want to convert a 1st gen from 2wd to 4wd, any idea what im looking at? is it worth it
Discussion in '1st Gen Tundras (2000-2006)' started by longshot, Sep 6, 2025 at 2:39 PM.
  1. Sep 6, 2025 at 2:39 PM
    longshot
    longshot [OP] New Member
    Saturday
    2002 4x4 tundra
    none
    new to the forum. i have a 4x4 thats been well maintained but used for working. having trouble finding a decent 4x4, but have found a beautiful 2 wd. low miles, solid.
    if anyone has any detailed information about how to do this i'd appreciate it. my 4x4 parts trans, front axle or solid.
    thanks
  2. Sep 6, 2025 at 2:47 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    It’s a longshot…. but maybe
    BroHon and FrenchToasty like this.
  3. Sep 6, 2025 at 2:51 PM
    WV_21Tundra
    WV_21Tundra New Member
    21 Tundra SR5
    My gut reaction is keep looking. Things to consider, nothing personal but what kind of wrench are you skills wise, doing it on the ground, in a garage? Is time a factor. Can you just drop the 2wd body on the 4x4 frame?
  4. Sep 6, 2025 at 2:56 PM
  5. Sep 6, 2025 at 7:43 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    OP, I can't seem to figure out the "search" feature either. Maybe I'm more like Han and less like Luke.
    Threads on here where people have done it but will depend on your skills, available tools, garage space, etc.
  6. Sep 7, 2025 at 2:05 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  7. Sep 7, 2025 at 8:35 AM
    BoiseG
    BoiseG New Member
    2001 Black SR5 4x4
    Seriously question the cost effectiveness of such a task.
  8. Sep 7, 2025 at 8:41 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Probably a lot easier to throw in a rear locker, make sure you have good clearance, tires, etc. and the truck will probably out perform most people's driving capabilities...
    However, if you're wanting 4wd, I'd just find a 4wd vehicle and call it good :notsure:
  9. Sep 7, 2025 at 9:02 AM
    The components are practically plug and play. Read the prior members who did its posts. Just need a good frame rotted or locked up 4.7 donor.
  10. Sep 7, 2025 at 9:11 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  11. Sep 8, 2025 at 4:47 AM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    You have a donor? Just LEGO the best parts from the 2wd into the 4wd, done.
    KNABORES likes this.
  12. Sep 8, 2025 at 6:44 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    My two cents: if you have to ask for a complete how-to for something like this, it's not something you should do. You're going to have a bad time on here if you ask for stuff like that.
    If you can research the bulk of this on your own and ask detailed questions about certain parts of the process, you'll have a much better time. This swap is totally doable if you can undertake that mentality.
