Snert’s Audio Build
Discussion in 'Audio & Video' started by Snert, Sep 8, 2025 at 2:15 PM.
  1. Sep 8, 2025 at 2:15 PM
    Snert
    Snert [OP] New Member
    2021 SR5
    I wanted to start a new thread to compile the many posts/pictures I’ve made across other threads/posts about my previous audio build and current rebuild. This’ll basically be a photo dump and as I’m finishing up the rebuild and more posts/pictures will be added in the coming months. For any of the new stuff I’ll provide details, but for all these old pics the details are in existing threads and I don’t want to bog this post down with text. Anyways, enough blabbing, here’s a bunch of pics from the builds with minimal descriptions:
    New head unit from Trail Grid Pro, pre-wired and Maestro programmed ready to drop in:
    upload_2025-9-8_15-24-57.jpgupload_2025-9-8_15-24-57.jpgupload_2025-9-8_15-24-57.jpgupload_2025-9-8_15-24-57.jpg
    Originally had Focal K2’s with the Frak tweeter for front stage, modified JBL sail panels to fit them:
    upload_2025-9-8_15-26-49.jpgupload_2025-9-8_15-26-49.jpgupload_2025-9-8_15-26-49.jpgupload_2025-9-8_15-26-49.jpgupload_2025-9-8_15-26-49.jpgupload_2025-9-8_15-26-49.jpg
    Fit was decent, but no way to secure and there was a noticeable overhang/lip so I used stranded body filler, the Frak included cups, glazing putty, SEM texture coat and SEM trim black to build custom sails.
    upload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpgupload_2025-9-8_15-28-39.jpg
    Used Resonix CLD/sound deadener on all the doors and rear wall:
    upload_2025-9-8_15-37-1.jpgupload_2025-9-8_15-37-1.jpgupload_2025-9-8_15-37-1.jpgupload_2025-9-8_15-37-1.jpg
    DIY’d block off plates using HDPE and rivet nuts/machine screws to attach them:
    upload_2025-9-8_15-39-6.jpgupload_2025-9-8_15-39-6.jpgupload_2025-9-8_15-39-6.jpgupload_2025-9-8_15-39-6.jpg
    Ran new wiring to each door, fronts were the usual grommet to door, but the rear doors/drilling out connectors was both nerve wracking and a pain.
    For power, I originally had a single fuse holder on a janky diy hdpe bracket. I’ve since added another power cable going to my center console for 4 heated seat circuits.
    This was my original amp rack, grounded to a factory ground point behind the driver’s side c-pillar trim. I’ve since tested and moved to a frame ground for less resistance (pics further on)
    upload_2025-9-8_15-46-6.jpgupload_2025-9-8_15-46-6.jpgupload_2025-9-8_15-46-6.jpgupload_2025-9-8_15-46-6.jpg
    I wanted to re-use a JL 8W7 I’ve had for a few years as the sub, so I built a center console extension box, mocked up using foam board from the dollar store, big fan/proponent of that stuff.
    upload_2025-9-8_15-50-37.jpgupload_2025-9-8_15-50-37.jpgupload_2025-9-8_15-50-37.jpgupload_2025-9-8_15-50-37.jpgupload_2025-9-8_15-50-37.jpgupload_2025-9-8_15-50-37.jpgupload_2025-9-8_15-50-37.jpgupload_2025-9-8_15-50-37.jpg
    Semi-related center console heated seat stuff, but also going to be mounting a digital audio converter here. HDPE panel that sits on rubber feet in bottom of the center console with a sandwich lid, essentially lose a couple inches of depth to do this.
    upload_2025-9-8_15-52-52.jpgupload_2025-9-8_15-52-52.jpgupload_2025-9-8_15-52-52.jpgupload_2025-9-8_15-52-52.jpgupload_2025-9-8_15-52-52.jpgupload_2025-9-8_15-52-52.jpg
    Really wanted to fit an Audiomobile Encore sub and removed the rear seats, threw some leftover deadener from other projects down, mocked up the sub and couldn’t find a way to make it fit. Opted to go with a Wavetech thinPRO 12 rear firing similar to the JL stealth box.
    For the new amp rack since I’ve got 3 amps going in, I opted to get the ESP Truck Accessories underseat locking storage box. Holes drilled in the box and hdpe panels with grommets for wire pass throughs. Amps etc. are mounted with heat inserts in the hdpe.
    Did a frame ground for less resistance than anywhere inside the cab after multimeter testing multiple locations.
    Helix conductor switch with a 3D printed top panel glued onto @RainMan_PNW’s switch panel for the shifter area, waiting on DAP la day delivery to finish wrapping it in vinyl pleather
    Added fiber mat to the front doors along with more CLD and butyl rope while I had the door panels off to mount the new front midbasses.
    Ordered 8” brackets from the awesome guys at Sounds Good Stereo and added heat inserts for mounting. CCF rings to help channel sound into the cabin.
    Added Knu Conceptz battery post terminals and an SMD fuse holder, along with a HDPE panel mounted to the top of the OEM fuse cover.
    Some random diy custom cables, big fan of Deutsch connectors for ease of use and quick waterproof connections especially for inside the doors.
    That’s all for now. Will have more to post in the coming weeks/months as I finish custom mounts/panels for the midranges going into the dash corners and tweeters in the a-pillars.
    Happy to answer any questions, if you scrolled through all that, thanks for looking!
  2. Sep 8, 2025 at 2:50 PM
    littlebus01
    littlebus01 New Member
    Tobias
    21 trd off-road
    Iron Man lift, still-cai, list goes on
    Wow :101010::101010: that looks great I will definitely be following your build.
    Snert[OP] likes this.
  3. Sep 8, 2025 at 3:09 PM
    blenton
    blenton New Member
    Love it!
    What do you think about the block off plates - worth it? I have a large piece of HDPE just begging to be used to build some block off plates.
    Did the WaveTech ThinPro 12 work out as expected?
    ..and because I'm lazy, would you mind adding a component list somewhere? I don't recall what mids you went with in the doors.
  4. Sep 8, 2025 at 3:33 PM
    Snert
    2021 SR5
    I havent gotten a chance to listen to the Wavetech yet, next step is installing the main amp and sub amp this week at some point.
    Happy to drop the components! Component list going in is:
    BLAM MB8D midbass in front doors
    BLAM MB3 midrange in dash corners
    BLAM T28S in the a-pillars
    Focal K2 midbass in rear doors
    Focal K2 (non-Frak) tweeters in the rear doors
    Wavetech thinPRO 12 for sub duty, maybe a second in the future and/or a front sub
    Helix P6 Ultimate for front stage
    Helix 204 Direct for rear stage
    Helix P1 for sub(s)
    Edit: @blenton forgot to answer your question about the block off plates, I don’t have an A/B before/after comparison so I can’t say wholeheartedly exactly how much of a difference they make, but IMO they’re worth it. The midbass I got out of the K2 6.5’s was honestly pretty impressive, obviously they’re midbasses so they didn’t play super low but I was getting pretty impressive output from them, definitely the best midbass I’ve had in a personal vehicle and I attribute a lot of that to the block off plates tbh. I know Sounds Good Stereo makes/sells them as well, but they were a fun project to DIY and learn to use a rivet nut tool. Only thing I’ll say is that be careful how thick you make them and/or the thickness of foam you use to decouple them. I used CCF around their perimeter to decouple them from the doors and create a better seal which worked well but my door panels are exceedingly tight to get back on, to the point I used a heat gun to soften/bend the top ones in a bit. Overall if you want a somewhat time consuming project that’s not too expensive, I’d say go for it!
    blenton[QUOTED] likes this.
