What did I do to my rear hatch latch?
Discussion in 'Sequoia 1st Gen (2001-2007)' started by poormxdad, Aug 26, 2025.
  1. Aug 26, 2025 at 12:13 PM
    poormxdad
    poormxdad [OP] New Member
    2012 Tundra Grade Four Door 4.6 4WD/ 2007 Sequoia SR5 Leather
    All the trim push pins on the rear license plate surround piece on my ’07 Sequoia were broken or missing. It rattled and was driving me crazy. I wedged a piece of foam between it and the door, but wanted to fix it right. I removed the license plate, took off the interior trim on the hatch door, removed the access panels, and removed the nuts necessary to pull the surround out far enough to put in some new push pins. I didn’t disconnect the cable to the latch lever, or the connector for the license plate lights. I didn’t need to move the surround very far to get the new pins in. I put everything back together and now, the door won’t unlatch.
    The latch lever is the metal version. It seems to have resistance.
    It had to be something I did, since it was working fine beforehand.
    What should I look for?
    Thanks,
  2. Sep 9, 2025 at 3:17 AM
    poormxdad
    Just to close this out... the cable had slipped out of the holder and was just hanging by the ball. The plastic tip at the end of the cable guide is also broken. I slipped the cable back into the holder and I speed taped it to the door. The latch worked better than before, so I just put all the trim back on and called it done.
    The Black Mamba likes this.
