Installed a transmission cooler on my 2021 Tundra TRD Pro. Here are the results.
Discussion in '2.5 Gen Tundras (2014-2021)' started by imgreenlantern2, Sep 14, 2025 at 3:06 PM.
  1. Sep 14, 2025 at 3:06 PM
    imgreenlantern2
    imgreenlantern2 [OP] New Member
    Snake Plissken
    Central Texas
    2021 Tundra TRD Pro Double-Cab
    #197 2021 Tundra TRD Pro Double Cab ordered in it's final model year. You could only get a TRD Pro double cab in 2021 buy ordering one. I ordered five weeks before Toyota closed down orders for that year. I would argue my TRD Pro is one of the rarest Tundra's ever made. 285/70/18 Nitto Ridge Grapplers. RCI rock sliders Leer Tonneau Cover NSV Hood Mounted Lightbar. Genuine Cooling Systems Transmission Cooler (FU Toyota for taking the coolers off in the 1st place WTF) Suspension air bags for better towing.
    Hello friends!
    I discovered this last summer after towing a 7,000+ camping trailer with my 2021 Tundra TRD Pro in flat ass Texas with no hills just kiddos, wife, and trailer, I was averaging 235-248 degrees in my transmission. Even with normal driving with just me in the truck I was averaging about 205 degrees for my transmission fluid.
    So, I went and bought the Genuine Cooling Systems transmission cooler and had it installed. I am happy to report that with normal driving I am averaging around 185-190 degrees, and that same camper with the family in tow, over labor day weekend I never got above 215-218 degrees.
    I want to take a second to say on behalf of all 2019-2021 Tundra owners and say, "F**k you Toyota. F**k you for taking the transmission coolers off of these trucks and putting us in this position of burning up these amazing AISIN transmissions prematurely!"
    The fact they have the Gaul to say you don't need one, and that we should be changing the fluid at 100,000 miles is an absolute SPIT in the face of us owners.
    I had the shop that put the cooler on change the fluid while they were at it, and it was dark. My truck is at 65,000 miles, and I don't tow much at all maybe 2-3 times a year (that camper by the way which is owned by my parents), and the shop said the transmission fluid had no chance of making it to 100,000 miles.
    On top of this and the fact 2022-2025 Tundra's have faulty engines has all but made me never want to own another Toyota product again.
    Ok, I am stepping off my soap box.
    Gentlemen, if you own a 2019-2021 Tundra the cooler I think is an absolute must own. Do not wait until 100,000 miles to change your transmission fluid do it at the 50,000 mile mark. Don't believe a dang word coming out of the mouths of Toyota they don't care about us anymore.
    Here is the link for those that want to get the cooler. https://genuinecoolingsystems.com/
  2. Sep 14, 2025 at 3:11 PM
    Aerindel
    Aerindel New Member
    Montana
    You just have to own an OLD toyota, everyone should boycott the new ones until toyota pulls their head out of their rears.
  3. Sep 14, 2025 at 4:25 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I agree the cooler is a good idea, and I run one too. In case you’re not aware, Toyota WS fluid turns dark pretty quickly with use, so color isn’t a great indicator of fluid condition. Hopefully you got it before damage was done. Did they mention any other issues with the fluid?
  4. Sep 14, 2025 at 4:37 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Just curious but we're you im S4 and tow haul mode when you saw the high tranny temps?
    I agree its probably the best longevity mod to do.
  5. Sep 14, 2025 at 5:05 PM
    imgreenlantern2
    Snake Plissken
    Central Texas
    Great question. Tow haul mode and then do tap shift. If I am flat I will run in 5th gear at 70 mph but depending on the load stay in 4th gear. The goal for me is to maintain 3,000-3,500 RPM to stay at the max power band. The high temps were regardless of the gear. They were just always high which I find disturbing.
    Tunrod and MadMaxCanon[QUOTED] like this.
  6. Sep 14, 2025 at 5:11 PM
    imgreenlantern2
    Snake Plissken
    Central Texas
    Great question! They did the white paper towel test. They poured some of my fluid on the paper towel next to good fluid, and mine was orange. They said if was still pink'ish it would be fine, but they said orange you replace so I did. I looked it up after and confirmed that they were right.
  7. Sep 14, 2025 at 5:26 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Like the other poster said it turns dark quickly. Im not saying you shouldn't have changed your fluid. Keep changing it and the cooler will help. But in 5k miles mine turns dark and looks bad like it has 100k miles on it on paper towel next to new fluid.
    Tunrod and MadMaxCanon like this.
  8. Sep 15, 2025 at 3:58 PM
    Magoo motors
    Magoo motors New Member
    Mark
    I just put a must have cooler on a 2021 and the color on the paper towel was blue wow? I went with a 28 row G-plus stock hard lines from 2018 shock all the rest and i could not be more happy ! cost me 600 & some time but I can now drive / tow an not worry at all worth every penny !!!
    MadMaxCanon likes this.
  9. Sep 15, 2025 at 4:59 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Glad I have the parts coming. Couple weeks back I did a drain and refill at 54k miles on my '21. Fluid was darker than I'd like to have seen but based on this thread, perhaps it's expected. Regardless, I won't wait another 50k to do another drain and refill.
