode Dynamics amber front lights, ARE topper, custom storage boxes, and more...
    One more LED headlight update. Painted top clear orange. Use Tamya Color. Have to wait 24hrs to put clearcoat protection on. Decided to match the fog lights. I'll post pic when done and reinstalled but this is what I did today.
    bulldog93, rdiddy5, mqqn and 4 others like this.
  5. Sep 14, 2025 at 11:26 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    You specifically just painted the top DRL orange?
  6. Sep 14, 2025 at 1:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Do the B pillar too!
    Dsptundra[QUOTED] and Yota303 like this.
  7. Sep 14, 2025 at 2:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Admired it leaving the office late Friday
    Rear brakes and rotors yesterday - no pics though
    bulldog93, schleinj, Nbab23 and 14 others like this.
  8. Sep 14, 2025 at 2:14 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Took the pavement princess camping and a little 4x4 exercising.
  9. Sep 14, 2025 at 3:06 PM
    Florida AF
    Logan
    North Florida
    Brought my trailer home and spent some time on the road
    Decided I will be selling my rack and its accessories as I want to go a different route. @subspd
  10. Sep 14, 2025 at 3:46 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Thats a nice setup you have there, I wish we had enough property to build something like that. I think we pay about as much per month to store our travel trailer as the monthly payment itself right now. They keep jacking the prices up at the storage facility.
    bulldog93 likes this.
  11. Sep 14, 2025 at 4:09 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    is our coil tower brace that heavy? Or just awkward that it was just easier to use annengine hoist?
    also, I thought someone wasn’t getting keys to their shop till Nov?
  12. Sep 14, 2025 at 4:34 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    Feeling good enough and it was cool outside so I washed it. Finally ziptied up the dongar dashcam hardwire kit, and tighted the loose rearview mirror screw.
  13. Sep 14, 2025 at 5:29 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Scored a set of (4) retractable ratchet straps from Juggernaut Designs and installed them :thumbsup:
    rdiddy5, jmdaniel, bulldog93 and 6 others like this.
  14. Sep 14, 2025 at 5:58 PM
    Vizsla
    Vizsla pretend2send
    Mine weighs 30 lbs.. Bypass hoop and connectors complicate it a bit, it’s easier with the hoist when removing alone.
    Mentioned that, going to do what’s needed before, and what I want after the trip. I haven’t talked to him, waiting to get it back from the cam tower repair before scheduling. If Kyle doesn’t have time, I have another shop that can do it, but obviously prefer he does the work.
    BiggHertz[QUOTED] likes this.
  15. Sep 14, 2025 at 7:30 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Bought one of the LC blower motors from Fred Anderson for $120 shipped.
  16. Sep 14, 2025 at 8:46 PM
    Tundra805
    Tundra805 Quality. Durability. Reliability.
    Tennessee
    2020 CrewMax SR5 TRD 4x4 5.7 Cement
    The rodent threat is real. I had one living in the dashboard of my 2013 Tundra. Almost killed me. Like going to the ER. I actually contracted a parasitic infection in my lungs.
  17. Sep 15, 2025 at 4:05 AM
    SND Racing
    Basically. I played with a matte clear first, but went too heavy and got some yellowing. Gave me the idea to spray over with clear orange. If I did it again I would skip the matte layer. Top DRL does still shine through so top is now orange and bottom white.
  18. Sep 15, 2025 at 7:27 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
  19. Sep 15, 2025 at 7:46 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Just a heads up...
    Doesn't look like you have the flange bolts (90080-10400) on your order...
    If not, you'll need 2 of them as they don't come w/the hardlines, and they are used to secure the hardline brackets to pre-threaded mounting points.
  20. Sep 15, 2025 at 7:47 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Well shit! Thanks for calling that out! I'll get them added to my order. I was going off of the link I'd shared in my post and didn't see those in there.
  21. Sep 15, 2025 at 7:55 AM
    Tripleconpanna
    :hattip:
    I had the same thing happen...
    Fortunately, another member posted the info about the need for the flange bolts in a different thread. I had already received my OE parts, but had not started the install, so I ended up ordering them separetely. Not ideal, but better than being halfway through the install and not having them!!
  22. Sep 15, 2025 at 8:28 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Finding out in the middle of the job would have sucked big time!
  23. Sep 15, 2025 at 8:46 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    What is your opinion on those, as opposed to the older style ratchet straps? I hauled one of my motorcycle north a couple of weeks ago, and one of the ratchet straps decided to get twisted up. I've always thought they were kind of a PITA, and my buddy told me about the retarctables he had recently purchased. Are they as strong as the older variety?
    HulkSmurf14 likes this.
  24. Sep 15, 2025 at 9:03 AM
    jackienguyener
    Jackie
    2016 Tundra 1794
    I just installed them, so haven’t had a chance to test them out quite yet. They’re definitely high-quality all around though. They don’t feel like they’ll give out anytime soon.
  25. Sep 15, 2025 at 9:58 AM
    00h2itr
    00h2itr New Member
    Carolina's
    Posting this here for visibility. The GR code - GRob25Q324 - is available not only for trans cooler parts, but ANY OEM parts. Still requires the login, but you can basically get 50% off OEM parts right now if you buy from dealership that are having their 25% off sale as this code stacks with that.
    So, TLDR, if you're considering OEM parts anyway, use the code in addition to the 25% off sales (and free shipping) to save even more.
    Nbab23, Tripleconpanna, BR73 and 4 others like this.
  26. Sep 15, 2025 at 10:25 AM
    joseph_womack
    Joe
    Louisiana
    I didn’t have them for my brothers truck so I just stole two skid plate bolts and trimmed them down lol :rofl:
  27. Sep 15, 2025 at 10:30 AM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    I'd expect them to last a lifetime with that kind of price tag!
  28. Sep 15, 2025 at 10:38 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Can anyone confirm that part# 90105-A0450 is for the long upper control arm bolt and 90178-A0084 is for the nut?
    I have a 2018 SR5 Sport 2wd.
    I'm getting different results between a local dealer site and Fred Andersons site.
  29. Sep 15, 2025 at 11:41 AM
    sbxx312
    sbxx312 New Member
    Fat kid can move. The Sniv 65mm pulley is on my desk for now.
  30. Sep 15, 2025 at 3:29 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    I installed the Schoshe kit that I got from @RainMan_PNW. My Pixel 10 phone is too large to fit parallel to the truck so this works better with the larger phone. I used an Anker magsafe charger so it is slightly raised from the bed, which accommodates the camera that slightly sticks out from the phone. Fits and works perfectly. And it looks OEM. Definitely not going to miss that small cup holder that I have never used.
