750 e transmission problem
Discussion in 'New Member Introductions' started by thunder bolt, Sep 10, 2025 at 12:02 PM.
  1. Sep 10, 2025 at 12:02 PM
    thunder bolt
    thunder bolt [OP] New Member
    Wednesday
    Ralph
    2005 tundra access cab sr 4.7L
    n/a
    HY all
    I'm new here i have a 2005 tundra access cab 4.7L. sr . 180453 k miles don't know history. every thing i can see is all stock. no add ons. I recently did a trans drain and fill with filter change. Refill with idemitsu type TLS LV fluid. trans up shifts fine and when i gradually slow down to a stop trans downshift s fine. But if i have to come to sudden stop trans seems like it does not downshift with engine speed. After i stop there is a jult , that jult is the trans shifting into 1st gear i believe.
    What are your thoughtss on this issue
  2. Sep 10, 2025 at 12:05 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Might not be the trans at all. When was last time you lubed the driveline?
    When the driveline begins to dry up - fast stops cause the rear end to lift up and the brakes hold it there - then when you release some of the brake hold it will then jolt as you say like a bump.
    Do not overfill with grease - just 3 good pumps per fitting. Luck and enjoy.
    Mdl likes this.
  3. Sep 10, 2025 at 12:12 PM
    thunder bolt
    Wednesday
    Ralph
    n/a
    thank you for your reply
    I'm not sure what you mean by driveline. i did grease universal joints. I did nothing with rear end.
  4. Sep 10, 2025 at 12:18 PM
    Johnsonman
    Austin
    Sequoia
    Yeah drive line = Ujoints. Was hoping for something simple - common on other Toyota trucks.
  5. Sep 10, 2025 at 2:06 PM
    thunder bolt
    Wednesday
    Ralph
    n/a
    the ujoints weren't bad took 2 pumps.
  6. Sep 10, 2025 at 2:51 PM
    2wd or 4wd?
  7. Sep 10, 2025 at 3:02 PM
    It calls for Toyota WS fluid, is the fluid you used compatible?
    KNABORES likes this.
  8. Sep 10, 2025 at 3:08 PM
  9. Sep 10, 2025 at 5:56 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  10. Sep 10, 2025 at 5:59 PM
    Welcome from NY.
  11. Sep 11, 2025 at 1:24 PM
    thunder bolt
    Wednesday
    Ralph
    n/a
    it is a 2w rear drive.
    I did my research and found that the idemitsu atf type TLS -LV is compatible.
  12. Sep 11, 2025 at 1:29 PM
    thunder bolt
    Wednesday
    Ralph
    n/a
    I was thinking of replacing the solenoids in the trans not sure of the cost for parts , i can do the labor myself. then again i don't want to just throw in parts not knowing it will fix the issue. I think there 5 or 6 solenoids.
