General Turbocharger Thread (formerly "Turbo Charging A Tundra!")
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Aug 25, 2025 at 6:41 PM
    #2551
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    Small update on my swap.
    I wish they were on here to give them the props, but big shout out to ECS Performance for doing me a solid today. The long block comes nearly complete with the exception of a few peripherals. Turns out, the oil filter housing (the part that the filter cap screws into, and that the oil cooler bolts to) is one of those peripherals. I was unaware, and this is one of the only new replacement parts I did not order.
    Anyways, ECS already has a replacement ordered so there is zero risk of debris or contamination in the oiling system on the new block. They just simply didn't feel comfortable reusing it.
    After the wait and the cost of this build, I'm beyond thankful they are being as meticulous with the swap as I have tried to be planning for it.
  2. Aug 25, 2025 at 7:02 PM
    #2552
    centex
    centex New Member
    I can’t wait to see this thing run.
    e30cabrio and Jego like this.
  3. Aug 25, 2025 at 7:26 PM
    #2553
    bflooks
    Metrowest MA
    Neither can I. :rofl:
    Soon
    e30cabrio, Mdl and Jego like this.
  4. Aug 26, 2025 at 4:32 AM
    #2554
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    @bflooks Can't wait to see your build!
    Quick update: Got all I need for the coolant/heater core by-pass and the ATF warmer removal. I will use one of the hose connected to the warmer for the by-pass. Will do it this weekend. :fingerscrossed:
  5. Aug 26, 2025 at 5:29 AM
    #2555
    bflooks
    Metrowest MA
    What are the circled parts for, exactly? I'm tracking the elbows and o-rings. Are you keeping the metal lines on the valve cover?
  6. Aug 26, 2025 at 6:03 AM
    #2556
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Looking good! I haven't had any issues with the elbows. Napa brand hose seems to fit pretty snug.
  7. Aug 26, 2025 at 10:08 AM
    #2557
    TurboKits
    TurboKits New Member
    Just picked this GESi Downpipe up from the fabricators... This is why we wait for him and him only. Dude welds like a robot... Just beautiful!
    e30cabrio, AZTundra, Mdl and 6 others like this.
  8. Aug 26, 2025 at 10:09 AM
    #2558
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    My plan is to completely remove the heater core hoses and the warmer. We don't need heater in PR :bananadance:.
    I will flush the heater core and put the 2 hose rubber caps to protect it.
    The other are the hose connectors to do the coolant bypass in the front:
    All metal lines and hoses will not be necesary after the bypass in the front.
  9. Aug 26, 2025 at 10:12 AM
    #2559
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Nice! Glad to know! I am going to used one of the short hoses connected to the warmer. But if that leaks Napa can be the way to go. You got Napa 5/8 in. inner diameter?
    e30cabrio likes this.
  10. Aug 26, 2025 at 10:22 AM
    #2560
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    @Jego have you also bypassed the coolant lines that run to the throttle body? You definitely don't need that if you don't even need the heater core.
  11. Aug 26, 2025 at 10:33 AM
    #2561
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Definitely! Thanks for reminding me. It's the perfect time to do it. I'd forgotten that part too!
    I will take a look of it and do it as well! Thanks
  12. Aug 26, 2025 at 11:31 AM
    #2562
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    3/8 for atf and 5/8 for heater hose.
    e30cabrio and Jego[QUOTED] like this.
  13. Aug 26, 2025 at 12:02 PM
    #2563
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Ooops, I don't have a 3/8" hose. I can't find the photo you posted recently. Did you add a short 3/8" hose extension or replace it completely?
  14. Aug 27, 2025 at 9:40 PM
    #2564
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you have the hardline to cooler then it's about 14 inches? from elbow to hahardline. So a little over 28 inches for both supply/return.
    Jego[QUOTED] likes this.
  15. Aug 28, 2025 at 8:25 AM
    #2565
    TurboKits
  16. Aug 28, 2025 at 8:33 AM
    #2566
    bflooks
    Metrowest MA
    Congrats! @martiartisan
    Can't wait to watch your install and hear about your experience. The kit is so refined and the installation is well documented with most "install specific" steps having been talked through that I'm almost jealous of anyone doing it.
    I'll add you to "The Backroom" now.
    Jego and TurboKits like this.
  17. Aug 28, 2025 at 5:35 PM
    #2567
    bflooks
    Metrowest MA
    It's finally happening!! Thank you to @TurboKits and ECS Performance!
    Accessories/systems, hoses, wiring and turbo need to be buttoned up, BUT!! Engine is in.
    TurboKits, ssmokedz, centex and 5 others like this.
