DIY: Map Light Switch Replacement
Discussion in 'Lighting' started by csuviper, Nov 24, 2015.
  1. Sep 21, 2023 at 3:21 PM
    ForceV4
    ForceV4 Pull my finger
    Sacramento
    2018 DC TRD 4x4
    8 years later and this thread is helpful. Replacing the old LEDs that were crapping out, I must have pushed the bulb receptacle thing up. Now I've got nothing on one side and can't really get the bulb in there. Do I have to yank the assembly to remedy this or can I ham fist it somehow from below?
    I pulled the assembly and it was easy. I bent back the brass or copper tabs but no joy. 3 different bulbs in each orientation and no luck. Suggestions on what to do next? A junkyard might be easier as I'm poor with electric stuff.
    Thanks.
  2. Sep 21, 2023 at 6:57 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Just read the thread from the start. You can buy the switch and replace it and it's very simple to do.
  3. Sep 23, 2023 at 8:14 PM
    ForceV4
    Sacramento
    2018 DC TRD 4x4
    Well, looks like I'm the first to f this all up somehow. Replacing the switch didn't do anything to fix it. Jumping the 2 middle wires didn't work, either. I guess the junkyard is my first stop on Monday. Time to put a jar of Vaseline in the truck now so I don't forget. :eek2:
  4. Aug 21, 2024 at 9:28 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    Looks like this thread may solve my issue. I went to change out my map bulbs to LED. One side works and the other side doesnt. Will remove the entire console and see what happened.
  5. Mar 7, 2025 at 12:56 PM
    cbrzrule
    cbrzrule New Member
    Bob
    2021 SR5
    Oh my god, you are a lifesaver! I did the same thing as you, and popped up the contacts above the bulb. I figured that out on my own, but without your post I never would have looked at replacing the switch.
    Ruggybuggy likes this.
  6. Jul 31, 2025 at 2:51 PM
    2011SR5
    2011SR5 New Member
    2011 Tundra SR5 double cab
    Where are the 6 screws?
    I see 2 in the front glasses case and 2 in the second but that’s all
  7. Sep 7, 2025 at 5:42 AM
    PogMoThoin
    PogMoThoin New Member
    Greg
    Howel New Jersey
    2018 Tundra Limited Double Cab
    I wish I saw this thread before I changed out the stock bulbs for the LED one. What is it with the passenger side switch causes it to go bad with changing to an LED light? The switch is $80 from Toyota, expensive bulb change. At least now I know why I couldn't get it to work.
    Apparently this is a less expensive option for the switch. Hopefullyy it works. I've found that electronic parts from Amazon can be a little sketchy.
    https://www.amazon.com/dp/B07GD4QJV1?ref=ppx_yo2ov_dt_b_fed_asin_title
  8. Sep 7, 2025 at 6:50 AM
    RitcheyRch
    Richard
    Star, Idaho
    I'm still using the LED bulbs in my maplights without an issue.
    PogMoThoin[QUOTED] likes this.
  9. Sep 7, 2025 at 9:29 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Go into you fuse box and change out the map light fuse to a smaller amp one. I think I have a 5amp one in mine. The problem only happens if you short out the terminals trying to put the LED bulb in. The weak link in the circuit is the map switch.
