General Supercharger Thread
  1. Sep 3, 2025 at 7:21 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I definitely lost some of everything in the valley but I used fuel hose with a magnet glued in and was able to retrieve...the valley is a true abyss!
  2. Sep 3, 2025 at 7:34 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    What about due to weather? Would seem like the larger temperature delta in the winter would cause more condensation in the engine. At this point I don't even check my catch can because there's such a trivial amount in it. On the two built engines I have, during break in and the first 100 miles or so they would fill the catch can almost to the brim with a couple dozen miles, but once sealed up they catch as much as the Tundra does.
  3. Sep 3, 2025 at 7:45 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Speaking of the catch can, what is the best routing?
    mustang67408 and ARES35 like this.
  4. Sep 3, 2025 at 8:14 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Heard back from Whipple. I'll have the missing pieces/decals tomorrow or the next
    They asked for the label on the bag of the missing parts in a separate email. Wonder if someone's getting chewed
  5. Sep 4, 2025 at 5:31 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Did mine earlier this year and dropped the old one as soon as I unthreaded it. Turned a 10 minute job into an hour. Only thing that got it out was a small rubber hose hooked up to a vacuum.
  6. Sep 4, 2025 at 6:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    should i be adding a PCV valve to my to-do list before the whipple install? Y'all are scaring me.
    I'm about at 40k miles.
    Tripleconpanna and HulkSmurf14 like this.
  7. Sep 4, 2025 at 6:32 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Might as well while it’s apart. Cheap insurance
  8. Sep 4, 2025 at 6:43 AM
    Danimal86
    Daniel
    Sacramento, CA
    is this the correct PN?
    12204-38030
    Anyone know if any of these are the OEM mfg?
  9. Sep 4, 2025 at 7:21 AM
    bflooks
    bflooks New Member
    Metrowest MA
    that part number matches what I got for my 2019. Toyota part was ~$7.50 from Fred Anderson.
  10. Sep 4, 2025 at 7:44 AM
    blenton
    blenton New Member
    That’s what I’ve got.
  11. Sep 4, 2025 at 9:10 AM
    e30cabrio
    Apparently it is possible to get real parts from Amazon. I gambled as it's not a big deal if it had to go back.
    Hoping this is the end of my evap codes.
    Tripleconpanna, Jego, ARES35 and 2 others like this.
  12. Sep 5, 2025 at 7:59 AM
    nags
    nags New Member
    Hopefully, cause someone is fucking up left and right over there.
    Wynnded, Tripleconpanna and e30cabrio like this.
  13. Sep 5, 2025 at 8:10 AM
    Danimal86
    Daniel
    Sacramento, CA
    Yup!
    Got a box yesterday with the missing 3 decals and 1 loose step spacer.
    Were you missing the same thing also?
  14. Sep 5, 2025 at 8:38 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :monocle:
    The bag is real, but the item inside is probably fake news... :D
    e30cabrio[QUOTED], Mdl and blenton like this.
  15. Sep 5, 2025 at 10:35 AM
    nags
    nags New Member
    We were missing the injectors and a few other things as well as the heat exchanger was damaged within the box but the box itself had no damage.
    Danimal86[QUOTED] and Mdl like this.
  16. Sep 5, 2025 at 8:33 PM
    Danimal86
    Daniel
    Sacramento, CA
    So I'm thinking of taking some time off next week and doing the install. I had my dad lined up to give me a hand, but its looking like he might get tied up until later in the week.
    This doable as a solo mission? I don't have a lift or a cherry picker, but have 2 floor jacks for the tank
  17. Sep 5, 2025 at 8:45 PM
    snivilous
    SW UT
    Definitely. Lifting the blower into the engine bay is a bitch but maybe you're more jacked than me. Can definitely do it yourself, I would expect 16-20 hours. If you have three full days to focus on it you should be golden if you're just doing the blower and pump.
    ARES35, e30cabrio, Fastlane47 and 4 others like this.
