First Gen Tundra Electrical Connector Identification - Please make a Sticky
Discussion in '1st Gen Tundras (2000-2006)' started by bfunke, Aug 9, 2025.
  1. Aug 9, 2025 at 4:42 PM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    This thread is to identify and photograph the various electrical connectors in our trucks. The EPC does not do a great job of showing wire clips or electrical connectors.
    Please limit your posts to pictures of electrical connectors and part numbers. Do not add any other anecdotes or questions. Hopefully this can become a reference for members looking to repair their wire harnesses.
    Here is a picture of the depinning tool I found works well to de-pin our connectors.upload_2025-8-9_19-43-46.jpg
  2. Aug 9, 2025 at 4:47 PM
    bfunke
    2000 AC 4.7 Starter Signal Connector. Attaches next to the +12V lug.
    rouxster70 and The Black Mamba like this.
  3. Aug 9, 2025 at 4:49 PM
    bfunke
    2000 AC 4.7 knock sensor connector in the valley. There are two of these here. Note Toyota OEM replacements for some connectors are different colors. Original was gray and new one is white.
  4. Aug 9, 2025 at 4:53 PM
    bfunke
    2000 AC 4.7 green temp sensor on front water crossover
  5. Aug 9, 2025 at 4:58 PM
    bfunke
    2000 AC 4.7 gray temp sensor attached to front water crossover.
    rouxster70, tvpierce and jerryallday like this.
  6. Aug 10, 2025 at 10:11 AM
    bfunke
    2000 AC 4.7 Evap Solenoid on driver side of intake manifold
  7. Aug 10, 2025 at 11:21 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  8. Aug 10, 2025 at 10:15 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    :popcorn: Sounds very useful
  9. Sep 8, 2025 at 11:47 AM
    komodo1942
    komodo1942 New Member
    Los Angeles
    2003 Tundra SR5 2WD V6 Access Cab Automatic Transmission
    Hopefully this thread gets stickied. I am in search of the part # for the lower camshaft position sensor connector on the V6 models if somebody happens to know/has replaced it. Or more specifically, the black tab/grommet attached to it which holds it in place on the plastic timing cover. The connector for the female side is available, but I can't find this one anywhere.
  10. Sep 8, 2025 at 12:01 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
