  1. Sep 12, 2025 at 4:01 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    I would be interested as well!:mudding:
  2. Sep 12, 2025 at 4:24 PM
    @WSDMetal
  3. Sep 12, 2025 at 4:44 PM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Installed new rear shocks and my Pop N Lock
  4. Sep 12, 2025 at 4:50 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Modified factory harnesses on the accessory side. Hot wired folding mirrors. IMG_3323.jpg IMG_3322.jpg IMG_3337.jpg
    Boneskull420, BR73, RobertD and 2 others like this.
  5. Sep 12, 2025 at 5:03 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    To do that did you just have to run a wire to the mirror and then to the button on the mirror adjustment switch?
    ToyoMafia[QUOTED] likes this.
  6. Sep 12, 2025 at 5:35 PM
    Vizsla
    Vizsla pretend2send
    Have an off-road trip with my LT Tundra friends in November, so finally made some time to work on the truck. Goes to Toyota on Monday for cam tower repair, then off to the fab shop for repairs and add few things I’ve been wanting to do.
    Had to remove skid plates, bypass shocks, coil tower brace, and disconnect all accessory wiring. Fun stuff! Few pics below
    :mad::annoyed::censored: stupid cam tower leak
    Have to jack truck up by the frame until the front tires are close to off the ground to remove the tension on the coil tower brace for removal. Took a few pics of the truck at full droop in front on the limit straps. Fender lip is 49 1/2” from ground, strapped at 13.25” travel. Tires are still barely touching, this is at the fully usable droop limit for the cv joints, up travel is limited with a spacer 1” to keep the inner fenders intact with 37” tires.
  7. Sep 12, 2025 at 5:35 PM
    ToyoMafia
    Magic carpet.
    It’s a work in progress. Got the platinum mirrors installed (physically) also got the BSM pins switched so that system works like it should. Next up is wiring the Fold switch and tie in the auto dim. Big thanks to my brother @RainMan_PNW for always picking up the phone when I call.
  8. Sep 12, 2025 at 5:45 PM
    joseph_womack
    Joe
    Louisiana
    Yeah I saw his post about adding the BSM and folding mirrors but I never read through the whole post
  9. Sep 12, 2025 at 6:26 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    When I first installed it, it seemed like it was close to the shifter, but I have not noticed in real-world use.
    I did not lose any steering wheel controls, and as far as I’ve noticed I didn’t lose anything in the center dash screen, although I admit I rarely use it for anything other than the digital speedometer.
  10. Sep 12, 2025 at 6:30 PM
    ToyoMafia
    Magic carpet.
    I’m ADD also lol. I did actually read all
    Of @RainMan_PNW thread on the process. I was actually proud of myself.
  11. Sep 12, 2025 at 6:32 PM
    bigmace
    bigmace New Member
    Oregon
    2021 Silver Tundra Limited / 2019 Black Sequoia SR5
    Replaced the front brakes. I’d say it was definitely time. OEM pads, rotors, and installation hardware. Reused the pad shims.
    Also got tech12volts JBL sub installed (infinity branded in my case)
  12. Sep 12, 2025 at 6:48 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    The (maybe) original TrueStart battery finally kicked the bucket. New battery is a Duracell 27F, 840CCA from Sam’s Club. I got scared off getting another TrueStart and bit on the higher CCA. I also need to replace the tie down, mine is corroded and nasty.
  13. Sep 12, 2025 at 7:21 PM
    joseph_womack
    Joe
    Louisiana
    Well I don’t even own a 2.5 gen yet :rofl:
    still hunting for one but getting closer and closer, one I was looking at didn’t have the BSM, but then another I did so I stopped researching for the time being
  14. Sep 13, 2025 at 6:48 AM
  15. Sep 13, 2025 at 6:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    When’s Baja…
    HulkSmurf14 likes this.
