ECU-IG No. 1 Fuse Troubleshooting Advice
Discussion in '2nd Gen Tundras (2007-2013)' started by ddd4114, Jul 21, 2024.
  1. Jul 21, 2024 at 7:26 PM
    ddd4114
    ddd4114 [OP] New Member
    I have a 2010 5.7L Tundra that I've just been using as a tow vehicle, and I haven't had a chance to do anything that would require it for the last 10 months. During that time, I only went into it once about 3 months ago, and at that time the battery was pretty much dead. Otherwise, it has been sitting in my driveway. I know I should still be driving it every so often even though I don't "need" it, but... unfortunately it's too late for that. Before letting the car sit, I drove it monthly and never had any problems with it.
    Now that I want to use it again, I replaced the battery, and now it keeps blowing the ECU-IG No. 1 fuse as soon as I turn the key.
    The symptoms are:
    • The stability control, ABS, SRS, TMPS, and brake (with the parking brake off) lights are all on. The 4LO/4HI lights are constantly flashing.
    • The climate-control system and related features won't turn on
    • The shifter will not go out of Park
    • Simply turning the key on without starting the engine blows the fuse pretty much immediately
    What still seems to work is:
    • The engine starts and runs fine
    • There are no active or pending DTC's, even after running the engine for a few minutes
    • All lights (headlights, turn signals, brake lights, etc.) work
    • The clock, radio, and power mirrors work
    • The instrument cluster and all gauges work
    • I can turn cruise control on, but obviously I can't test it without driving
    I started looking through wiring diagrams to see what the ECU-IG No. 1 fuse feeds, and I counted about 3 billion circuits. I might be slightly off with that number, but I think it's pretty close. Annoyingly, they all seem to be in parallel, which makes the culprit difficult to identify.
    Are there any common issues I should investigate first, especially related to a dead or recently replaced battery? Any tips for narrowing down what might be causing the short? While I have a lot of automotive experience, I'm guessing this could take hours or maybe days to troubleshoot due to the sheer number of circuits downstream of that fuse. Therefore, any advice is appreciated.
    Thanks in advance.
    bigc76036 and Pxpioneer like this.
  2. Jul 24, 2024 at 11:25 AM
    ddd4114
    After some troubleshooting, I found the steering wheel angle sensor is causing the short. After unplugging it and replacing the ECU-IG No. 1 fuse, everything is working again (besides the systems that require that sensor).
    I found one other thread saying that melted wires going to the sensor are a "common issue". From what I can see, the wires going to mine are fine. Does anyone know what might cause a short like this? I'd hate to replace the sensor just for this to happen again.
  3. Sep 25, 2024 at 4:05 PM
    Pxpioneer
    Pxpioneer New Member
    2007 Tundra Limited
    Having the same issues. I removed an aftermarket (dealer added) car alarm thing. Karr Security, the problems started around then, but could be coincidence. I'll take a look at this but my fuse isn't blown with the same symptoms, except I cannot use the stereo and my climate control doesn't work at all. I have an 07 Crewmax Limited.
    Interested to see if you found anything else.
  4. Sep 25, 2024 at 6:52 PM
    ddd4114
    For me, everything worked fine after I replaced the steering angle sensor. I took it apart to look for obvious issues, but I didn't see anything. I have no idea what caused the short.
  5. Jul 3, 2025 at 1:31 PM
    rchong
    rchong New Member
    I just wanted to thank OP for the post. I had the same thing happened to my 2009 Tundra last week, replaced the steering angle sensor with an OEM unit from Toyota and that solved the problem.
  6. Sep 5, 2025 at 8:02 AM
    bigc76036
    bigc76036 New Member
    Thank you for this post, OP!! I wish I'd given this a shot. I'd been dealing with a blown ECU IG No1 fuse on my 2013 Tundra and tried everything I could think of - removed the aftermarket viper and auto start.. checked everything on the ECU IG circuit except the steering angle sensor, smh.. after spending 5 days of troubleshooting, I took it to 2 mechanics. Both said they spent hours trying to locate the short, but could not. The 3rd mechanic shop spent a day troubleshooting and called me with the results. Said the steering angle sensor was causing my fuse to blow... 1100 labor plus part.. not upset about the cost.. even told the mechanic I saw your post on the forum. They said this was a fun one to troubleshoot. This post deserves an award... Thank you!!
    Main Loads on ECU-IG No.1
    • Engine Control Module (ECM/ECU)
    • Air Conditioning Amplifier (A/C control)
    • Combination Meter (instrument cluster)
    • Shift Lock Control ECU (shifter solenoid/ECU)
    • Four Wheel Drive Control ECU (if 4x4 equipped)
    • Steering Angle Sensor / Spiral Cable assembly (via CAN link and power feed) - the problem on my truck...
    • ABS/VSC/TRAC ECU
    • Immobilizer / Certification ECU (if equipped with smart key)
    • Transmission Control (part of ECM or separate on some models)
