General Supercharger Thread
  1. Aug 27, 2025 at 2:45 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    That in Denver? Always looking for a good body place. The M3 needs some work
    HulkSmurf14 and ARES35[QUOTED] like this.
  2. Aug 27, 2025 at 3:42 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    24 TRD Pro
    I miss seeing 20+ psi on my boost gauge in my 2018 truck on the 2.0 pulley. I have hit 20psi a few times in the new rig, doesn't hit the same, yet.
  3. Aug 27, 2025 at 3:51 PM
    ARES35
    ARES35 New member for life
    Mile high
    Out here in Aurora close to Buckley space force base. They're not the quickest but they do meticulous work!
  4. Aug 27, 2025 at 6:51 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    It was fun to see what I got for my $0.02. XL sizing is right.
    I've never ordered from anyone who gives you more stickers. Kid ate the candy right away.
  5. Aug 28, 2025 at 4:55 PM
    ARES35
    Mile high
    What Toyota should have done with the turd gen:rofl:
  6. Aug 28, 2025 at 5:12 PM
    ARES35
    Mile high
    Was messing with Gemini and had to ask her. She thinks real big. :rofl:
  7. Aug 29, 2025 at 7:29 AM
    nags
    nags New Member
  8. Aug 29, 2025 at 7:57 AM
    nags
    nags New Member
    Getting this on the 2019 post Whipple install. Anyone deal with this? A search in the thread for P0307 returned no results. Sent it to Sniv along with some logging but curious if others have come across this. After my SC install I had misfire codes on a different cylinder (5, I believe?) that ultimately ended up being a bad cat but not sure this is the same. Get on it a bit hard at around 60 and it goes right into limp mode and throws this code. Will not clear until the battery is disconnected for a minute.
  9. Aug 29, 2025 at 8:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    You check the coil pack connection? No codes on mine post install etc you try and switch the coil pack see if it moves?
    HulkSmurf14 likes this.
  10. Aug 29, 2025 at 8:01 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Were the plugs changed?
  11. Aug 29, 2025 at 8:03 AM
    nags
    nags New Member
    Yep, brand new.
    You've got that 3.0 installed already? Y'all don't play. I'll make sure he checks them tonight.
  12. Aug 29, 2025 at 8:09 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No I meant the 2.9 nothing is different really to make you get codes on that vs a 2.9
    HulkSmurf14, nags[QUOTED] and Mdl like this.
  13. Aug 29, 2025 at 8:09 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I battled misfires in 7 and 5. Installing new plugs helped for a little bit. All my logs were good but for some reason my fuel trims needed to settle in. @snivilous went through a few tunes before it settled out.
    HulkSmurf14 and nags[QUOTED] like this.
  14. Aug 29, 2025 at 8:17 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is Gemini your sign? I'm a cancer myself.:rolleyes: Still can't bring myself to use that stuff but I'm sure I am everything I'm on the interwebs.
    I just stick with this formula.
    ARES35[QUOTED] and reywcms like this.
  15. Aug 29, 2025 at 8:18 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Obviously it meant 10,000.
    I had multiple misfires after motor 1, pretty sure it was ten install & not connected to anything that would be helpful for you.
    blenton and ARES35[QUOTED] like this.
  16. Aug 29, 2025 at 8:22 AM
    Fastlane47
    Maryland
    24 TRD Pro
    I had that same code after running higher boost, I gapped my plugs down and it never came back.
    ARES35, Wynnded, Mdl and 1 other person like this.
  17. Aug 29, 2025 at 8:41 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Mine were gapped at .024 and was still happening but there are a lot of variables.
    One thing I can say is after switching to the Lexus 8arfts coils along with @JustDSM background dwell settings I haven't had a misfire. Have plugs gapped at .033 hitting 15psi. I was getting random misfires that wouldn't trigger a MIL but was still annoying.
    ARES35 and Wynnded like this.
  18. Aug 29, 2025 at 8:56 AM
    Fastlane47
    Maryland
    24 TRD Pro
    I gapped mine to .020 after that it ran great.
  19. Aug 29, 2025 at 9:01 AM
    Silver17
    Northeast
    I installed my IKH24s as they come out of the box and haven’t had any issues in 25k miles. How long can you expect to get out of plugs boosted? 40k?
    Wynnded and mustang67408 like this.