  18. Sep 5, 2025 at 9:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Definitely diable by yourself as stated. My friend had to bail who was going to help with my trans install. My 74 year young mom was gracious enough to hold the crank pulley while I torqued the torque converter to flywheel. I was going to take a pic but that was a "NO"!
    ARES35, e30cabrio, Fastlane47 and 7 others like this.
  19. Sep 5, 2025 at 9:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Did all mine alone not bad at all blowers heavy but yea few days for sure taking my time.
    ARES35, e30cabrio, Fastlane47 and 2 others like this.
  20. Sep 5, 2025 at 11:36 PM
    blenton
    blenton New Member
    I wimped out and had the dealer install mine (mostly due to some time constraints, but I really did wimp out). They also charge what I thought was a very reasonable price; about $1000 cheaper than the local Magnusson recommended installer.
    But now that I’ve had to pull it and take the motor down to the timing chain tensioner, I see everything that needed to be done to install the blower originally except for the fuel pump. And I will have to reinstall it all. I would agree with @snivilous and @reywcms and say it’s doable solo if you have some good basic wrenching ability. Take your time and follow the instructions and you should be fine. It would be nice to have an extra set of hands for placing the blower but I was able to heft it off by myself and will most likely be hefting it back on by myself as well.
    ARES35, e30cabrio and reywcms like this.
  21. Sep 6, 2025 at 5:19 AM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    Easily possible. The blower is heavy though. I put a piece of wood across the motor and lifted the blower up and onto it. Then I rigged up a pulley from the ceiling of my shop and made a sling for the blower and used it to pick up the blower. Then swung it back over the motor and with my wife's help was able to get it lined up and set on the motor. Easy.
    ARES35, Mdl, e30cabrio and 1 other person like this.
  22. Sep 6, 2025 at 7:28 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    24 TRD Pro
    Just take the body off the frame, easy access to everything. Lol. PXL_20240105_171625444.jpg
  23. Sep 6, 2025 at 9:29 AM
    Danimal86
    Daniel
    Sacramento, CA
    Thanks everyone for the advice. My wife is gone for work tues-friday, so i'm batching it....seems like the perfect time. Plus here the weather is going to be perfect (low/mid 80's).
    I'm kinda thinking about starting by myself and when i get to the blower install part, i'll try to grab a second set of hands from a neighbor or try to get my dad to swing by for an hour or 2 to help set the blower. I thought about buying a cherry picker, but probably not worth it for one time use.
    Lifting the blower gonna be the worst part? I think i'm a little more worried about dropping the tank that just being able to heave the blower up.
    @snivilous I'm not jacked....more like a grizzly bear....there's a good amount of muscle under the fluff and fur. lol
    My truck wont fit in the garage and be able to close the door, so i'm thinking that i'll probably be doing it in the driveway. I've seen people do this before (with a lift) where they remove the front tires, and lower it down onto jack stands to bring the front of the truck lower. I'd have to leave it like that until i'm done with the install. My driveway has a bit of a slope to it, but nothing crazy. Think its worth doing that, or i'd be fine with doing the install at normal
    I've got a lot of tools i've accumulated over the last 20 years, so i've got pretty much everythign i can think of covered (general diy, not really mechanics specific tools). Any specialty tools that i should be ordering?
  24. Sep 6, 2025 at 9:50 AM
    e30cabrio
    Slim sockets & U joints both in 1/4" for tight spaces bolting the SC on were instrumental for me.
  25. Sep 6, 2025 at 10:32 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
  26. Sep 6, 2025 at 12:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    And electrical connection plier set. Save your knuckles!
    ARES35 and e30cabrio like this.
  27. Sep 6, 2025 at 12:24 PM
    e30cabrio
  28. Sep 6, 2025 at 3:15 PM
    Danimal86
    Daniel
    Sacramento, CA
    Any preferred ones?
  29. Sep 6, 2025 at 3:50 PM
    Danimal86
    Daniel
    Sacramento, CA
  30. Sep 6, 2025 at 5:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
