1st Gen SPEED GOVERNOR?
Discussion in '1st Gen Tundras (2000-2006)' started by Desertrockmtn, Sep 2, 2025.
  1. Sep 2, 2025 at 12:14 PM
    Desertrockmtn
    Desertrockmtn [OP] New Member
    Kyle
    2001 Toyota Tundra Limited 4x4
    IMG_2471.jpg Hey y’all, so I’m new to a 2001 tundra 4.7 limited. I was on the freeway this weekend testing a different set of wheels to eliminate some vibration. Anyhow, as I was testing, it felt like I hit a series of gusts of wind head on. The thing just quit on me at 95-97 MPH at around 3200 rpm. So I’ve been researching and it sounds like a speed limiter? But everyone says it should be 105 or 110. Is there a way to disable the speed limiter?
    Thanks
  2. Sep 2, 2025 at 12:17 PM
    You shouldn't have one that limits it below 110 mph as I know I've been able to do that on the interstate at 3 am and mine's an 02.
    Desertrockmtn[OP] likes this.
  3. Sep 2, 2025 at 12:43 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Looks like bigger than stock tires. Check the speed rating on them because they might not even be rated for 110mph. With bigger than stock tires and no other adjustments, you'll hit the govenor sooner. Your speedo is likely off as well, so I would check how fast you're going with a GPS app.
  4. Sep 2, 2025 at 12:44 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    What size tires you on?
  5. Sep 2, 2025 at 12:46 PM
    Desertrockmtn
    Kyle
    These are 265/75/r16
  6. Sep 2, 2025 at 12:49 PM
    Desertrockmtn
    Kyle
    It’s wild because I’ve hit 105 in my little Tacoma and this tundra has a lot more to go but is restricted. Anyone figure
    265/75/r16
  7. Sep 2, 2025 at 12:53 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    So you're an inch taller than stock tires. There's your reason your speedo is off by 3.3% and why the governor is kicking on in a way perceived as early.
    My 03 is on stock tires, but I regeared the rear diff from 3.91 to 4.10, so my governor also comes on when the speedo reads like 95 or 100.
  8. Sep 2, 2025 at 1:00 PM
    2mchfun
    I don't think the computer knows your tire size has changed. You should be able to go above limited speed with larger tires. That said, I highly suggest staying within the rating of the tires, so adjust accordingly.
  9. Sep 2, 2025 at 1:02 PM
    Desertrockmtn
    Kyle
    Wouldn’t larger tires make the limiter kick on later?
  10. Sep 2, 2025 at 1:10 PM
    Desertrockmtn
    Kyle
    Did you install a Limited Slip?
  11. Sep 2, 2025 at 1:24 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Yes
  12. Sep 2, 2025 at 1:53 PM
    StrawberryBlowpopPrincess
    StrawberryBlowpopPrincess New Member
    2002 sequoia RWD
    Is there anyway to remove the speed limiter in these things?
    M14 EBR and Desertrockmtn[OP] like this.
  13. Sep 2, 2025 at 2:04 PM
    You usually need an ECU tuner for that and even if you did, you’d want to make sure you’re running the correct speed rated tires at a minimum.
  14. Sep 2, 2025 at 2:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Unfortunately, I don't believe the VF Tuner is able to tune 00-02 ECUs yet. But maybe they updated it recently.
    I know I had a time trying to get my 03 tuned, because my particular calibration ID wasn't supported yet.
  15. Sep 2, 2025 at 2:19 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I didnt think there was a limiter. I’ve been 108ish before i gave up. And i dont like taking it over 100 with the cap on.
  16. Sep 2, 2025 at 2:19 PM
    Desertrockmtn
    Kyle
    Just messaged Underdog Racing, they make one but for same year Toyotas but have not tested/ checked to see if it works with the 4.7 2UZFE
    I may just have to be the guinea pig
