General Supercharger Thread
  1. Sep 9, 2025 at 10:57 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I replaced them every time as I did not want to chance it.
    I also replaced the knock sensors (not cheap for 4) :(
    HulkSmurf14 and mustang67408 like this.
  2. Sep 9, 2025 at 11:50 AM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    For ya'll that have long tubes - do you recommend it? I know it will be louder, but also more efficient. I can also hear a slight leak from having 10 year old manifolds, and that's driving me nuts alone.
    I know install can be a knuckle buster, but I'm not very concerned about that. How about getting the truck to idle right and not trigger CELs? How about brands - SW, Kooks?
    Ponderosa_Pine likes this.
  3. Sep 9, 2025 at 12:14 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I ran jba headers before going SC route. It was louder and a few more HP.
    ARH headers have one air tube off the 7 and 8 primary making it easier to get at the top exhaust manifold nuts. 3 inch with 1 7/8 inch collector. Have the O2 bung in the primary tube instead of collector to avoid reversion of gases on O2 sensor which causes some idling issues. issues.https://www.tundras.com/threads/general-supercharger-thread.85513/page-813#post-3925634
    Factory cats or quality ones will help with codes or anti-foulers. Some headers can cause you to run lean on a stock tune, not sure if you're supercharged but a tune may be in store to get the most out of them.
  4. Sep 9, 2025 at 12:30 PM
    BigAl
    BigAl New Member
    Now I remember reading about the o2 bung location. Supercharged and tuned. I'll be doing a few other things at the same time and a re-tune will be in order.
  5. Sep 9, 2025 at 12:44 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I saw DD is making what is I guess supposed to be replicas of the JBA LTs. $1650 a set so a bit cheaper. I thought I had leaking manifolds and it ended up being a gasket downstream of them.
  6. Sep 9, 2025 at 12:44 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  7. Sep 9, 2025 at 2:23 PM
    Danimal86
    Daniel
    Sacramento, CA
  8. Sep 9, 2025 at 2:45 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    24 TRD Pro
    The sound difference is big IMO, I know that I felt like I lost too much on the bottom end. If I did it all over again and kept the stock s/c pulley I wouldn't do headers. When you start pushing higher boost numbers they are a must.
  9. Sep 9, 2025 at 2:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've been waiting for Keith to re-make the JBA without the airtube. Hopefully soon.
  10. Sep 9, 2025 at 3:07 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I wonder if he'll change the head connection flange to a flat style vs what JBA was using before with the projected primary tubes into the gasket surface.
    e30cabrio and Mdl[QUOTED] like this.
  11. Sep 9, 2025 at 3:25 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    For efficiency and engine health I think LTHers are worth it despite some of the issues people end up dealing with. If you are chasing power numbers don't expect big gains from them.
    Loudness inside the cab will depend on your exhaust and how far back your mufflers are on the exhaust, more so when the rear cats are deleted. Based on the number of bird flips I get when passing people they are still loud AF and rowdy at WOT.
    Biggest issue with LTHers is the Left bank right bank oscillation that occurs with the O2s sitting rear of their OEM location; adding the bung others mentioned fixes the issue.
    If it matters to you, the SW aren't true 3" all the way through as they neck down before the cat back flange.
    IMO count on getting performance cats. While it's been shown stock cats are not restrictive they don't always hold up to higher boost.
    Knowing what I know now I would get headers again but only with a new O2 bung.
    Best of luck with your decision.
  12. Sep 9, 2025 at 3:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hopefully. I have the prototype JBA's when they were firstdesigning them. They needed a little fine tuning on the airtube and surface but have held up for the past 13 years.
    I almost had a local shop chop and weld the airtubes closed when I had pulled the passenger side for the trans swap. But they couldn't guarantee the flange wouldn't warp. Just took a little extra finesse to get the 2 top manifold nuts on behind the shock tower.
  13. Sep 9, 2025 at 5:28 PM
    Danimal86
    Daniel
    Sacramento, CA
    Alright. Need some advice from you guys. Im stuck....the hose from the side of the blower to the pcv isn't long enough....itll only go on like 1/4 of the pcv barb and when I click the qc in it pops off
    Ideas?
  14. Sep 9, 2025 at 5:35 PM
    Danimal86
    Daniel
    Sacramento, CA
    Anyone know if they measure the length of the hose or the entire assembly?
    Should be 10"
    HulkSmurf14 likes this.
