What kind of camper do you have???
Discussion in 'Towing & Hauling' started by Muleycrazy13, Feb 12, 2017.
  1. Aug 8, 2025 at 5:42 AM
    #1291
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I heard those are like 5,000 gvwr and in the 3s dry... How's the build quality on them?
    Also, iirc someone said those have an option to have a body lift installed w/the build... is yours lifted or traditional height??
  2. Aug 8, 2025 at 5:58 AM
    #1292
    iamunique127
    iamunique127 New Member
    Manitoba, Canada
    2013 CrewMax
    3" level
    That is about the weight. Rated at 5,500 max loaded. 800 lb pin weight loaded so I have to watch the payload pretty closely.
    Build quality is excellent and with the clamshell style shell there are never any water leaks. They are very factory-customizable, tons of options. We got most of the options available 10 years ago. There are more now.
    Yes, you can get a 2.5" body lift kit on most model years of these trailers. Mine has beam axles and leaf springs so it meant flipping the axles below the springs resulting in 4.5" lift. I now have lots of clearance and the trailer runs level behind the 3" levelled Tundra. Air bags keep the whole rig levelled when towing.
  3. Aug 28, 2025 at 1:13 PM
    #1293
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Hopefully someone can share some knowledge here.
    Right now the Trailer has a dometic thermostat, when the furance is turned on, the fan speed is just full blast, if I was to change it to microair unit, does it offer adjustability on fan speed? I tried to reach out to Microair but they said they don't know.
  4. Aug 28, 2025 at 1:43 PM
    #1294
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I did this upgrade, the fan only runs at one speed. You could wire a variable speed dial to the motor and that might slow it down but it might screw up the sail switch in the furnace.
    Cpl_Punishment likes this.
  5. Aug 28, 2025 at 2:52 PM
    #1295
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    GFC V2. Absolutely love this thing for backcountry camping.
  6. Aug 28, 2025 at 6:42 PM
    #1296
    Downytide
    GTA
    That's a bummer, on previous trailer had Truma furnace and controller, I loved it that at night I can keep it at "quiet" mode.
