  1. Sep 8, 2025 at 3:15 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Today, I started insulating my bed and got some retro wheel decals.
  2. Sep 8, 2025 at 5:55 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    Now that it has 325K miles on it, I figured I should drop the transmission pan on my 2006 RCLB to see what kind of hideous creatures are living in there. It is the original tranny and never been rebuilt or anything. I did this once before at about 100K miles. I was pleased to see how clean the pan was, just a little fuzz on the magnets to wipe off. The pan had a rubber gasket which didn't leak, yet it fell as soon as the bolts were out. The bolts came out easy in spite of Montana winters.
    I have always used the expensive Toyota WS fluid and added 8 quarts every 100K miles or so and changed my Magnefine filter at the same interval.
    Toyota paints the inside of the pan with black paint so the pics don't do it justice.
  3. Sep 8, 2025 at 6:15 PM
    I did mine at 100k, new filter and all. I’m at 285k or so now, haven’t done it since. Just some drain and fills along the way.
  4. Sep 8, 2025 at 6:23 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    I have never taken my Magnefine filters apart to see what they're catching, But if I wasn't using them I would want to drop the pan at least once every 150K miles whether it needs it or not.
    oscardog86 and 455h0le_dachshund like this.
  5. Sep 8, 2025 at 6:41 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Definitely on my list. I just been doing drain n fills every third oil change. But I think I'll probably end up having a transmission shop install a Transgo shift kit, sometime in the future. So I'll just wait til then to replace the filter and clean the metal flakes, since they'll have to drop the pan to take out the valve body anyways.
    I've already regeared to 4.56 and VF tuned the ECU. From what I've been reading the next step to bullet proof the truck for all the 5hr+ long, 75mph+ highway drives is the Transgo kit. However some stuff I've read insists that the A750F is already bullet proof as is.
    I've already got the Transgo kit sitting in the garage for my A340E, if I ever get around to boosting my 03.
    Edit: also first I've heard of these magnetic inline filters. Definitely peaked my interest.
  6. Sep 8, 2025 at 7:25 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I read once that the "break even amount" was 60 seconds. So basically one would have to idle more than 60 seconds to use more fuel than would be used to start the engine. This was some time ago...30 years or something when I read that?
    455h0le_dachshund likes this.
  7. Sep 8, 2025 at 7:41 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Today we did what I call an "odd job." (Anything other than mowing or weedeating is an "odd job.")
    I loaded up the 1-axle trailer and the wife and I headed down that steep hill we photographed to repair a downspout for a couple. The lady had hit it with her 4-wheeler(!) and torn it down.
    We got the downspout straightened out (I suspect it looks better now than it ever has :p) and reattached, much more solid now than it ever was before.
    Just not enough hours in the day to do more. Tundra pulled the trailer fine, as always.
    Here is that steep hill again....
    But no need for Shift L this time, trailer was empty except for an 8 foot ladder and a single 2x4.
  8. Sep 9, 2025 at 4:19 AM
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd tow package
    Mine has one. I thought they all did.
  9. Sep 9, 2025 at 4:30 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    That's an early truck thing. Later trucks have a weight sensor on the passenger seat.
  10. Sep 9, 2025 at 4:46 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  11. Sep 9, 2025 at 4:53 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    2000-2004 RC & AC have the key.
    2004 DC and 2005-2006 have the sensor instead.
  12. Sep 9, 2025 at 5:01 AM
    I’ll have to see if I can get black label tape with white lettering print for my label maker at work. I may want to cover the lighted letters and change “airbag” to “ejection” and “on” to “activated”.
    :monocle:
  13. Sep 9, 2025 at 5:09 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    That sounds about right for the carbureted engines. It was much higher than fuel injected.
    Bought2Pull[QUOTED] likes this.
  14. Sep 9, 2025 at 9:08 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I had to double check your work and you are correct. I could've sworn both my trucks had the key. Just the 03 does. But now I'm wondering what this blank is supposed to be a button for? I never noticed it before.
    Jack McCarthy likes this.
  15. Sep 9, 2025 at 9:14 AM
    des2mtn
    Shady Grove
    Tonto cover
    Heated mirrors
  16. Sep 9, 2025 at 9:21 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    My heated mirrors are on the other side of the steering wheel, on the dash, next to the power sliding rear window switch.
  17. Sep 9, 2025 at 9:24 AM
    des2mtn
    Shady Grove
    Tonto cover
    Yeah, not on mine. The mirror button also warms the rear window. Additionally, the 05-06 1st gear button is a blank on mine.
  18. Sep 9, 2025 at 9:31 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Now to get a heater mirror button and harness to replace that dummy that will switch something else
  19. Sep 9, 2025 at 9:33 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I always wished my rear window had a defroster. Doesn't matter now, because the topper window also gets fogged up.
  20. Sep 9, 2025 at 9:41 AM
    ChattanoogaPhil
    Never given it much thought but this appears to be the right place and time to ask:
    What is this button otherwise for?
  21. Sep 9, 2025 at 9:44 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  22. Sep 9, 2025 at 10:30 AM
    Rear window slider on the RC/AC models?
  23. Sep 9, 2025 at 10:35 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    Yes. 2003-2006 AC Limited for sure, unsure if offered on RC.
  24. Sep 9, 2025 at 10:35 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    That wasn't a thing until 2003
  25. Sep 9, 2025 at 11:11 AM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Depending on the year and model, heated mirrors, power rear window, fog lights. Some of the cheap fog light kits for our trucks on Amazon include a knock off fog light switch that can be used for other exterior lights.
    If you ever remove that trim piece with the switches, you might already be wired for something behind there. When I pulled mine to install a ditch light switch I had the plug and harness for I believe the power back window.
  26. Sep 9, 2025 at 12:07 PM
    Desertrockmtn
    Desertrockmtn New Member
    Kyle
    2001 Toyota Tundra Limited 4x4
    Wonder if an early model AC can be convertered to have a power slide rear window
  27. Sep 9, 2025 at 12:11 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    It may be possible to install the 3pc AC slider into an older AC, since the cabs are dimensionally the same, but I haven't seen anyone try it yet. You could be the first and do it for science.
  28. Sep 9, 2025 at 12:19 PM
    The AC cab never changed from 2000-2006. The rear window is a bolt in with perimeter seal. Any rear window option should fit all of them.
    455h0le_dachshund and bmf4069 like this.
  29. Sep 9, 2025 at 12:23 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  30. Sep 9, 2025 at 1:12 PM
    ChattanoogaPhil
    Interesting. I see that the furthest button the left on my truck is for a different function than in pic post# 74033.
    My truck
