Color matched bumper end cap thread.
Discussion in '2.5 Gen Tundras (2014-2021)' started by r4z0r51o, Feb 18, 2017.
  1. Mar 29, 2017 at 6:49 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
  2. Apr 26, 2017 at 4:36 AM
    VAQuicksand
    VAQuicksand New Member
    Can anyone direct me to install video or instruction on how to install the front end caps as mentioned here?
  3. Apr 26, 2017 at 5:38 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
  4. Apr 26, 2017 at 5:51 AM
    Bmedic50
    Bmedic50 New Member
    Brandon
    2017 TSS Crewmax
    IMG_2853.jpg I replaced the entire front end (grill, hood bulge, headlights, and bumper. I also ordered a new center valance and had it color matched. For installation I had to search numerous videos on YouTube. This is what I would recommend because you have to start by taking off the grill, then the molding under the lights. (Searching for headlight replacement videos should get you there). Once those are off, you can access the bolts and clips for the bumper. I would recommend taking off the entire bumper as the end caps are attached to the center valance by multiple bolts that are very difficult to get to while on the truck.
    Tony v and Auriarte02 like this.
  5. Apr 26, 2017 at 6:04 AM
    VAQuicksand
    Didn't see reference to parking sensors. Any advice/caution about disconnecting and reconnecting the parking sensors? or is it like the fog lights.
    Thank you for the instructions.
    Auriarte02 likes this.
  6. Apr 26, 2017 at 9:11 AM
    Bmedic50
    Bmedic50 New Member
    Brandon
    2017 TSS Crewmax
    I don't have sensors so I'll defer to anyone who has experience with working around them.
  7. Apr 26, 2017 at 11:01 AM
    texasflyer
    texasflyer New Member
    2016 MGM Crewmax
    Magnuson S/C, BD Tuner, TRD Exhaust, TRD Rear Sway Bar, TRD Pro Grill, TRD Wheels, TRD Shift Knob, Escort Passport 9500ci Radar/Laser Detector, Retrofit Headlights (RX350 Projectors), Morimoto XB LED Fog Lights, Retrax Pro MX, Ceramic Tint, ESP Full Length Storage Box, Console Vault, Driver Side Grab Handle, WeatherTech Floor Liners, Diff Breather Mod, Color Matched Front End Bumpers, Color Matched Door Handles and Mirror Caps, Black TRD "Tundra" and "iForce" Badges, Removed chrome badges
    The parking sensor grommets are held in place by a retaining clip on the inside of the bumper. Once the retainer is removed, the sensor assembly comes out the front of the bumper. Be very careful when removing the actual sensor from the grommet not to damage the the rubber weatherproofing or thin gauge sensor wires.
    Hardest part IMO is reinstalling. I suggest routing the sensor through the new bumper hole and attaching to the grommet first before securing the assembly to the bumper with the retaining clip. The sensor will only go into the grommet one way so make sure you have it aligned correctly and don't force it too hard. Again make sure not to do any damage to the rubber weatherproofing. It wants to stick to the plastic grommet so it may help to use some type of non harmful lube.
    Hope this helps.
  8. Apr 26, 2017 at 2:21 PM
    757TUNDRA
    Illinois
    As far as reinstalling the sensors, I also had to file away some fiberglass in the sensor hole (in the end caps) for mine to fit. I couldn't get my sensors in before I did that.
  9. Apr 27, 2017 at 4:55 AM
    VAQuicksand
  10. Apr 27, 2017 at 7:48 PM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I had my chrome ones painted. I was going to powder coat but he assured me the paint would hold up just as well and match better. They media blasted, primed, painted and cleared for $130
  11. Apr 27, 2017 at 9:17 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
  12. Apr 27, 2017 at 10:11 PM
    Gibzki
    Gibzki New Member
    14 White Tundra DC TRD 4X4
    Bakflip Tonneau Cover Fibermax Amp Power Step Moto Metal M0961 Pro Comp Xtreme M2 295/55R20 2 8" Rockford Fosgate Punch Alpine MRP-M500 Mono Power Amplifier LED headlight, foglight, reverse light, license plate light, cargo light, map light, dome light, vanity and footwell Magnaflow 15304 with black tip
    Powdercoat. 40.00 per end = 160.00. Not a perfect match here when new in the first 2 pictures. Barely noticeable now that it faded in the last pic.
  13. Apr 28, 2017 at 8:34 AM
    Sporto
    Sporto New Member
    2014 Radiant Red Tundra Limited CM TRD
    I have a set of 2014 front chrome end caps with sonar cutout. PM me if interested in them.
