  1. Aug 30, 2025 at 7:43 AM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    I'm not a big believer in that stuff creeping into threads very far. IMO I wouldn't worry about contamination, it would be so miniscule "I" wouldn't worry. BUT, I'd be careful with how it may react with the foam insulation more than anything. Impact is the way.
    woods[QUOTED], JMB and TaquitoBandito like this.
  2. Aug 30, 2025 at 2:18 PM
    Didn't even think to take pics 'til after buttoning it up and POST'ing it to verify all was OK, but every 3-4 year battery pack rebuild for the data closet battery backup today. I guess $40 every 3-4 years is better than having to buy a new one. One of these days I should probably migrate to a rack-mount unit. This thing has a really f'n annoying setup where the batteries sit "69" to each other with a shim, and one side is damn near impossible to plug in. Pisses me off every time.
    oddhours, woods, Fotnot and 2 others like this.
  3. Aug 30, 2025 at 3:06 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Y'all convinced me to apply pneumatic power to my water heater. I'll report back tomorrow if you need to come help me replace it.
    T-Rex266, OldGuy03, oddhours and 6 others like this.
  4. Aug 30, 2025 at 3:37 PM
    TaquitoBandito
    Joel (AKA Bif)
    I think it was originally @T-Rex266 ’s idea… I was all for you returning it and waiting for your water heater to shit out on you.
    T-Rex266, OldGuy03, oddhours and 4 others like this.
  5. Aug 30, 2025 at 3:43 PM
  6. Aug 30, 2025 at 3:55 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I finally replaced my old white APC that looked like that after about 12-14 years, it could no longer keep thing on at the start of an outage, even after new batteries.
    Costco was clearing out some Cyberpower 1350va units for $100 a few months ago, so I grabbed one.
    I have a 1500 and the 1350 powering my 2 computers, monitors, security camera DVR, and network gear. the computers will power off after 5 minutes, so i will have another 30+ minutes of the network still up.
  7. Aug 30, 2025 at 4:13 PM
    This is the unit I usually install at customer sites: https://www.amazon.com/dp/B0016P7HJA
    It'll usually keep a 24-48 port POE switch, UDM gateway, a couple APs and a dozen POE cameras up for around an hour. Really makes the APC BX1500 pictured look like a slouch.
    EDIT: They also have a much more affordable 500VA version that will keep 100W of stuff up (IIRC) 15-20 mins: https://www.amazon.com/dp/B000XJJN60/
    woods likes this.
  8. Aug 30, 2025 at 7:22 PM
    Cfincke
    San Antonio
    If you have room for a 2U UPS, maybe look at this unit with pure sine wave instead of simulated sine wave. comes in cheaper and has the same battery capacity using 2 12V 9AH instead of 4 6V 9AH batteries. does have a shorter cord.
    https://www.amazon.com/CyberPower-CP1500PFCRM2U-Sinewave-Outlets-Rackmount/dp/B0B354X985?th=1
    shifty`[QUOTED] likes this.
  9. Aug 30, 2025 at 8:41 PM
    JMB
    Chesapeake, VA
    I think he recommended a breaker bar, which would have been the same as what I already did.
    I'll put a 100 psi of pneumatic goodness on it tomorrow. Either it works or I replace my water heater tomorrow.
    Either way, it gives me something to do.
    T-Rex266, oddhours, woods and 3 others like this.
  10. Aug 30, 2025 at 8:56 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I'm sure you will have complete victory over the dreaded nut. :thumbsup: How long has the anode been in your tank? We here are anxiously waiting to see what it looks like, because that's what we do here. :)
  11. Aug 31, 2025 at 4:12 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Wife and I's anniversary is in about two weeks. Decided instead of getting the traditional gifts, to replace our washer and dryer. While they still work, we have hated them for the entire 7-8 years we've owned them. Washer can't balance itself to save its life. The dryer has to run 2 full cycles on the highest heat to dry a load of towels. Just non of it performs anywhere close to what we expected. They are whirlpool made in USA models that were not cheap when we bought them, both have broken multiple times.