  20. Aug 29, 2025 at 9:02 AM
    Fastlane47
    Maryland
    24 TRD Pro
    I replaced mine every 10k, but I didn't wait for them to fail.
  21. Aug 29, 2025 at 9:05 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I pulled the spec'd mileage for each option when I was adding them to the GTC thread "first post". Not sure boosted really matters much if you are running the right temp. Let me copy/paste.
    Spark Plugs-
    Heat Range 7 / 22 (one step colder than stock)
    - DENSO IKH22 (30k mile)
    - NGK LFR7AIX (50k mile)
    - NGK DILFR7K9G (100k mile)
    - NGK LFER7BHX (Ruthenium, 60 -120k mile)
    Heat Range 8 / 24 (two steps colder than stock)
    - DENSO IKH24 (30k mile)
    - NGK r7437-8 (racing, no service life provided)
    ARES35, Wynnded, e30cabrio and 2 others like this.
  22. Aug 29, 2025 at 9:06 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    We're you still planning to use the Lexus coils or has it changed with OTT?
  23. Aug 29, 2025 at 9:22 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Lexus coils and dwell table were planned for back in late winter/early spring with the existing tune already updated by @JustDSM
    The coils are installed along with 0.034" gapped LFR7AIX (NGK 2309) plugs.
    Plans have changed a bit, and as soon as the exhaust and fueling upgrades are done (immediately after 500 miles), my goal is to get a custom dyno tune done on it. I'm assuming it will start with the OTT & Turbokits baseline, but I'm letting the experts do expert things on that front. I actually need to sync up with @TurboKits on that part. A few moving pieces that involve multiple parts of their ecosystem to make it happen.
    e30cabrio, reywcms and Mdl[QUOTED] like this.
  24. Aug 29, 2025 at 9:28 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    My 2002 Tundra was boosted since it was born week 1.....I changed the plugs at 100K, never an issue and I drove her like I stole her.
    Saltyhero13, ARES35, Wynnded and 3 others like this.
  25. Aug 29, 2025 at 9:52 AM
    e30cabrio
    I still miss my 2000 V6 manual 2wd longbed Tundra, been gone since 2005.
    mustang67408 likes this.
  26. Aug 29, 2025 at 10:29 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Trying to help a dude, he had the supercharger and valve body done at the same time. Now in 2nd gear only, when the truck goes to shift into 3rd gear and only at WOT the engine completely unloads and blows past the rev limit. It's like clutches are releasing for 2ne gear and not grabbing 3rd fast enough or something, so the revs shoot up for a moment until 3rd gear is engaged. I've tried to band aid it with tuning but nothing changes. He even had the stock valve body reinstalled and it made no difference.
    What I'm guessing is something fell out or was messed up when installing the aftermarket valve body, and the shop doesn't realize it when they reinstalled the stock one. Is there something accessible during the valve body install that would seemingly relate to the issue he's seeing? It only happens during the 2-3 shift and at high throttle, every other gear and lower throttle he says is fine.
  27. Aug 29, 2025 at 10:56 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Sounds like a check valve issue.
    HulkSmurf14, BigAl, ARES35 and 2 others like this.
  28. Aug 29, 2025 at 11:41 AM
    ARES35
    Mile high
    No sir Cancer here too! Lol. That's my phones AI:rofl:
    Mdl[QUOTED] likes this.
  29. Aug 29, 2025 at 12:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    One of the 3 o-rings may have slipped out. I've also had them be too flattened from re-use too many times. They hold the brake drum pressure.
    Edit: could they have mixed up the accumulator piston springs? Check ball spring intact?
    C3/red, b3/orange and c2/light green
  30. Aug 29, 2025 at 12:10 PM
    blenton
    blenton New Member
    Same as Rey with my 2.9 Whipple - no misfires after install. I even gapped them out a few thousands a couple of times just to see if they would start misfiring (pretending to chase some fuel economy) and even at .030 they weren’t misfiring. I gapped them back down to Whipples recommended gap though.
    They supplied plugs with the 2.9 kit but no longer supply them with the 3.0 kit. As others have noted, I would check your gap.
    Also, do you know what plugs were used, and from whence they were sourced? Were they factory plugs or colder plugs? Too many skeezy counterfeit parts on the likes of Amazon, eBay, etc..