  15. Sep 9, 2025 at 5:43 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I would just grab some random fuel line or whatever laying around and throw it on. That line isn't anything special and appears to be a barb connection on the top side anyway.
  16. Sep 9, 2025 at 6:01 PM
    Danimal86
    Daniel
    Sacramento, CA
    I don't have any laying around, but I can swing by the autoparts store in the morning and grab some. 3/8 would be the inner diameter?
    Another question, where does the catch can get installed onto?
    HulkSmurf14 and e30cabrio like this.
  17. Sep 9, 2025 at 6:02 PM
    blenton
    blenton New Member
    Between the PCV and the inlet that you are currently trying to plumb, if I’m not mistaken. Let me see if I can find a pic of mine installed. Super simple once you understand it. What catch can are you using?
  18. Sep 9, 2025 at 6:07 PM
    blenton
    blenton New Member
  19. Sep 9, 2025 at 6:08 PM
    Danimal86
    Daniel
    Sacramento, CA
    Well maybe that's going to be my solution to the problem of the short hose.
    I bought the Evil Energy one off Amazon
    https://www.amazon.com/dp/B081N392BN
  20. Sep 9, 2025 at 6:11 PM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    The catch can connects to the PCV, on the maggy 2650, they have you reuse the stock hose and try to bend it to get on and it pops off stupid easy, the catch can fixed that problem.
  21. Sep 9, 2025 at 6:15 PM
    Danimal86
    Daniel
    Sacramento, CA
    Ohh hell yeah. Perfect solution.
  22. Sep 9, 2025 at 6:16 PM
    Danimal86
    Daniel
    Sacramento, CA
    Thanks! The catch can will fix the problem then!
  23. Sep 10, 2025 at 5:37 AM
    nags
    nags New Member
    I love my Tri-Y's on my RCSB. Got a set going on the 2019 soon as well.
  24. Sep 10, 2025 at 5:48 AM
    ssmokedz
    Shelton CT
  25. Sep 10, 2025 at 5:54 AM
    Fastlane47
    Maryland
    24 TRD Pro
    I'm putting that one on the 24 next week, I used the same one on the 18.
    e30cabrio, HulkSmurf14 and ssmokedz like this.
  26. Sep 10, 2025 at 5:58 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    A dude definitely measured that hose when writing the instructions.
  27. Sep 10, 2025 at 5:58 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    Current : Magnuson S/C 5.7 FFV, Tundra CM, SNIV tuned w/HP Tuner, SG-1 Wide band AF w/gauge, TRD cat back, slotted and drilled rotors, stainless brake lines, TRD pads front and rear, front OEM Sport sway bar, rear TRD sway bar, 38 gallon OEM fuel tank, Tesla screen, ham radio, 2.5 Icons w/ res front and rear. X2 battery w/Voltage Booster Pro 2014 OEM wheels. 17.2 MPG on road trips https://drive.proton.me/urls/Y8739Z14BG#HCVT8AowG9fl ---------------------------------------------------- Previous: 2002 Tundra AC 2wd... Converted to OEM 4wd , S/C 4.7, TRD exhaust. 35's w/4:88's, too many other mods to list. https://drive.proton.me/urls/SWEWY4AFMC#eC7zX57Ex6pI ---------------------------------------------------- Other: 1967 mustang , Blown 408, 671Mike Kuhl 12.5% overdriven, 300shot NOs 5 speed TKO600, 4:11's Ford 9", Detroit Locker (real) Evans Coolant, Twin 12" Spahl fans https://drive.proton.me/urls/ABBVY3TQ3M#OT9LceyNwbTy ---------------------------------------------------- 2015 4runner TRD drop in filter Prinsu 1/2 roof rack, Nfab side steps, TRD FJ lift kit. ---------------------------------------------------- 2007 Prius 45mpg+ ... It's the only way to afford fuel for these Beasts!
    e30cabrio likes this.
  28. Sep 10, 2025 at 6:06 AM
    centex
    centex New Member
    Same. No way I'm spending hundreds of dollars on a beer can with steel wool in it.
  29. Sep 10, 2025 at 6:37 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes for longtubes. American racing headers on mine. Sounds great.
  30. Sep 10, 2025 at 7:06 AM
    Danimal86
    Daniel
    Sacramento, CA
    An inch short....story of my life
    I'm going to be getting going on day2 of the install here in a little bit.
    Got my dad coming over to help. It'll be nice to have a second set of hands.
    BigAl, Mdl, AZTundra and 4 others like this.
