5.7 Oil drain plug loose(ish)
Discussion in 'General Tundra Discussion' started by jcic22, Aug 27, 2025.
  1. Aug 27, 2025 at 12:52 PM
    jcic22
    jcic22 [OP] New Member
    I do my own oil changes and use all OEM stuff. I notice on my '21 tundra that when I perform an oil change, the oil drain plug is not as tight as I remember it being. It's almost loose, just barely snug. I use the drain plug washers that have a blue finish on them. The finish on it almost disintegrates like paper when I remove an old one, revealing the silver metal washer.
    Today when I changed the oil in the wife's '20 Sequoia I noticed the drain plug bolt was very tight. The last oil change on her vehicle was done by a local shop who has done great work for us. I noticed they used a copper washer on the drain plug bolt when they last did it.
    After this observation I went to snug up the oil drain plug on the tundra which had an oil change a few days ago. I definitely snugged it up a bit more.
    Does anyone share a similar experience with the OEM drain plug washer? It's almost like it loses it's integrity leaving the drain bolt not as tight as it should be.
    I don't use a torque wrench when snugging these up, but I have a decent feel for snug tight without going so far as damaging the threads.
  2. Aug 27, 2025 at 12:58 PM
    2mchfun
    Prior to installing a Fumoto vavle, I never had an issue with the blue washers. They did stick to the pan though.
    des2mtn and AZBoatHauler like this.
  3. Aug 27, 2025 at 1:55 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This ^^^.
    Get Fumoto (or equivalent) valves for your engine oil draining and never have to contemplate this conundrum again.
    Fobroader likes this.
  4. Aug 27, 2025 at 2:11 PM
    jcic22
    Not a good solution. I put one on the tundra for exactly one oil change interval. It took so long to drain the oil that the fumoto valve came off before it was even done draining because it took so long. I’ve got things to do, not wait around for 30min for the oil to finish draining. The longest part of an oil change without the fumoto valve is getting the stupid skid plate back on. Pain in the butt…
    I’ve had the blue washers stick to the oil pan before. No biggie. Just seems like the oil drain bolt feels looser over time compared to when I installed it. Curious if it was something any else noticed or not. Maybe it’s time to just get the torque wrench out and tighten it up per the spec….
    chugs likes this.
  5. Aug 27, 2025 at 2:13 PM
    2mchfun
    Check out the valvomax plug/valve, good stuff!
    Bought2Pull likes this.
  6. Aug 27, 2025 at 2:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Drill a hole in the skid plate for the fumoto?
  7. Aug 28, 2025 at 8:00 AM
    seydou
    seydou Distinguished Member
    You could always try torquing it to the manufacturer's spec. But then you would be made fun of by simpletons for not knowing what you are doing, and having no business changing your own oil.
    :crapstorm:
  8. Sep 1, 2025 at 11:21 AM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Sounds like the port is starting to strip with your next oil change you could replace the oil pan, tap it to a larger size( which I would remove to do so if you are removing the oil pan I would just replace it) or put a bunch of JB Weld or similar around the drain plug and use a fluid extractor for future oil changes
  9. Sep 1, 2025 at 12:10 PM
    jcic22
    Thanks. I’ll inspect the threads next time but I’m certain that isnt the case.
  10. Sep 1, 2025 at 4:25 PM
    seydou
    How would it be stripping out with just 4 years worth of oil changes? Over-tightening? That doesn't seem likely at all, given what's happening. There are many things I would consider and try before I go with removing/replacing/retapping the pan. And JB Weld would not be one of them, LOL.
    Inspecting the threads (should always be part of the procedure)
    Torque bolt to manufacturer specification
    Try a different bolt/washer
    Install Fumoto/ValvoMax/EZ Oil Drain
  11. Sep 4, 2025 at 1:43 PM
    Orions Dad
    2007 Tundra 4.7L
    When I hear the words loose drain bolt I think the worst and assume it has something to do with the threads. Yes it can be over tightening and cross threading when reinserting the drain bolt. It could be the bolt I am not a fan of Toyota OEM bolts I have changed out all of my differential, oil pan and transmission bolts with more sturdy and the drain bolts with Gold Plug versions applying a small dab and spreading either anti seize or thread sealant into the threads
    I have seen some extreme methods of work arounds when it comes to oil pan mishaps it all depends on the OP and his mechanical abilities. The JB Weld would have required the least amount of work
  12. Sep 9, 2025 at 8:15 PM
    tundras00
    tundras00 New Member
    I have seriously been considering on removing my Fumoto valve because as someone else said it takes so long to drain, but than again I might not want to deal with splatter everywhere and since there will be 8 quarts coming out fast it limits the type of pan to use since I have the TRD plate.
    One aspect that also bothers me is not knowing if all of the oil is draining out. I think the Fumoto sticks too far in for all the oil to drain out. What do you guys think?
  13. Sep 9, 2025 at 10:39 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I second the Valvomax oil drain plug (apologies if I'm actually the third or whatever as I did not read the entire thread). I have the Valvomax oil drain plug on, let's see, four vehicles now. It really does speed things up.
    Opt for the stainless steel drain knob but the plastic one works just fine.
    2mchfun[QUOTED] likes this.
  14. Sep 10, 2025 at 3:12 AM
    Orions Dad
    2007 Tundra 4.7L
    If you are concerned about oil coming out fast you could use a fluid extractor such as a Mityvac you will still need to get under the engine to change out the filter though
  15. Sep 10, 2025 at 6:24 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    If you are concerned about it coming out fast, splashing, making a mess, pissing you off, etc. you could elevate your oil catch pan. Set it up on an appropriately sized and sturdy cardboard box. I'm just spit balling here..........