  14. Apr 28, 2017 at 12:36 PM
    uncbm30
    uncbm30 New Member
    Brando
    2015 Tundra 1794 Ed
    4.5 BDS Lift, 35" Terra Grapplers, Window Tint, TRD Exhaust, TRD Cold Air Intake, TRD Pro Grille, TRD Pro Front Bumper, all paint-matched trim, Peragin Truck Bed Cover
    I just got rid of all chrome on my 1794 Ed. Replaced grille with TRD Pro, and color matched bumper, side view mirrors, and door handle....IMG_1141.jpg IMG_1147.jpg IMG_1149.jpg
  15. Apr 28, 2017 at 3:12 PM
    manofsteele2003
    Grant
    24 Sequoia TRD Pro
    What rims do you have and what's the offset? Looks good and doesn't seem to stick out too far. Debating whether or not to get rims and tires or just tires, I've got stock 20" Limited wheels.
  16. Nov 2, 2017 at 7:53 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    Man, I'd be all over it for that price. I e-mailed the local shop that does PC here for a quote. Fingers crossed...
  17. Nov 2, 2017 at 5:27 PM
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Here's my color matched bumper ends from @Roman
    DaBoro54, Nick452, Tophergt99 and 3 others like this.
  18. Nov 14, 2017 at 5:36 AM
    Cbrunt
    Cbrunt 2017 SR5 CM
    Charles
    Sacramento
    2017 White SR5 Crewmax
    Bakflip g2 cover Trd pro grill/bulge Nerf bar steps
    What kind of fog light setup you have. Sweet ride bro
  19. Nov 14, 2017 at 9:47 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Do you still have the silver plastic piece for the center of the front bumper? is it called the valance?
  20. Nov 30, 2017 at 1:34 PM
    #50
    mpersell
    mpersell New Member
    2017 SR5 with upgrade kit
    TRD Pro Air, Magnaflow, 20" black wheels and badging
    Is your black stuff wrapped or painted?
  21. Dec 1, 2017 at 5:09 AM
    #51
    Tophergt99
    Weston, Wisconsin
    In progress....
    Painted and powder coated.
  22. Dec 2, 2017 at 10:29 PM
    #52
    D_will21
    D_will21 New Member
    D
    Oklahoma
    2017 Blue SR5 Crewmax TSS
    Flush mount LED.
    Get rid of the chrome! Sanded and painted chrome ends, grill shroud and hood bulge. The pro grill really just finished the look. 20171202_210554.jpg
    SchnauzerMan, HUTCHJ, Tony v and 7 others like this.
  23. Jan 4, 2018 at 7:33 AM
    #53
    AlexWV
    Alex
    WV
    Do you remember what vinyl and color you used? I'm getting mine done in a couple weeks.
  24. Jan 4, 2018 at 7:54 AM
    #54
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    For every1 thats painting or powder coating over chrome whay process are they taking? How is it holding? I was told they need to be dechromed, not blasted?
    thetwood likes this.
  25. Jan 5, 2018 at 8:15 AM
    #55
    shockinyall
    shockinyall Hillbilly
    West Virginia
    2017 TRDOR CM
    In Queue...
    Please share what you find out. Cost for PC and vinyl since I see you decided to go vinyl. I am in WV as well and would imagine that there are not that many shops around. Want to go color matched but having trouble deciding which way to go, paint, powder coat, vinyl.
  26. Jan 5, 2018 at 3:21 PM
    #56
    AlexWV
    Alex
    WV
    I was quoted $60-75 per bumper end for PC in Shinnston and $50 each for vinyl at HD Truck Center at the mall in Bridgeport. I’d go PC but that price was for me to remove them and bring them in and idk want to have to do that
    shockinyall[QUOTED] likes this.
  27. Jan 5, 2018 at 5:46 PM
    #57
    tyredfern
    tyredfern New Member
    2018 Tundra CM SR5 TRD OR Cement
    My 2018. Ordered the end caps and grille/bulge from Roman. Given TSS had to keep stock grille which I don't mind. Had end caps matched and painted at local boy shop. Sure beats the chrome.
    - T
  28. Jan 5, 2018 at 6:09 PM
    #58
    SuaveRC
    SuaveRC New Member
    So all your chrome was painted by a paint shop?
  29. Jan 6, 2018 at 3:27 PM
    #59
    D_will21
    D_will21 New Member
    D
    Oklahoma
    Flush mount LED.
    Yes a friend runs an auto body shop. Sanded with 80 grit dual action sander. Wiped clean, sprayed with self-etching primer. Then regular auto prime and paint. So far so good only paid material cost the four bumpers grill and hood bulge paint was $250.
    A lot of shops will not attemt to paint over chrome. If I didn't have that type of hookup I would powder coat then paint to color match. I definitely like the solid steel construction of the chrome bumpers. No shaky fog light bounce.
    Henry1jg, SchnauzerMan, Ahhhz and 2 others like this.
  30. Jan 6, 2018 at 3:33 PM
    #60
    Darth Tundra
    Curt
    17 CM TRD Black
    I did the exact same thing at my bodyshop...did it myself. 20171207_133737.jpg 20171207_140246.jpg 20171207_150042.jpg 20171031_145704.jpg 20171031_145711.jpg...even painted this front center piece
