67k miles, whine only when accelerating
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rinse_N_Repeat, Aug 29, 2025 at 1:23 PM.
  1. Aug 29, 2025 at 1:23 PM
    Rinse_N_Repeat
    Rinse_N_Repeat [OP] New Member
    Louisiana
    2020 SR5 4x4
    Been having this whine noise for a week or so now. Its faint with the windows up and not noticeable with the radio at 10 vol. But man its a lot louder than I thought. Dropped the back window down this morning headed in to work and you can really hear it.
    Only when accelerating. Sounds is like a buzzing whine.
    Apologies, this is my first post and can't for the life of me figure out how to attached the video I took from this morning :annoyed: Reddit comments were pointing to a carrier bearing, but its not a clunky or howling noise. Noise is present at all accelerations no matter the speed.
    No performance lost. trans, engine, everything is solid feeling.
  2. Aug 29, 2025 at 2:18 PM
    AZBoatHauler
    So.Arizona
    Have you heard about the wire screen in the intake? Mine sounded like a faint turbo until I replaced it.
  3. Aug 29, 2025 at 2:23 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Videos can't upload here unless something like youtube links or vimeo links i believe. kinda sucks.
    if it ONLY happens when accelerating, then it'd be engine related. if it happens at any and all times and changes with speed, then that could be anywhere in the truck. seems odd it is louder when the back glass is down. what about when the front windows? what about when sitting still and in neutral revving the engine?
  4. Aug 29, 2025 at 2:47 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Could be the rear differential. Does it happen under load and coasting? Might want to check wheel bearings
    snivilous likes this.
  5. Aug 29, 2025 at 3:43 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  6. Aug 29, 2025 at 3:56 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    It’s your screen in the intake. Cut it out and no more whistle/whine.
  7. Aug 29, 2025 at 6:40 PM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
  8. Aug 29, 2025 at 6:47 PM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    Tried revving in park with the driver door open, didnt hear it. My first thought was alternator last week when it started, but front windows down while driving I dont hear it, still faint like I have the the all windows up. Put the back glass down its really noticeable. Could be sound traveling as I'm moving forward but kinda ruled out the alt since revving in park can't reproduce the sound.
  9. Aug 29, 2025 at 6:55 PM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    Ill look into it, i traded in my 19 tacoma for the 20 tundra. Family got bigger so does the truck I suppose. 150k on the tacoma not one thing ever made noise or needed replacing. 2 weeks into the tundra and now I have a s/c apparently ,, man life is good :rofl:
  10. Aug 29, 2025 at 7:57 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds like the differential. Maybe a bearing going out or a tooth fractured.
    The screen in the intake is a slight whistle, it's not what you're talking about.
  11. Aug 29, 2025 at 8:19 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    And it's not through the speakers, right? It doesnt ocilate louder with higher RPMs etc? It could be a grounding strap needed or replaced if it is from speakers-ish...
    ZappBrannigan likes this.
  12. Aug 29, 2025 at 10:50 PM
    MALIBU1794DC
    MALIBU1794DC Like a Japanese Texas built Rock
    2019 Double cab 1794
    Did you install any new stereo equipment in the truck?
    HulkSmurf14 likes this.
  13. Aug 30, 2025 at 2:55 AM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    It does get a little more pronounced when going faster, but not from speakers. Its alot fainter with the windows up, soon as I roll the back glass down its considerably louder.
    HulkSmurf14[QUOTED] likes this.
  14. Aug 30, 2025 at 2:56 AM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    No all factory, the sound is louder with the back glass rolled down, so its definitely something outside
  15. Aug 30, 2025 at 3:03 AM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    Yea i looked at a few videos about the mesh screen last night. Thats not the noise, sounds more of something like a water pump or prower steering when its struggling. Revving in park doesnt create the sound, only when I accelerate. So it's def something when on load. Almost like a buzzy fuel pump, but nothing is compromising performance when driving so idn lol. Not wobbles, shakes, no clanking. Just a buzzy whine sound
  16. Aug 30, 2025 at 5:17 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I started thinking fuel pump too when you said that about the back glass down making it louder
  17. Aug 30, 2025 at 5:23 AM
    HulkSmurf14
    2014 Tundra Limited
    Could or be the idler pulley or alternator pulley? If it's from the back end, likely the rear end, from the front, a pulley needs attention. This feels like Jeopardy! :p
  18. Aug 30, 2025 at 6:24 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    At like 35 to 55 mpg my rear end makes a wine noise when I lightly get on the throttle, the noise mostly goes away when I left off the gas. Been this way pretty much since new, 85k miles now.
  19. Aug 30, 2025 at 6:40 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    The easiest way to tell if it’s the idler puller or belt tensioner is to warm it up, then spray water on it. If it goes silent, you’ve found the problem. Still sounds like the intake mesh to me. I had a very similar weird noise (only under acceleration sounded like a supercharger.) I cut the mesh out and it went away.
  20. Aug 30, 2025 at 7:40 PM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    As for the mesh, I do hear what everyone is saying that's more of a whistle from say 0 to 30ish. The sound I'm hearing starts at dead stop acceleration and gets pretty pronounce around 50+
  21. Aug 31, 2025 at 5:52 AM
    mqqn
    mqqn New Member
    Andy
    2019 SR5 Double Cab 4.6L 2WD
    Every vehicle I have owned for the last 35 years has had a pronounced whine and high-pitched squeel that comes from the front passenger seat during acceleration.
    I apologize, couldn't resist.
    I hope you track down your issue soon @Rinse_N_Repeat
  22. Aug 31, 2025 at 6:44 AM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    Yours is not backseat only,, dang she lucky
    mqqn[QUOTED] likes this.
  23. Aug 31, 2025 at 7:30 AM
    mqqn
    mqqn New Member
    Andy
    Lol. I guess she is...
  24. Aug 31, 2025 at 7:44 AM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    Finally got time to get under and see if anything sticks out. This is the only thing I found. Went under the entire bottom, under hood, through fender walls. Idn if this would be cause a whine noise. Obviously seems I need to replace but is it anything to be super concern atm. Sorry I'm not mechanic nor I pretend to be. I know my limits lol
  25. Aug 31, 2025 at 7:46 AM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
  26. Sep 2, 2025 at 9:29 PM
    MALIBU1794DC
    I'm thinking fuel pump noise
  27. Sep 3, 2025 at 10:12 AM
    yakeng
    yakeng 3URFE Apologist
    I would remove the serpentine belt and start it up, if the noise is gone, you know it’s one of the items on the belt train. It would at least rule that out.
  28. Sep 3, 2025 at 10:31 AM
    Rinse_N_Repeat
    Louisiana
    2020 SR5 4x4
    Well it's in the shop at the dealership, so we shall see what they come up with
