Shudder
Discussion in '1st Gen Tundras (2000-2006)' started by Zach_795, Jul 29, 2025.
  1. Aug 24, 2025 at 1:04 PM
    #91
    Zach_795
    Zach_795 [OP] Master Apprentice
    Virginia
    2002 4.7L Limited 4WD
    K&N Cold Air Intake PowerStop Z36 Extreme Performance Brakes, drilled and slotted, red calipers and drums Midland 75-822 CB w/ 3’ FireStik antenna JBA Silver Ceramic Shorty Headers BFGoodrich T/A KO2 LT265/65R17 tires 4Runner Sport 6 spoke 17” wheels Remote control exhaust cut-out Ruthenium spark plugs 12-hole injectors 20% tint all around 35% windshield Weathertech mats and window flares Grille guard with twin spot light bars, wired to high beams 2.5” RC lift front and back KSP Upper Control Arms Full led replacement 6000k Clear front turn signals, tailights, third brake cover
    Just ordered a Spicer bearing from Rockauto for 95 some dollars before shipping.
    Gonna leave the u-joints alone cause they haven’t been done too long ago.
    shifty` and joseph_womack like this.
  2. Sep 6, 2025 at 3:18 PM
    #92
    Zach_795
    Virginia
    Spicer “oem” bearing is literally a Toyota oem bearing.
    Made in Japan
    Toyota name and part number on the rubber part
    Steve4X42002 and joseph_womack like this.
  3. Sep 15, 2025 at 7:02 AM
    #93
    You are correct, Spicer is OEM for the carrier and driveshafts and several other parts on our Tundra. For those of us with stickers still intact, all the driveshafts are marked with Spicer stickers from the factory.
    However, that's not necessarily the best replacement for your truck that Spicer makes.
    Will your part fit? Yes, of course. But the above info is, to my knowledge, what most folks should be using.
    joseph_womack likes this.