    So it might not be romantic, but both of us are super excited. Replacements will be speed queen 5 series. We almost went for the front load 7 series fancy pants ones, but the motivator there was fitting a king sized blanket, and I realized if I just get a new blanket, it could save us 2-3k in machine costs AND I could get the simple made 5 series that we both wanted. No screens, no energy star, just good ol' mechanical washing power! Local company has a pretty big sale going on right now so the timing was just adding up and we went for it. So in two weeks I'll know if they are as good as people say, or if its just hype!:fingerscrossed:
    Trooper2, NWPirate, ATV25 and 3 others like this.
  12. Aug 31, 2025 at 5:28 AM
    Sadly, a lot of times I’m installing 4U or 6U racks, so space is at a premium. Depth is an issue too because the 2U are typically deeper than the rack (shorter-U racks I prefer with top/bottom brace often max out around 13-14”). Else I’d love to go with the 2U units. I can only consider those when using a larger framed adjustable rack 8U+, assuming mounting dept of the rack space allows.
    Cfincke[QUOTED] likes this.
  13. Aug 31, 2025 at 6:50 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what does something like you had built cost if you don't mind ? also size ?
  14. Aug 31, 2025 at 8:36 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I don't mind. I'm ok sharing it cuz i wish people would be more transparent and just say it.
    30x50 shop at 16' ceilings with a 20x50 lean to attached with concrete, 1 door, and 2 10x12 roll up doors was 55k.
    I added some dirt to my existing pad we had built up before (built pad for 20x40 10 years ago when we built). With the extra dirt and the extra concrete to connect the driveway made it about 71k (concrete is expensive at about $7 a square finished).
    This is no electrical, plumbing, permits, etc.
  15. Aug 31, 2025 at 9:25 AM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    That's actually a really good price
    T-Rex266, woods and Fotnot[QUOTED] like this.
  16. Aug 31, 2025 at 9:35 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    The guy doing it is a small operation and got him from word of mouth (my favorite type of advertising personally). Wasn't the quickest, but not an issue for me. He also did it where if you needed dirt, you'd pay him for the dirt and he'd spread it for free. Worked for us. He was straight forward too. Concrete was $6/Sq, but he charged $7 so he'd make $1 a square for setting it up and all.
    Gonna need to do electrical soon. Hopefully within the next year I can get it done.
  17. Aug 31, 2025 at 9:40 AM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    That's a $90k + build on my side of the country
  18. Aug 31, 2025 at 10:25 AM
    JMB
    Chesapeake, VA
    I put 150 psi to it, and...nothing.
    I returned the anode and got my $37 back.
    The tank was installed 10 years ago, so that's how long the anode has been there.
    woods and oddhours like this.
  19. Aug 31, 2025 at 10:39 AM
    TILLY
    Massachusetts
    Well, that's a bummer for sure.
    BroHon and JMB[QUOTED] like this.
  20. Aug 31, 2025 at 12:20 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    MOST other places around me are typically closer to that too. One guy that's close to me was very close to the price, but he and the company have a very crooked past (original owner faked death and fled country for a few years to avoid paying things).
    Lots of reputable places around me would have been about 10k+ more for the same build.
    I'm hoping electrical comes soon. Prob be around 8k to have it ran the way I want
    woods, oddhours, Mater and 2 others like this.
  21. Aug 31, 2025 at 1:16 PM
    TaquitoBandito
    Joel (AKA Bif)
    I like that A LOT better than our $50k roof. :(
    WAtundra4x4, OldGuy03, ATV25 and 2 others like this.
  22. Aug 31, 2025 at 1:18 PM
    TaquitoBandito
    Joel (AKA Bif)
    Have you seen his arms?! When he recommends a breaker bar he's talking about something pneumatic for the rest of us weaklings.
    OldGuy03 and JMB[QUOTED] like this.
  23. Aug 31, 2025 at 1:39 PM
    JMB
    Chesapeake, VA
    True.
