2012 Tundra ECU problems
Discussion in '2nd Gen Tundras (2007-2013)' started by Hondaguy, Aug 25, 2025.
  1. Aug 25, 2025 at 8:23 PM
    Hondaguy
    Hondaguy [OP] New Member
    Looking for some help with my 2012 Tundra, I replaced the ECU to try and fix my 4wd problem, got a pre programmed one from flagship, plugged it in, used their OBD2 port tool to reset and did their procedure, now it cranks, won’t start, and the old ECU cranks, won’t start it either, I cannot hear the fuel pump cycling either, anyone have any experience with this? Thanks
  2. Aug 25, 2025 at 8:48 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Did the process include registering the keys?
  3. Aug 26, 2025 at 6:30 AM
    Hondaguy
    No, it did not, is this something that I need to do?
  4. Aug 26, 2025 at 7:47 AM
    e30cabrio
    When I swapped my ECU I had to register the keys. Mine came from eBay. So there was no company with a process involved.
    I looked at their site. Did you give them your VIN?
    Do they say no key registration is needed?
    I had not heard of them before.
  5. Aug 26, 2025 at 9:14 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Getting Techstream on your laptop and syncing the ecu to the keys to the third other ecu (name escapes me) may be a good path forward. All three have to have the same vin number and is likely what is causing no fuel (essentially truck thinks you have the wrong key).
    e30cabrio likes this.
  6. Aug 26, 2025 at 9:17 AM
    e30cabrio
    I got a new key yesterday, during registration I got a unregistered key code. Maybe you can see if you have that code.
  7. Aug 26, 2025 at 12:21 PM
    Hondaguy
    I have them my VIN, and in my conversation with their rep on the phone, they stated that this would Pete a “ Plug and play” , that nothing else was needed lol. I’ve heard about bootleg techstream thats available, and inexpensive connectors, anyone know anything about those, I’m thinking I’m going to need to see what’s actually going on
  8. Aug 26, 2025 at 2:00 PM
    e30cabrio
    I'd call them & get them to figure it out.
  9. Aug 26, 2025 at 2:23 PM
    Hondaguy
    Did that, they are trying to figure it out, just not confident in their staff at this point lol, so I thought I’d throw it out to the real world people
  10. Aug 26, 2025 at 2:30 PM
    e30cabrio
    What is the original issue that made you seek a new ecu?
  11. Aug 26, 2025 at 9:55 PM
    Hondaguy
    Long story, 4x4 quit working about 2years ago, stuck in 4whl hi, Toyota diagnosed bad Transfer case actuator, pulled it apart, it looked and worked great, so did the front axle actuator, I replaced all of them with new Toyota Actuators( Hi, Lo, front differential,. It still did the same thing, would go into 4x4/high, but not come out. Replaced the dash switch, and the 4x4 controller, and tried moving the timing on the actuator about 20 different positions, still no luck. Talked to an old friend who is a Lexus master technician for the last 30 years, he he had no clue( I was a Honda Master tech for 19 years up until 2005, then entered a career in the Fire service) I checked every ground, fuse, relay, so the ECU was the only component left lol
  12. Aug 27, 2025 at 10:30 PM
    zeekevin
    zeekevin New Member
    Sounds like a immo issue. Is there a red key light flashing on the dash? Or by the clock
    bicklebok likes this.
  13. Sep 2, 2025 at 12:00 PM
    Hondaguy
  14. Sep 2, 2025 at 12:50 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    I used flagship one for an ECU swap for a 2004 4runner (also has a key-based immobilizer). I did NOT need to do anything with programming keys. The installation was as you describe (follow their instructions). The OBDII dongle connects two pins, and the step where it sits for a while the dash lights were blinking/flashing a lot. I needed to do a zero-point calibration afterward to clear ABS, traction control, and 4WD lights if I remember correctly.
  15. Sep 2, 2025 at 3:16 PM
    2mchfun
    @Jeff_5_7 might be able to shed some light on this subject for you if he is still around. Anybody home?
