  1. Sep 12, 2025 at 4:01 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    I would be interested as well!:mudding:
  2. Sep 12, 2025 at 4:24 PM
    @WSDMetal
  3. Sep 12, 2025 at 4:44 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Installed new rear shocks and my Pop N Lock
    mqqn, bulldog93, BrandonL812 and 4 others like this.
  4. Sep 12, 2025 at 4:50 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Modified factory harnesses on the accessory side. Hot wired folding mirrors. IMG_3323.jpg IMG_3322.jpg IMG_3337.jpg
    mqqn, bulldog93, Boneskull420 and 4 others like this.
  5. Sep 12, 2025 at 5:03 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    To do that did you just have to run a wire to the mirror and then to the button on the mirror adjustment switch?
    ToyoMafia[QUOTED] likes this.
  6. Sep 12, 2025 at 5:35 PM
    Vizsla
    Vizsla pretend2send
    Have an off-road trip with my LT Tundra friends in November, so finally made some time to work on the truck. Goes to Toyota on Monday for cam tower repair, then off to the fab shop for repairs and add few things I’ve been wanting to do.
    Had to remove skid plates, bypass shocks, coil tower brace, and disconnect all accessory wiring. Fun stuff! Few pics below
    :mad::annoyed::censored: stupid cam tower leak
    Have to jack truck up by the frame until the front tires are close to off the ground to remove the tension on the coil tower brace for removal. Took a few pics of the truck at full droop in front on the limit straps. Fender lip is 49 1/2” from ground, strapped at 13.25” travel. Tires are still barely touching, this is at the fully usable droop limit for the cv joints, up travel is limited with a spacer 1” to keep the inner fenders intact with 37” tires.
    mqqn, bulldog93, HulkSmurf14 and 8 others like this.
  7. Sep 12, 2025 at 5:35 PM
    ToyoMafia
    Magic carpet.
    It’s a work in progress. Got the platinum mirrors installed (physically) also got the BSM pins switched so that system works like it should. Next up is wiring the Fold switch and tie in the auto dim. Big thanks to my brother @RainMan_PNW for always picking up the phone when I call.
    mqqn, bulldog93, reywcms and 4 others like this.
  8. Sep 12, 2025 at 5:45 PM
    joseph_womack
    Joe
    Louisiana
    Yeah I saw his post about adding the BSM and folding mirrors but I never read through the whole post
  9. Sep 12, 2025 at 6:26 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    When I first installed it, it seemed like it was close to the shifter, but I have not noticed in real-world use.
    I did not lose any steering wheel controls, and as far as I’ve noticed I didn’t lose anything in the center dash screen, although I admit I rarely use it for anything other than the digital speedometer.
  10. Sep 12, 2025 at 6:30 PM
    ToyoMafia
    Magic carpet.
    I’m ADD also lol. I did actually read all
    Of @RainMan_PNW thread on the process. I was actually proud of myself.
  11. Sep 12, 2025 at 6:32 PM
    bigmace
    bigmace New Member
    Oregon
    2021 Silver Tundra Limited / 2019 Black Sequoia SR5
    Replaced the front brakes. I’d say it was definitely time. OEM pads, rotors, and installation hardware. Reused the pad shims.
    Also got tech12volts JBL sub installed (infinity branded in my case)
    mqqn, bulldog93, Yota303 and 8 others like this.
  12. Sep 12, 2025 at 6:48 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    The (maybe) original TrueStart battery finally kicked the bucket. New battery is a Duracell 27F, 840CCA from Sam’s Club. I got scared off getting another TrueStart and bit on the higher CCA. I also need to replace the tie down, mine is corroded and nasty.
    mqqn, bulldog93, BrandonL812 and 3 others like this.
  13. Sep 12, 2025 at 7:21 PM
    joseph_womack
    Joe
    Louisiana
    Well I don’t even own a 2.5 gen yet :rofl:
    still hunting for one but getting closer and closer, one I was looking at didn’t have the BSM, but then another I did so I stopped researching for the time being
    mqqn likes this.
  14. Sep 13, 2025 at 6:48 AM
    bulldog93, Yota303 and Boneskull420 like this.
  15. Sep 13, 2025 at 6:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    When’s Baja…
    HulkSmurf14 likes this.
  16. Sep 13, 2025 at 8:22 AM
    martiartisan
    martiartisan New Member
    North Texas
    2020 Tundra DC, 2006 Tundra Crew Cab
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    Got the heated steering wheel and AJT Design steering wheel trim installed first thing this morning. It’s going to be a good day
    1794TX, Vizsla, RobertD and 9 others like this.
  17. Sep 13, 2025 at 8:28 AM
    joseph_womack
    Joe
    Louisiana
    That blue stitching is sick
    ATV25 and martiartisan[QUOTED] like this.
  18. Sep 13, 2025 at 8:31 AM
    martiartisan
    North Texas
    It turned out good! The stripe itself is a little off and I wish it matched the stitching, but they weren’t able to match the leather and stitching. Overall for the price I’m happy with it though! Feels great as far as driving experience is concerned.
    joseph_womack[QUOTED] and BR73 like this.
  19. Sep 13, 2025 at 8:51 AM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    I ordered my High-flying steering wheel off Amazon and it came in a Cartrimhome box .I added the black out pieces from Meso PXL_20250711_204724837.jpg 17577785473334560030240677152472.jpg
  20. Sep 13, 2025 at 10:20 AM
    ToyoMafia
    Magic carpet.
    martiartisan, JerryH, ATV25 and 6 others like this.
  21. Sep 13, 2025 at 10:40 AM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Im with you on that one. I need to add more myself but just lazy and dont want to take the time to tare out the floor and headliner because then I have to put it all back nice and neat:rolleyes:
  22. Sep 13, 2025 at 10:50 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Where did you buy the parts, and how much? Any reason why you didn't do the rears?
  23. Sep 13, 2025 at 10:57 AM
    Started my rewire project. Removed the Blue Sea circuit system and installed the Bantam X. The touchscreen is pretty sweet. Still have quite a bit of wire chasing, labeling, and organization to do.
  24. Sep 13, 2025 at 11:38 AM
    bigmace
    bigmace New Member
    Oregon
    I bought them from a local Toyota dealership when Toyota was doing a 25% off sale a couple months ago. Was about $250 for all the parts. Rears will be next but they still have some meat left on the pads.
    joseph_womack likes this.
  25. Sep 13, 2025 at 11:43 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    So he's still doing business? He's been off the grid lately. I know he's been dealing with health issues.
    ATV25 likes this.
  26. Sep 13, 2025 at 11:44 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Washed this dirty thing after months of intermittent rain and too-humid-and-hot-to-do-sh1t days.
    reywcms, BR73, Velocity72 and 6 others like this.
  27. Sep 13, 2025 at 11:46 AM
    that thing looks ready for some 40’s
  28. Sep 13, 2025 at 12:12 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I would rub unless I put another 3". I've got other immediate plans for it starting with super and ending with charger.
  29. Sep 13, 2025 at 12:15 PM
    ToyoMafia
    Magic carpet.
    I’m not dropping the headliner in the tundra. Did the FJ because I had to drop it. Tundra is gonna wait
  30. Sep 13, 2025 at 2:54 PM
    martiartisan
    North Texas
    Mine shipped in the same box from Cartrimhome. Took about a week to arrive even with the custom stitching request
    BR73[QUOTED] likes this.
