Hardware for rear access cab windows?
Discussion in '1st Gen Tundras (2000-2006)' started by xaq, Jul 30, 2025.
  1. Jul 30, 2025 at 10:32 PM
    xaq
    xaq [OP] 2003 4WD AC SR5 TRD Off-Road
  2. Jul 31, 2025 at 8:16 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Which exact parts are you missing? Just those anchor pieces the latch itself mounts into to secure the latch to the glass? I ask because several of us have messed around with replacing different parts and I don't know that there's been any particular problem with using aftermarket parts (we're pretty strongly an OEM-only cult on most things!). If you do buy those and they work (and don't leak, etc.), please post a follow-up here so others can know that product works.
  3. Jul 31, 2025 at 8:32 AM
    xaq
    yeah, the anchor hardware. I'm more concerned about finding the parts, but I guess I could try the Sienna hardware before I try a pick-n-pull if OEM is too expensive
  4. Jul 31, 2025 at 9:01 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    OEM are approx $40 each from Ourisman Toyota for instance. While those latches give many folks ulcers, the quality IMHO is better than aftermarket. Be sure you know your trim color if ordering by Toyota part #. The last 2 digits tell trim color
    For 2000-2004.....62910-34012-E0....E0 means it's in the brown, B0 is gray family etc
  5. Jul 31, 2025 at 9:20 AM
    Look at this picture to ID the part you need and inform us once you read this reply fully and figure out where in the diagram the parts are which you need.
    If the number next to that part is 10 digits and a hyphen (i.e. XXXXX-XXXXX), that number is your part number. If it's 5 numbers or 5 numbers w/letter after, that's just an index number. Tell me the index number, I'm happy to pull the part number for you.
    OEM isn't expensive if you know how to get legit OEM parts, direct from Toyota, at a discount. But nothing will beat simply hitting a junkyard and pulling the parts, you'll pay less than a few bucks, or potentially they may let you have for free.
  6. Sep 14, 2025 at 8:49 AM
    Gnarcar
    Gnarcar New Member
    Yesterday
    2001 4WD Tundra AC
    The Black Mamba likes this.
  7. Sep 14, 2025 at 2:56 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Gnarcar[QUOTED] likes this.
