  1. Sep 8, 2025 at 4:14 PM
    YarbianTheBarbarian
    YarbianTheBarbarian New Member
    Ian
    Bloomington, IN
    '05 SR5 TRD 4x4 double cab
    None yet!
    Dang, seems to be very tire dependent. What size would you go with if you did it again today?
    I'm also somewhat considering upgrading to bilstein 5100s because I'm still on the old stock bilsteins. A little rub might help motivate me to action.
  2. Sep 8, 2025 at 4:18 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Got a pic of which part you're talking about?
    KTM_AJ421[QUOTED] likes this.
  3. Sep 8, 2025 at 4:31 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
  4. Sep 8, 2025 at 4:44 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Weird, I've got Cooper Discover AT3 LTs in 265/75/R16 and never had any rub at all, in fact I keep thinking about going bigger because they're not even close to my fenders/mud flaps. I have to park in a really small parking garage pretty regularly and that always involves having the steering at full lock. Maybe dependent on how the front alignment was setup?
  5. Sep 8, 2025 at 5:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I didn't realize there was plastic in there. Have you tried spraying the mechanism with WD-40 or something similar already?
  6. Sep 8, 2025 at 5:28 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    90% of the time i run little 215/85-16 E load tires. That’s a great size for cutting (more like crashing) cross country through the middle of the woods where there are no roads or trails. Backed up with 4.10 gears and it does fantastic both on the highway, towing, and offroad. Now if i lived in an apartment complex, drove on easy gravel roads, or got my coffee at starbucks, then i’d definitely require a larger tire and a lift kit. My truck plays double duty as a work truck, so i don’t want a bed that high up in the air since i have to reach into the bed. Nor do i want to hop up to get into the cab. FYI, i have a jeep CJ7 with 37” Boggers on it, so i’m not opposed to oversized tires. But for me i keep my CJ lifted and keep every thing else flying under the radar at stock high with stock sized tires.
  7. Sep 8, 2025 at 5:32 PM
    whodatschrome
    lots of dents
    Alignment might be the culprit. I take my truck off road, so my tire might get stuffed into the wheel well further.
    Also there’s no set spec on just how tall a 31” tire actually is. One manufacturer might build theirs at 29.5” tall, while another at 31.5”.
  8. Sep 8, 2025 at 5:53 PM
    Upshot Knothole
    Thatchery
    PDX OR
    True that on the tire sizes. Also why I want to go narrower if I go bigger.
    Mine mainly just sees forestry roads and somehow I’m really good at finding every dirt road that’s washboarded.
    This is how far forward mine sit. Slightly compressed because half on the curb.
    oscardog86 likes this.
  9. Sep 8, 2025 at 6:02 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    I've been running LT265/75R16 tires on both my 2004 and 2006 RCLB and they never rub. They are Les Schwab Open Range all terrain 6 ply tires.
    No lift.
    Upshot Knothole likes this.
  10. Sep 8, 2025 at 6:12 PM
    whodatschrome
    lots of dents
    side note, let’s see some glamor shots of your truck with the new ARB bumper installed!
  11. Sep 8, 2025 at 6:17 PM
    I ran 265/75/16s for 20 years. On my first set of 285/75/16s. Not going back.
  12. Sep 8, 2025 at 6:57 PM
    Upshot Knothole
    Thatchery
    PDX OR
    As soon as I can get out and go mountain biking this week I'll take some photos.
  13. Sep 9, 2025 at 12:32 AM
    bing5
    bing5 Long member
    New Mexico
    2004 Double Cab. 270k+
    Like she came out of the factory.
    Getting ready to do some valve cover gaskets for the first time. Is a gasket scraper worth the money or does a pocket knife work just as well? Thanks
  14. Sep 9, 2025 at 3:11 AM
    I’m wondering how necessary replacing those half moon things are for the job. I need to do it myself.
  15. Sep 9, 2025 at 3:14 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I used a razor scraper
    Might as well once you are in there. It'll add about 30 more minutes to a job that you know will be done right.
  16. Sep 9, 2025 at 3:30 AM
    I’m not convinced they’ll ever leak only because it’s not a smooth surface the way it fits in like a puzzle piece and oil thrown against it isn’t going to easily migrate its way out. I could be wrong but I’m willing to bet they won’t.
    Plus it’s at the back of a the valve cover out of view, so who’s going to see a few drips? :D
    455h0le_dachshund likes this.
  17. Sep 9, 2025 at 4:48 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Only everyone who is convinced that their rear main is leaking
  18. Sep 9, 2025 at 5:55 AM
    Barring any fuckery from the mods, this should be 10k posts. 7 years of good times and bad, shit posting galore, and a sprinkle of knowledge here and there. To 7 more years and 10k more shit posts my friends.
  19. Sep 9, 2025 at 6:16 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    malcolm gladwell said something along the lines that if you’ve done something 10,000 times, you’re an expert at it.
    bmf4069 likes this.
  20. Sep 9, 2025 at 6:21 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  21. Sep 9, 2025 at 6:32 AM
    I didn’t even realize I’m 979 posts beyond the 10k count. No biggie.
  22. Sep 9, 2025 at 6:51 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
  23. Sep 9, 2025 at 7:40 AM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    No good call I’ll try that now
  24. Sep 9, 2025 at 7:49 AM
    Dakillacore
    Georgia
    Id hit it with some white lithium grease on top of that
  25. Sep 9, 2025 at 2:36 PM
    That didn't take long.
  26. Sep 9, 2025 at 2:54 PM
    There was something else I wanted to order but now forgotten, but I want to order some oem drums and rotors
    bmf4069 likes this.
  27. Sep 9, 2025 at 3:22 PM
    What is the dealer that @shifty` detests?
    Jack McCarthy likes this.
  28. Sep 9, 2025 at 3:25 PM
    I was thinking that as well when I saw AL listed for the dealer.
  29. Sep 9, 2025 at 3:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Get the 14wa's
  30. Sep 9, 2025 at 3:40 PM
    Are those the Gx ones?
