5 Channel Amp Isn't Powering My Sub
Discussion in 'Audio & Video' started by 455h0le_dachshund, Aug 24, 2025.
  1. Aug 24, 2025 at 11:19 PM
    455h0le_dachshund
    455h0le_dachshund [OP] Death machine & man in love gogogogo
    Rev. Hotdog
    TX...big surprise
    Alpine S-A55V
    I'm only getting power to the speakers, but not the sub. It stopped working a few weeks ago and I adjusted the connections to the sub and it started working fine. Fast forward a few weeks and it stopped working again. I checked the wiring at the amp and the sub and the fuses. I'm at a loss here. Maybe something wrong with the amp?
    Any ideas, fellas?
  2. Aug 25, 2025 at 5:35 AM
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    Not just in "protection" mode or similar? (Always the simple stuff first.)
    Since you had "adjusted connections" and had it working after: Possible all yer base is shaking an internal power connection loose at/in the amp?
    This assumes there is a separate internal path to sub amp power section.
  3. Aug 25, 2025 at 5:42 AM
    If adjusting the connections helped, I would start by checking all of the connections and cables. Maybe a bad or cheap cable? If wiggling the cable at the amp (the speaker cable? Or the RCA input) makes it work, try replacing with a new cable. Of that doesn’t fix it, could be the actual terminal on the amp is loose, like a bad solder connection inside. My Punch amp does that now. I need to pull it and resolder the rcas.
    455h0le_dachshund[OP] likes this.
  4. Sep 9, 2025 at 7:33 PM
    Snert
    Snert New Member
    2021 SR5
    Have you checked connections from the sub to terminal cup inside the sub box? Lot of times those are soldered and can get brittle/break over time
  5. Sep 9, 2025 at 7:43 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I have not. Thanks for that info. I still need to work on fixing it this week. I haven't looked at it in about two weeks because it's not my fault driver.
    Snert[QUOTED] likes this.
  6. Sep 9, 2025 at 7:55 PM
    Snert
    Snert New Member
    2021 SR5
    Best of luck! Always annoying trying to diag intermittent problems like that, audio equipment or otherwise
