Shortening boat trailer tongue
Discussion in 'Towing & Hauling' started by Outbound, Sep 6, 2025 at 4:38 PM.
  1. Sep 6, 2025 at 4:38 PM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Alright towing geniuses, any reason I shouldn't cut 17" off my boat trailer tongue so it fits in my garage without having to put the rig on an angle?
  2. Sep 6, 2025 at 4:46 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    You could also install a foldaway tongue kit. As an alternative.
  3. Sep 6, 2025 at 4:48 PM
    Outbound
    Aaron
    Northern Alberta
    Thought about that but my brake lines are rigid. I'd have to completely redo the brake system.
  4. Sep 6, 2025 at 4:57 PM
    2mchfun
    You will need to put more tow vehicle in the water at launch and load
    GODZILLA likes this.
  5. Sep 6, 2025 at 5:03 PM
    18" TRD Off Road Wheels
    Shorter tongue will make it more squirrelly. I wouldn't do it.
    How big is the trailer? Is it light enough to back it onto ramps? Might buy you a few inches the same way ramps in the bed when loading a 4 wheeler can get enough room to close the tailgate on a shorter bed.
    2mchfun likes this.
  6. Sep 6, 2025 at 5:07 PM
    Outbound
    Aaron
    Northern Alberta
    Meh. I haven't even needed to get my tires wet yet at this point. 17" won't make much difference.
    The boat is just under 1200lbs. I'm not putting this rig on ramps in the garage.
    Tunrod and Cpl_Punishment like this.
  7. Sep 6, 2025 at 5:11 PM
    2mchfun
    1200 Pound boat can be unloaded in the garage and the trailer can stay outside
  8. Sep 6, 2025 at 5:13 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Trade in for a folding tounge
  9. Sep 6, 2025 at 5:13 PM
    Outbound
    Aaron
    Northern Alberta
    Come show me how!
  10. Sep 6, 2025 at 5:15 PM
    Outbound
    Aaron
    Northern Alberta
    Thought about it, since I would like a dual axle trailer eventually but that's not in the cards right now. Cheaper to install a folding tongue. It appears that if I do that, I would need to install a piece of braided steel brake line. So it's possible, just more of a pain.
  11. Sep 6, 2025 at 5:28 PM
    2mchfun
    A rack with rollers and a winch, not too hard.
    Keep in mind, not all ramps are the same slope and lake levels vary. Just cause you haven't needed the length, doesn't mean you won't in the future. Carry on!
    Outbound[QUOTED][OP] likes this.
  12. Sep 6, 2025 at 6:19 PM
    Outbound
    Aaron
    Northern Alberta
    I need a bigger shop...
  13. Sep 6, 2025 at 6:30 PM
    Ericsopa
    Ericsopa Old man and the sea
    Also have to consider clearance on tight turns at some launch ramps.
    2mchfun likes this.
  14. Sep 6, 2025 at 6:30 PM
    This is the correct answer.
  15. Sep 6, 2025 at 6:37 PM
    Outbound
    Aaron
    Northern Alberta
    Fuck it, I may as well do this properly. I pulled the trigger on a Fulton swing tongue kit. Gonna have to get a braided brake line made up but it should work.
    blenton, GODZILLA, Ericsopa and 2 others like this.
  16. Sep 6, 2025 at 6:48 PM
    2mchfun
    You can get an electric over hydraulic actuator for surge brakes if you want to spend some more $$$ and get fancy.
    blenton likes this.
  17. Sep 6, 2025 at 6:53 PM
    Outbound
    Aaron
    Northern Alberta
    I'm not that fancy.
  18. Sep 6, 2025 at 7:06 PM
    blenton
    blenton New Member
    Good call. A friend of mine has a foldaway tongue for their wakeboard boat so that it fits in the garage. It works great. They use the boat often in the summertime. I think he spends even more time cleaning and detailing it after every outing which is the real reason that it needed to fit in the garage.. ha.
    I don’t recall what braking setup he has, though it is a tandem axle trailer and definitely has brakes.
