Adding to gas tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jas1970, Sep 12, 2025 at 5:24 AM.
  1. Sep 12, 2025 at 5:24 AM
    Jas1970
    Jas1970 [OP] New Member
    Friday
    2014 Black Tundra
    Fox suspension, 6 inch lift, ranch hand front bumper and winch, Prinsu rack, ARE camper top, DECK drawer system,
    I know there is a larger gas tank made to replace the OEM, however, I was wondering if anyone had added a second tank under the bed where the spare tire would usually sit. I don’t carry a spare and there is plenty of space under the bed.
  2. Sep 12, 2025 at 6:07 AM
    No and it would make more sense to upgrade the current tank.
    Corndog123 and blenton like this.
  3. Sep 12, 2025 at 6:40 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Corndog123 likes this.
  4. Sep 12, 2025 at 7:59 AM
    2mchfun
    Tundras and rear end collisions don't jive real well
    Corndog123 and HulkSmurf14 like this.
  5. Sep 12, 2025 at 9:18 AM
    blenton
    blenton New Member
    Like @Tundra234 said, the larger 38 gallon factory tank is a better option. Transfer flow also makes a ~46 gallon tank. I looked at both for my ‘13 but opted for a factory 38 gallon: it’s much lighter, reuses the factory 26 gallon mounting locations, and was about half the price. You do need to figure out the front gas tank mount/crossmember but it shouldn’t be too difficult. I have all the parts in my shop waiting to do the conversion on my truck.
    Some do the online dealership parts places have an occasional 25% off plus free shipping promo which helps drop the price. Unfortunately, they won’t ship the new fuel tank for free - or what I’d consider a reasonable price - so you will need to find one locally. I had to get one from a dealership 3 hours away (I had family headed that way anyways). I called ahead of ordering as asked if they would hold on to it for a week or two before they could pick it up and they were ok with that. I was able to order it with a discount, then pick it up. Note, however, that most dealerships that sell online won’t match the online price if you walk up to the same dealership’s parts counter.
    Several years ago, legislation was passed that makes replacing the fuel tank in a gasoline powered vehicle with an aftermarket part incredibly difficult. I had a pretty in depth conversation with the guys at Titan Fuel Tanks (they are just down the road from me) about a larger fuel cell for our trucks. The gist of it was: legislation prevents them from doing it without millions of dollars in certifications for EACH product they develop or vehicle they develop it for. The crux of the issue is the lining required for gasoline powered vehicles and the bras tax/testing surrounding that liner. Diesel-powered vehicles aren’t subject to the same legislation so they continue to manufacture replacement tanks for those vehicles. They can use a different liner but despite it being suitable for gasoline as well, they can’t sell it for gasoline.
    As I understand it, Transfer Flow already had already developed the tank and had been selling it before the new legislation, so after a legal fight, they were able to reintroduce it.
    The only way you could add a second tank to the vehicle would be as a transfer tank that pumps in to the fuel filler. But even that would be tricky and may throw codes. Not quite as easy as it used to be with dual tanks in a pickup.
    That’s why I went with a larger factory tank.
  6. Sep 12, 2025 at 5:04 PM
    Jas1970
    Friday
    2014 Black Tundra
    Thanks blenton, prob the most informative response I have ever read in a blog. I’ll definitely take your recommendations.
  7. Sep 12, 2025 at 5:24 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    65 gallons. Anything is possible depends how much you wanna spend.
  8. Sep 12, 2025 at 6:36 PM
    WiscoPete
    WiscoPete 2020 Tundra Limited
    Appleton, Wisconsin
    2020 Tundra 5.7 Limited
    Just so you know, the 38 gallon factory tank only holds about 32 gallons (do a search - there are a TON of posts about it). I am still glad I have it, until it is freezing out and it takes a while to fill :)
    I do get about 500 miles on a tank.
  9. Sep 12, 2025 at 6:41 PM
    blenton
    blenton New Member
    It holds 38 gallons, there is just a 6 gallon reserve when the gas light turns on. The 26 gallon tank is the same - gas light turns on at 20 gallons. There is some speculation as to why Toyota does this, but since the tank is basically flat-bottomed, 6 gallons isn’t very deep in the tank - maybe 3” deep. Supercharged trucks are warned not to floor it with less than 1/4 tank because the acceleration can cause the enough movement in the fuel cell to run the pump dry for a second.
