RBP ALL TERRAINS at 25lbs?! LT295/70r18
Discussion in '3rd Gen Tundras (2022+)' started by Tony.ga, Sep 4, 2025 at 11:40 AM.
  1. Sep 4, 2025 at 11:40 AM
    Tony.ga
    Tony.ga [OP] New Member
    FL
    23 LIMITED SMOKED MESQUITE
    So I'm looking at new tires, for a new set of wheels I got for my '23 and I see that RBP has a new all-terrain tire, the Repulsor A/T Plateau. Apparently, this tire only weighs 25lbs. How is this possible in a 10ply load range E tire? When their Repulsor R/T weighs in at 69lbs??
    Is the tire being this light a bad thing or an indicator of lower quality?
  2. Sep 4, 2025 at 11:58 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  3. Sep 4, 2025 at 12:12 PM
    Tony.ga
    FL
    While that would make sense because it would push the weight to 56lbs . Their other tires are listed in lbs not kgs on their tire charts.
    Maybe just an error on their end
  4. Sep 4, 2025 at 12:36 PM
    blenton
    blenton New Member
    This. A lightweight stock p rated 32” tire is ~40lbs.
