OEM Classic Running Boars on 2021 TRD Pro?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by teg333, Aug 30, 2025 at 1:05 PM.
  1. Aug 30, 2025 at 1:05 PM
    teg333
    teg333 [OP] New Member
    I may add the Toyota OEM Classic Black running boards to my 2021 TRD Pro. I like the look but they may be a bit too wide for my taste. Can anyone tell me the exact width of these boards, P/N PT925-34183?
  2. Aug 30, 2025 at 4:43 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :eek:
  3. Aug 30, 2025 at 5:14 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    KIMG20250830_170920994.jpg KIMG20250830_170647892.jpg KIMG20250830_170847899.jpg
    2019 if it helps.
    Tripleconpanna likes this.
  4. Aug 30, 2025 at 6:58 PM
    teg333
    Wow, 7.5 inches wide. Does that include the gap over to the body or just the tread itself?
    Thx
  5. Aug 30, 2025 at 7:05 PM
    blenton
    blenton New Member
    I have them on my ‘21 DC. They are great old man steps. Surprisingly, they don’t hang lower than the frame, so it’s a hair higher to step up than the older series of steps from Toyota. The ones posted by @ATV25 are the older style steps (which are textured plastic vs the rubberized aluminas that the OP posted).
    Step depth at the top surface is 5.5”; the stick out maybe 1.5” past the front mudflaps.
    Lucid Tundra likes this.
  6. Aug 30, 2025 at 7:28 PM
    teg333
    Just to confirm... the ones posted in your photo for the DoubleCab are probably p/n PT925-34181, which I believe will be the same width as the PT925-34183 for the CrewMax cab and that tread width is 5.5"? I really like the look of those on you DC!
  7. Aug 30, 2025 at 8:09 PM
    blenton
    blenton New Member
    Thanks. They are actually PT925-34183; I bought the crewmax steps and run them long in case I need to access the roof. Plus, I think they look better than the DC steps. The rear mounts are easily adjusted/moved.
    Also, I measured the top of the step, not the bottom.
  8. Aug 30, 2025 at 8:19 PM
    teg333
    Perfect, I'm going to order them during the Labor Day sale! Thanks very much for the help!
  9. Aug 31, 2025 at 1:41 AM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    It's hard to measure but it includes the gap.
