  1. Aug 29, 2025 at 8:29 AM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Yep, under the feet, exactly. I had a gravel drive (still do now) so it was no worry. Hopefully that solves it for you :thumbsup:
    I think I used DeepCreep so it would migrate in there deeper, but silicon based (smaller molecules) helps
    sloppylbjs[QUOTED] likes this.
  2. Aug 29, 2025 at 8:35 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    455h0le_dachshund likes this.
  3. Aug 29, 2025 at 8:35 AM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    It's actually not that bad since I did the shocks all around. But she can handle a fk ton of weight. It was a construction companies truck (shadow of logo on door) and I think it may have even been a plow truck/and salter?
    I wish I had pictures, but there was a strange bracket in the engine compartment on the passengers side when I first bought it... like aux electric/hydraulic/or something? I'll see if I have a pic by chance.
    But bastard packs make sense for a construction company.
    EDIT: found one, it's not very good, but maybe someone will know.
  4. Aug 29, 2025 at 9:02 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    New starter is in, and new knock sensors are in. Hoping to get the coolant bypass pipes back in after lunch.
    Wrapped my knock sensor wires in hardware cloth. Should largely prevent mice from chewing in them, but it's not perfect.
  5. Aug 29, 2025 at 11:22 AM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    Awww they each have their own little faraday cage :rofl:
  6. Aug 29, 2025 at 11:33 AM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    How was that job, swapping the starter?
    Filthyphil likes this.
  7. Aug 29, 2025 at 11:39 AM
    Poor man’s armored cable so critters can’t bit through them supposedly. I’d go with flexible metal conduit myself if it was an issue.
  8. Aug 29, 2025 at 11:53 AM
    This is the stuff I've been using for exterior IP cameras where the network cable could be exposed to cutting/tampering/UV because it's cheaper than buying CMX-rated cable for something that'll only have max of 5-10ft exposed. It works well, and comes in a few different diameters under the product name "electriduct".
  9. Aug 29, 2025 at 1:12 PM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    Got the new tires on. They look and ride really nice so far.
    Bought2Pull, des2mtn, CC80guy and 3 others like this.
  10. Aug 29, 2025 at 1:21 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    If I could choose, I'd get that color and cab, but in a 02 to 00. That's so nice looking dude!
  11. Aug 29, 2025 at 2:30 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    It’s a moderate job especially when you have to do it twice because you put a remanufactured started in the 1st time like I did.
    Nicklovin[QUOTED] likes this.
  12. Aug 29, 2025 at 3:05 PM
    kentuckyMarksman
    It sucked, but my truck is VVTI. I bet it's a bit easier on your non VVTI truck. I'd honestly rather pull the transmission out of my Subaru again than mess with this starter.
    Not poor, just cheap
  13. Aug 29, 2025 at 3:10 PM
    kentuckyMarksman
    Well, I finished with the hardware cloth, and got most everything under the intake back together.
    Unfortunately my mind was spent, and I refused to quit, and made a rather stupid mistake... I thought the O-ring for the coolant bypass was giving me a fight so I kept tightening the bolt and broke my water pump... so now I get to replace that and the timing belt . Is the kit from Rock Auto the way to go for it?
    I should of just quit and looked at it tomorrow with a fresh head.
  14. Aug 29, 2025 at 3:11 PM
    Yes, this one: https://www.rockauto.com/en/moreinfo.php?pk=3290529&cc=0&pt=5759
  15. Aug 29, 2025 at 3:13 PM
    Ouch! Must be cast aluminum.
  16. Aug 29, 2025 at 6:13 PM
    Kalannar97
    Michael
    Hillsboro, TN
    New versus old tires in the fender. The new ones stick out slightly more. I love the way they look over the stock T4R Michelin Defenders that came with the rims.
  17. Aug 29, 2025 at 6:17 PM
    Kalannar97
    Michael
    Hillsboro, TN
    Is there an easy way of getting these backer plates off without pressing off all of the bearings, seals and retaining rings? As can be seen, the driver's side shaft has a stud cut off so they could remove it from the old rusted out axle. Unfortunately, that is the one I need to use for the axle shaft that is bent/bad bearing. Or should I just say screw it and buy a completely new assembly and call it good?
    Jack McCarthy likes this.
  18. Aug 29, 2025 at 6:28 PM
    des2mtn
    On the Scenery, Looking at the Road
    2004 Black DC Limited 4x4
    Tonto cover
    Grinder is the only way that's coming off quickly without a press. But you'll need a press to install the replacement. That bolt is a serrated bolt and pressed into the bearing housing/backing plate, so you could get a ton of penetrate on it and hammer it out, then reuse the bearing housing and backing plate.
    Don't say screw it and buy a new axle unless you're prepared to do the press work or have it done either. The only pre-pressed axles are aftermarket and of questionable quality.
    Jack McCarthy and FrenchToasty like this.
  19. Aug 29, 2025 at 6:39 PM
    Kalannar97
    Michael
    Hillsboro, TN
    No, I was planning on getting new from the Toyota sale if I did. The shop that is working on the truck doesn't have the correct press setup. I'll keep looking. The backing plates on these are shot from the rust. The ones on my new axle are much better shape but the axle shaft itself is bent slightly unless a bad bearing can cause the tire to wobble.
  20. Aug 29, 2025 at 7:22 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    We mowed sans trailer two yards.
    Hooked up single axle and got three more. I was hoping for 8 yards today but that was overly ambitious. Truth is, we plan to cut out the remaining truck-only yards at the end of the season. We lose too much time (money) keeping such yards up.
    One of the yards the wife has to block traffic so I can get backed back out into the road. The other, can't fit the trailer now that the city went and put a sign up right in the way!
    Should get some good "truck working" pics tomorrow. Cutting down a row of overgrown bushes and trimming a big walnut tree. Hauling it all off to the landfill.
  21. Aug 29, 2025 at 11:12 PM
    Nicklovin
    Nicklovin Yap Yap
    Ooof. Had that happen once with an autozone starter
  22. Aug 30, 2025 at 12:05 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Thanks. 10% more off this weekend...but looks like it only fits DC :(
  23. Aug 30, 2025 at 12:12 AM
    ToyotaDude
    ToyotaDude Member
    Have seen a pipe used in this video from 16:00 onward.
    https://m.youtube.com/watch?v=uY8pljevOY4
