So ... you wanna buy / just bought a 1st Gen Tundra, eh?
Discussion in '1st Gen Tundras (2000-2006)' started by shifty`, Nov 14, 2022.
  1. Jul 16, 2025 at 2:41 PM
    #241
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra New Member
    Eric
    Looking for my future 1st Gen Tundra
    I watched this...... I could be wrong, but I thought the guy whose truck it is, was selling it/did sell it.....
  2. Jul 17, 2025 at 5:08 AM
    #242
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
  3. Aug 12, 2025 at 7:54 PM
    #243
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    I suggest you let this cook in the thread you already posted instead of posting here as well.
    Additionally there is lots of info on springs in the very first post in this thread. See: "Guidance to pick the right lifted spring w/Bilstein 5100/4600"
  4. Sep 2, 2025 at 3:18 AM
    #244
    Dividers
    Dividers New Member
    Thinking about buying a 1GT….
    First of all this post is great. Definitely a valuable tool to use over and over.
    My question is about frame upkeep. I will do my due diligence with the frame of whatever truck I buy. But my concern is how to keep a clean frame, clean. I live in NY. What do you rust belt owners do to keep your frames clean? Are there good/necessary treatments or is it just a matter of hosing it down as often as possible?
  5. Sep 2, 2025 at 5:37 AM
    #245
    shifty` [OP] Earth acid cleanses me, cleanses me clean
    The tl;dr on this one from what I've read from rust belt folks over the years, to save you some searching:
    • Avoid driving salty roads as much as possible
    • Coat annually with a product like woolwax before salting begins
    • Rinse undercarriage regularly during winter
    The reality is, if you drive on salty roads, anything you do is simply delaying the inevitable rot and failure that's bound to happen.
  6. Sep 2, 2025 at 7:58 AM
    #246
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    The simplest option I've found is to just have a different vehicle to drive in the winter months. My truck hasn't seen salt since frame replacement in 2021. Otherwise yeah, you're just going to delay the inevitable, fluid film helps.
    shifty`[OP] likes this.