    So, yes, you can put 38 gallons in it. I’ve put 26 gallons in my 26 gallon tank. It’s not a good idea, though…
  10. Sep 12, 2025 at 6:55 PM
    WiscoPete
    Appleton, Wisconsin
    So in theory, I have 6 gallons left when the truck says zero miles to empty? (talking theory, not what is best for keeping the fuel pump cool)
  11. Sep 12, 2025 at 6:58 PM
    blenton
    blenton New Member
    Correct. Give it a go and see what happens :)
  12. Sep 12, 2025 at 7:23 PM
    joseph_womack
    Joe
    Louisiana
    Yup Blenton is dead on, I think most I’ve ever put into my 26 gal is about 22 gal, I’ve driven on E for about 40 miles but no more
    Corndog123, HulkSmurf14 and blenton like this.
  13. Sep 12, 2025 at 9:39 PM
    70m4h4wk
    70m4h4wk New Member
    Paris of the Praries
    23 Silverado LT, CCSB, 2.7L Turbo
    2/2 Drop, Ram Daytona Spoiler
    Titan fuel tanks makes a spare tire tank. They can only market them for diesel, as explained above, but you should be fine to use it for gas. You'll need to figure out getting it to pump into your factory tank without throwing codes.
    HulkSmurf14 likes this.
  14. Sep 14, 2025 at 11:32 AM
    USAFx
    USAFx New Member
    Andre
    Port St Lucie, FL
    2021 Tundra Limited - Cement
    if I do the tank, this is the route I would take also.
    blenton[QUOTED] likes this.
  15. Sep 14, 2025 at 3:45 PM
    imgreenlantern2
    imgreenlantern2 New Member
    Snake Plissken
    Central Texas
    2021 Tundra TRD Pro Double-Cab
    #197 2021 Tundra TRD Pro Double Cab ordered in it's final model year. You could only get a TRD Pro double cab in 2021 buy ordering one. I ordered five weeks before Toyota closed down orders for that year. I would argue my TRD Pro is one of the rarest Tundra's ever made. 285/70/18 Nitto Ridge Grapplers. RCI rock sliders Leer Tonneau Cover NSV Hood Mounted Lightbar. Genuine Cooling Systems Transmission Cooler (FU Toyota for taking the coolers off in the 1st place WTF) Suspension air bags for better towing.
    As a 2021 Tundra owner I can confirm this is absolutely false information. I have put 36.2 gallons into my 2021 on a road trip once. I went 644 miles on that tank.
  16. Sep 14, 2025 at 4:37 PM
    joseph_womack
    Joe
    Louisiana
    Dang almost 18 mpg that’s crazy!
    I don’t think I have the courage to drive it that low on E though :rofl:
  17. Sep 14, 2025 at 4:42 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    It isn't a great idea to routinely drive past empty as the fuel pump could get damaged but in an emergency its no big deal.
    joseph_womack[QUOTED] likes this.
  18. Sep 14, 2025 at 5:00 PM
    imgreenlantern2
    Snake Plissken
    Central Texas
    100% agreed! I remember that trip very vividly. I was coming from Texas going to Phoenix Arizona, and if you have ever driven along I-10 from New Mexico to Arizona there is absolutely nothing. We were thanking the good Lord we made it to the gas station that we did. I have never let it get that low since.
  19. Sep 14, 2025 at 5:26 PM
    MadMaxCanon
    Im driving to Phoenix from SoCal in a couple weeks to get a camper and I have the smaller gas tank. 100% bringing some jerry cans along.
  20. Sep 15, 2025 at 2:59 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Love it!!
  21. Sep 15, 2025 at 7:49 AM
    joseph_womack
    Joe
    Louisiana
    Yep about 6 gal in reserve to keep the pump submerged
  22. Sep 15, 2025 at 6:08 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    You can easily add a gas tank where the spare tire goes. The old school way is to get one at a pick and pull that fits, or you can buy an nice aluminum one from Summit racing.
  23. Sep 16, 2025 at 8:26 PM
    Unfortunate Confusion
    Unfortunate Confusion Identify theft as a hobby
    2020 White SR5 DC 4x4 6-seater, 2018 Gray SR5 CM 4x4 6-seater
    I have a transfer flow and regularly hit about 550 miles before I fill with approximately 33 gallons. I wish I had just gone with a 38 gallon tank instead of the transfer flow due to the weight difference, but I do like it. At the time, it was cheaper for me to get the transfer flow so I went with that.
    blenton and HulkSmurf14 like this.
