  1. Sep 6, 2025 at 5:11 PM
    bmf4069 Captain wtf
    You know, somebody else's anniversary was 5 days ago...
  2. Sep 6, 2025 at 5:12 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Happy belated Birthaversary
    edit: he had to tell me it was mine :rofl:
    BroHon and bmf4069[QUOTED] like this.
  3. Sep 6, 2025 at 5:13 PM
    bmf4069 Captain wtf
    I was hoping to hit 10k posts by then, but there haven't been enough opportunities to shit post.
    BroHon likes this.
  4. Sep 6, 2025 at 5:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    It
  5. Sep 6, 2025 at 5:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Sounds
  6. Sep 6, 2025 at 5:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Like
  7. Sep 6, 2025 at 5:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    You
  8. Sep 6, 2025 at 5:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Should
  9. Sep 6, 2025 at 5:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Try
  10. Sep 6, 2025 at 5:14 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Harder
  11. Sep 6, 2025 at 5:15 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  12. Sep 6, 2025 at 5:16 PM
    bmf4069 Captain wtf
    I'm deleting this post do make yours make sense. Fucker. :rofl:
  13. Sep 6, 2025 at 5:17 PM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Happy 7th year buddy :fistbump:
    For some reason I just glanced and it caught my eye randomly... weird.
    EDIT: My own date caught my eye...
    bmf4069[QUOTED] likes this.
  14. Sep 6, 2025 at 6:27 PM
    Upshot Knothole
    Upshot Knothole New Member
    Thatchery
    PDX OR
    2003 SR5 V8 AC TRD 4x4
    Just bought my truck an underbite and even more rake.
  15. Sep 6, 2025 at 6:28 PM
  16. Sep 6, 2025 at 7:36 PM
    bing5
    bing5 Long member
    New Mexico
    2004 Double Cab. 270k+
    Like she came out of the factory.
    455h0le_dachshund likes this.
  17. Sep 6, 2025 at 9:49 PM
    bing5
    bing5 Long member
    New Mexico
  18. Sep 6, 2025 at 10:03 PM
    bing5
    bing5 Long member
    New Mexico
    Is pounding out these lug bolts with a big hammer and a punch a bad idea? I say no big deal. Buddy says may foul up bearings and to remove the hub, so on, so forth. (I know. Pretend it's a Tundra).
  19. Sep 7, 2025 at 4:51 AM
    bfunke
    bfunke Tundra Curmudgeon
    Shouldn’t be hard to tap the two broken studs out and then use a lug nut with some washers or a bigger nut to install new studs.
    bing5 and des2mtn like this.
  20. Sep 7, 2025 at 5:18 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
  21. Sep 7, 2025 at 6:04 AM
    bfunke
    Nice tool but not for $200. I’ve seen it done with a ball joint separator which you can rent from the FLAPS.
  22. Sep 7, 2025 at 6:11 AM
    des2mtn
    Shady Grove
    Tonto cover
    That's what I was getting at, a LAPs rental ball joint press like this. C-clamp and a big socket can accomplish the same thing if you have the room.
  23. Sep 7, 2025 at 6:57 AM
    des2mtn
    Shady Grove
    Tonto cover
  24. Sep 7, 2025 at 9:31 AM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    I like his videos, and that’s definitely worth a watch since he has some high level tips. But he’s skipping over a ton of stuff for the benefit of his target audience. It’s more an overview. I will say over the years the most annoying part of a variety of engines is the little tweak of how to tension the belt after it’s in place. It’s something you can easily screw up after hours and fatigue of getting to that point. His clarity there is helpful.
    There are a ton of more detailed ones like Timmy’s that are 10x more detailed.
    bing5[QUOTED] and G_unit3000 like this.
  25. Sep 7, 2025 at 11:59 AM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    I really hate how weak these studs are I feel like every time I rotate tires one of them breaks. I don’t use any power tools on them
  26. Sep 7, 2025 at 2:41 PM
    Weird. Mine are all original
    The Black Mamba and Chris948 like this.
  27. Sep 7, 2025 at 3:00 PM
    Changed the oil, oil filter, air filter, rotated the tires, and changed the transmission filter / pan with a drain and fill on the wife’s 2015 JGC. Also installed new sway bar links front and rear on the son’s Mustang. Full shop day.
  28. Sep 7, 2025 at 3:04 PM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    I was confused. I’ve never broken a lug in my life. But I’ve always bought vehicles from the south. Maybe his truck spent a few winters in Illinois?
  29. Sep 7, 2025 at 3:05 PM
    Negative. Mine has been a part of New England winters for the last 22 years and I still have all the original studs.
    bmf4069 and The Black Mamba like this.
  30. Sep 7, 2025 at 3:19 PM
    Chris948
    Chris948 New Member
    DFW
    2006 DC
    all I can say is you have my utmost respect. Every now and then I see a car that’s been up north and I run away.
