1,500 miles and truck kicked up rock causing this
Discussion in '3rd Gen Tundras (2022+)' started by KrypticZer0, Sep 5, 2025.
  1. Sep 5, 2025 at 8:16 PM
    KrypticZer0
    KrypticZer0 [OP] New Member
    2025 Lunar Rock SR5 offroad
    Truck has 1,500 miles it’s a 2025 lunar rock off road. Taking family on first camping trip with it and a semi kicked up a rock and took the paint down to bare metal on the hood and dented it. I’ve been running through a couple options. Get it repaired through a shop or touch up paint and put a bug deflector shield on like the one attached and worry about it down the road??
  2. Sep 5, 2025 at 9:05 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That sucks man I’m sorry to see that.
  3. Sep 5, 2025 at 9:22 PM
    PNW-YODA
    PNW-YODA New Member
    2023 capstone
    Go the paintless dent repair route
    You will be super happy
    been doing it across 5 tundras over 20 plus years
    Google pdr in your area
  4. Sep 6, 2025 at 6:42 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    OP said the rock knocked the paint off to bare metal, so a PDR probably isn't what he's looking for.
    If it were mine, I'd probably stick some touch up paint on it to prevent rust, then cover it up with a bug shield.
    I actually like the looks of that WeatherTech shield. I might have to pick one those up myself.
  5. Sep 6, 2025 at 7:04 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I agree with paintless dent repair first then OEM touchup paint for remaining mark where there is a chip in paint.
    WILLINH, KNABORES and szabo101 like this.
  6. Sep 6, 2025 at 7:09 AM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Travel all over the country and gone this exact route (pun) several times. Always very pleased with outcome.
  7. Sep 6, 2025 at 7:22 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Do you guys have any tips for using the touch up paint? I've never achieved results that I was happy with. Maybe I'm too picky.
  8. Sep 6, 2025 at 7:33 AM
    Touch up paint requires a couple applications to build in the area that is missing paint. Then a “cut” back down to level. Then a polish to blend. Not easy to make it look good for the DIYer. Most just glob some on to cover the unpainted scratch or ding.
    Edit: really what I’m describing is paint correction, not just touching up though.
    Matt2015Tundra likes this.
  9. Sep 6, 2025 at 7:40 AM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    Man, I think I would get a quote from a body shop.
  10. Sep 6, 2025 at 8:10 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks, it's the "cut back to level" that I seem to struggle with. I either get a noticeable recessed area with too little paint, or a noticeable bump that usually chips off again. I can never get a perfectly flush finish.
    Do you prefer the magic marker, small brush, or ball point pen style? Or does it depend on the size of the chip?
  11. Sep 6, 2025 at 8:18 AM
    lapoolboy
    lapoolboy New Member
    Dr. Colorchip kit with the squeegee will give you the best DIY results.
    shawn474 and Matt2015Tundra like this.
  12. Sep 6, 2025 at 8:43 AM
    I prefer to put a drop of paint in a chip vs trying to paint or brush it. Not a big glob. The smallest drop that will flatten out and cover it.
  13. Sep 6, 2025 at 8:51 AM
    Matt2015Tundra
    2023 1794 CrewMax
    I notice their order page has this caveat about my Wind Chill Pearl paint.
    Wind Chill Pearl Tricoat 089
    Your vehicle has a tri-coat / 3-stage color, meaning it was painted with a base coat, pearl coat and a tinted clear coat. Our paint is a single stage formula that does not include the pearl. There is not a single stage formula that matches exactly. However, the paint you receive should allow for a close color match and yield far better results than using regular touch-up paint. Please check the box to acknowledge this.
    Apparently, OEM touchup for 089 comes in 2 bottles. One is the base coat and the other is a top coat that has the pearl in it. I'll probably give the OEM a try. It sounds like a better match.
  14. Sep 6, 2025 at 9:05 AM
    Matt2015Tundra
    2023 1794 CrewMax
    How does that work on a vertical surface? Doesn't the drop settle to the bottom of the chip?
    The chip I want to repair is about the size of a finger nail on the corner of my front bumper. I have a small air brush that I'm pretty handy with. I might try using it with the 2-part OEM touch up paint. I'm hoping I can "feather" it in to look respectable.
  15. Sep 6, 2025 at 9:34 AM
    It wouldn’t if the touch up paint is very thin.
  16. Sep 6, 2025 at 9:58 AM
    lapoolboy
    You'll be wasting your time and money with the OEM 2-stage. I've had several pearl white trucks and the Dr. Colorchip lays right in there nice and level with the squeegee. The match was always close enough at a couple feet even I had a hard time zeroing-in on the spot.
    KNABORES likes this.
  17. Sep 6, 2025 at 10:00 AM
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    When I brought my truck in a couple weeks ago for Toyota to fix the scratches they made, the guy at the front saw a scratch that I made and tried to cover up with paint pen that if I just add more to it and then wait for it to dry I can put blue tape around as close to the scratch as possible and just buff it out that most of it would come out looking better. Haven’t done it yet
  18. Sep 6, 2025 at 1:19 PM
    Matt2015Tundra
    2023 1794 CrewMax
    But did your trucks have the multiple color flecks that are in Toyota's new Wind Chill Pearl? I've had plenty of white trucks too, but this paint is a whole new animal.
    I do like the Dr. Colorchip concept, but I'm not confident it's going to match the WCP on my truck, especially for the fairly large chip I need to repair. If my airbrush idea, using the OEM 2-part touchup paint doesn't work, I'll give Dr. Colorchip a shot.
    Or, I'll just live with the chip. It's a truck, not a Ferrari, after all.
  19. Sep 6, 2025 at 1:29 PM
    lapoolboy
  20. Sep 6, 2025 at 2:53 PM
    KrypticZer0
    I really appreciate all the insight from all of you! I am getting a quote Monday for the PDR and if it’s higher than what I can afford right now then I’ll go with my original plan. If it’s reasonable then I’ll just go that route.
    lapoolboy likes this.
  21. Sep 6, 2025 at 10:38 PM
    PNW-YODA
    PNW-YODA New Member
    2023 capstone
    Also
    Google same day paint repair
    They also do pdr
    some ass clown razor knifed my last truck
    They use an air brush and can make your fix like factory
    Tundrastruck91 likes this.
  22. Sep 6, 2025 at 11:04 PM
    Hank Hill
    Hank Hill New Member
    Are there any special considerations when working with aluminum panels, or can a skilled PDR technician repair aluminum just as effectively as steel?
  23. Sep 7, 2025 at 4:10 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    I've repaired a chip and a small scratch on my blueprint. I used the kits that come with the applicators and different grits for wet sand which saves me a trip to the hardware store. The good news on the Tundra is that there is enough material to work with if you're comfortable with color sanding.
  24. Sep 7, 2025 at 9:22 AM
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    I used Dr. colorchip on my lunar rock recently.
    Went to the beach this summer and someone scratched my rear passenger door. It was about an inch long scratch to bare metal unfortunately.
    All the quotes I got were outrageous so I tried their squirt n’ squeegee kit. Watched some videos before and tried it. It was amazing like others say - couldn’t see it from about a foot away. I had to make about 5 applications before it was close to level. Mine was on a vertical surface with it being the door and it worked great!
