2008 Tundra 5.7 Sr5 Won’t start
Discussion in '2nd Gen Tundras (2007-2013)' started by ToyotaGrl, Mar 16, 2025.
  1. Mar 16, 2025 at 3:56 PM
    ToyotaGrl
    ToyotaGrl [OP] New Member
    2008 Tundra 5.7 TRD/SR5
    Bouncing off another thread with exact same issues - replaced starter - started 5-6 times that night was able to move it next day same loud click, next day cleared codes and it started once, today - replaced crankshaft sensor (new code) still won’t start!
  2. Mar 17, 2025 at 5:13 AM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    Do you have to keep the charger on it all the time? It looks like you have one attached in the picture. Does it crank but not start or does it just make the loud click noise and not turn over? Could be battery or a fuel issue or a bad starter, it happens. Have you reset the ECU? Need more information.
  3. Mar 17, 2025 at 5:35 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I assume you did this already, but if not, check your battery cables/connections from terminal to starter and from ground terminal to its termination point for corrosion; sometimes that crap is hidden in the cable and not exposed or the connections can be loose...
    Another question is regarding the new starter... just confirming you replaced the starter and the solenoid with another comparable/quality unit??
    Next up I'd check your relays and make sure you don't have one that's a bit loose and wiggling around on you.
    Finally, without more info, the only other 'obvious' thing to double check is the battery... Sometimes you'll get an acceptable reading (volts), but still have an issue w/it.
    Y0TA PR0 likes this.
  4. Mar 17, 2025 at 6:44 AM
    Tundra family
    Tundra family New Member
  5. Mar 18, 2025 at 2:17 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    I would put the Toyota Crank Sensor back in it first of all. I have seen that code come up several times as a false code. The aftermarket crank sensors are junk and will cause more headaches.
    Start simple. Battery charged, cables clean, terminals good and tight.
    When it only clicks and wont turn over check the voltage of the battery. If its still good you know you have a wiring issues somewhere
  6. Mar 20, 2025 at 12:26 PM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Adding to Jeff_5_7 input, voltage drop during cranking can generate lots or errors as modules go offline. If it was running fine before the starting issue, I would not suspect crank sensor.
  7. Sep 12, 2025 at 6:28 PM
    twinssyndrome
    twinssyndrome New Member
    Any update on this? I’m having the same issue
  8. Sep 12, 2025 at 7:37 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    How many miles?
    If it's up around 180k, odds are it's the starter. Most usually die around 210k +/- 5k miles. Before you go there though, ensure it's the starter by jumping the relay with a jumper cable, crossing screwdrivers over the teeth or a paperclip.
    If it continues with the same click it's the starter.
  9. Sep 13, 2025 at 5:44 AM
    twinssyndrome
    I’m having the same exact problem as OP. Starter was just replaced with a Denso from Rock Auto
  10. Sep 13, 2025 at 10:54 AM
    blackdemon_tt
    Bruh, probably a mistery.. but there are some theories...
    1. try and replace the pig tail on that starter. Some people claim it wiggles loose. Rockauto is like 6 bux, ebay is 20.
    2. Ensure your battery terminals are completely clean and clear of corrosion.
    3. Which is where I'm at, your next fail to start, you can reposition your tilt/telescoping steering wheel to where it stops start failure. It's super random so best of luck.
  11. Sep 14, 2025 at 11:16 AM
    twinssyndrome
    Battery terminal was the issue.