    OldGuy03 and oddhours like this.
  24. Aug 31, 2025 at 2:24 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I'm almost sure our next roof is going to be because of a hurricane. Hoping to put metal on then and stop doing shingles
  25. Aug 31, 2025 at 5:42 PM
    Azblue
    The Dirty T ( ^_^)_且
    Should've used 151 psi. I bet that would have worked.
    T-Rex266, Fotnot, Tundra2n3 and 3 others like this.
  26. Aug 31, 2025 at 6:47 PM
    TILLY
    Massachusetts
    The bottom of my dishwasher door started leaking water over the weekend, checked the usual suspect door seals, and was just about to order some parts until I checked out some Y-Tube vids. Lots of vids there with the same problem, but some came back with a solution I wouldn't have figured out in a million years. Seems over time the lower sprayer wand can weaken at the seams and although looking perfectly fine, it sprays out directly at the lower door
    seal overwhelming it and causing it to leak. Like I said before, never would have thought to look at that, replaced it today and the leak is gone. :notsure:
    https://www.youtube.com/shorts/X0CEKk4Fy0M?feature=share
    BroHon, shifty`, woods and 8 others like this.
  27. Aug 31, 2025 at 6:57 PM
    JMB
    Chesapeake, VA
    I would have have to buy another compressor, and hoses, and impact tool. But you might be right. Not worth it.
  28. Sep 3, 2025 at 1:13 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    :thumbsup:
    oddhours likes this.
  29. Sep 3, 2025 at 2:03 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Today's project was to remedy a problem the previous owner/builder/plumber created when they built this place in 2022. I knew it way back in April when we moved in. I have 2 outside hose bibs that I have absolutely no way to bleed/drain/or isolate (Michigan... it's a freezing thing). The pex is run under the slab and up and out to a NON frost free fixture on top of that. The walls are all spray closed cell foam making things difficult, but not impossible. In my shop area It would entail making an access hole in the drywall and digging through the foam to find the line, and installing a shutoff ball valve with a bleeder on it. Inside the house its all nice new knotty pine.... not cutting into that and making it look like crap.... Idiots! So after a little searching a long time ago I came up with my own flavor of what seems to be a good temporary/permanent fix.
    End caps I saved from some pipe. A way to see at a glance if the light/heat is on.
    Didn't know the whole thing would glow and I wouldn't need it.
    Encapsulate it in silicon
    A little thermal tube on the strap because I figured even the 7watt bulb might damage it
    Foam to Isolate it from the metal transferring cold in. I knew I saved that foam for something!
    Finished setup, (not wired yet)
    I wanna slap someone for being stupid, but it is what it is. The previous owners only lived here 3 months. There is a Winterization valve and air connection up by the wellhead, and I know they used it to shut it down for winter (It was their summer place). I know this because they fucked that up by back pressuring the well and blowing the pitless adaptor seal out. When we moved in the well was running every 3 minutes just gushing out that seal, and back down the pipe! Had to call the well guys because its a 235ft deep well (and not much head so most of it is dead weight), and I'm not lifting that and killing my back. I think it was only ever meant to be their summer home, because they had a place in FL. But their boys would come here during deer season and use the place, and then apparently re-winterize it, AKA eff it up.
    Long ramble... I'm 99% sure we will be fine with this setup. If not, we'll be w/o water for a day or two while I start chopping holes!
    I checked what it costs to run one 7watt bulb for 6months 24/7, about $6. I'll take that $12 investment over water damage and everything that comes with ripping the walls apart.
    Hollar if ya'll see anything wrong or have better ideas. :thumbsup:
    Fotnot, oddhours and TaquitoBandito like this.
  30. Sep 3, 2025 at 2:48 PM
    Do you not have a shutoff just inside the wall for the outside spigot?
    House we are closing on Friday morning in midcoast Maine has these frost-free spigots, per the inspection. I realize they're not freeze-proof if you leave the hose attached, but ... I'd never seen them before down here in the south.
