Toyota OEM TRD Front Recovery Hooks
Discussion in '3rd Gen Tundras (2022+)' started by RatPanda, Nov 12, 2024.
  1. Jul 24, 2025 at 1:53 PM
    #451
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  2. Jul 24, 2025 at 2:01 PM
    #452
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    I wanna speak to the dealer quoting 3 hours for a 30 min job. They taking a 2.5 hour lunch?
  3. Jul 24, 2025 at 4:59 PM
    #453
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    Ok since you ask . . . Here goes! Neither, both are way too big to be driving around with in my opinion and one or both with go missing one day. Keep the shackles in a recover bag with a good tow rope for when you need them.
    Just my two cents . . . and you did ask. :D
    Besides it's a Platinum and they look great standing still and don't need their shackles showing! :cool:
  4. Jul 24, 2025 at 5:27 PM
    #454
    Demar002
    Demar002 New Member
    Frank
    2022 Toyota Tundra
    I am considering that option as well (keeping them stored). Nothing at all really looks like something is flat out missing or fell off. I do appreciate the feedback. I would not have asked if I couldnt handle the feedback. Thanks !!!
    Calif-Tundra likes this.
  5. Jul 24, 2025 at 6:05 PM
    #455
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Black.
  6. Jul 24, 2025 at 6:28 PM
    #456
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Don’t leave them on
    DRP likes this.
  7. Jul 24, 2025 at 10:16 PM
    #457
    dogsleds_t100_tundra
    dogsleds_t100_tundra New Member
    '23 Tundra SR5 TRD OffRoad AG and '97 T100 4x4
    275/70/18 AT3, Elka IFP 2.0, Aftermarket Speakers, Sub, Amp. Ceramic Window Tint, Color matched grill surround and rear bumper panels, Orvis Backseat Protector for K9s, OEM Black Exhaust Tip, OEM Black Tailgate badge insert.
    Powdercoat the eyeloop mount to color match with a TRD Pro UCA would be ideal set up, no tassels. Someday.
  8. Jul 25, 2025 at 6:22 AM
    #458
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    The white does pop nice
  9. Jul 25, 2025 at 7:38 AM
    #459
    TheDo114
    TheDo114 New Member
    2022 Black Tundra SR5 TRD Offroad
  10. Jul 25, 2025 at 9:59 AM
    #460
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
  11. Jul 25, 2025 at 10:19 AM
    #461
    Bucko07
    Bucko07 New Member
    2025 Tundra Limited
    OEM Tow Hooks Dual wireless charger Tundra rear/front badging and TRD badge
    I put the red shackles on and I don’t think I like them…..they remind me of pirate earrings for some reason…lol
    23 Platinum and Rigger like this.
  12. Aug 7, 2025 at 7:54 AM
    #462
    MadRanx
    MadRanx New Member
    Joe
    2011 Black Tundra, 2025 Silver Tundra
    When you made the cut shown above, did you just eyeball it from the graphic in fig 2-3 ? (since no one has the templates referred to).
    Also, what tool did you use?
    Starting my install today or tomorrow
    Thanks.
  13. Aug 7, 2025 at 9:16 AM
    #463
    eddiefromcali
    Eddie
    100% Stock
    No need to cut anything, just slap it all together and everything clears just fine
  14. Aug 7, 2025 at 9:19 AM
    #464
    Calif-Tundra
    Bob
    I did NOT have to cut anything. Do a test fit first to see, but on my 2023 Limited there was no cutting needed.
    Good luck!
  15. Aug 7, 2025 at 10:47 AM
    #465
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    If you deploy the dam it is so much easier for the install.,there's zero need to slice and dice it.
  16. Aug 7, 2025 at 4:49 PM
    #466
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
    Got a link for this trans lawsuit?
  17. Aug 7, 2025 at 5:47 PM
    #467
    bailey bulldog
    bailey bulldog New Member
    Same here, no reason to cut.
  18. Aug 9, 2025 at 7:45 PM
    #468
    Rigger
    Rigger New Member
    2025 Tundra Crewmax
    I ordered these. Looking forward to having my teenage boys install them for me.
    (These are less expensive than the Slee units. Not sure what else is available.)
    TheDo114 likes this.
  19. Aug 28, 2025 at 4:08 AM
    #469
    OrangeBlueOrangeBlue
    OrangeBlueOrangeBlue New Member
    2024 1794 Limited Edition
    it’s for 2019-20s, not 3Gs. Lawyers arguing that the transmission heat exchanger isn’t a transmission cooler…
    sudobash likes this.
  20. Aug 28, 2025 at 6:00 AM
    #470
    sudobash
    sudobash New Member
    It isn't. It's 100% to get the transmission fluid to a igher temp faster in order to improve "fuel economy". It was also a decision made by the accounting department in order to milk the every last bit of revenue out of the model.
  21. Aug 28, 2025 at 8:06 AM
    #471
    No, it was made because they had to switch the 134a refrigerant for the AC condenser, which previously housed an external cooler, to less efficient 1234yf refrigerant. The less efficient refrigerant necessitated a bigger condenser, which they swapped in for the combined condenser/cooler, leaving the external “puck” heat exchanger to handle trans temperature regulation.
    While the puck does indeed help get the trans fluid up to operating temp using the engine coolant loop, because the transmission’s high-temp threshold is 300F and the coolant threshold is closer to 250F, there is a point when the trans fluid is warmer than the engine coolant, so the engine coolant is cooling the trans fluid instead of warming it. The puck can’t cool the trans to below the engine temp like the prior liquid/air coolers, but it does help keep the trans temp lower than it would be without it.
  22. Aug 28, 2025 at 8:18 AM
    #472
    Breathing Borla
    AZ
  23. Aug 28, 2025 at 9:21 AM
    #473
    sudobash
    sudobash New Member
    While Toyota will say that, it's not the real behind the scenes reason.
  24. Aug 28, 2025 at 1:48 PM
    #474
    If we accept your theory that they were just pinching pennies, then Toyota wouldn’t have spent money to spec a larger AC condenser than they absolutely had to. And since they did, in fact, switch to a larger unit, it suggests that there was a technical reason behind it, rather than a financial one.
  25. Aug 29, 2025 at 4:55 AM
    #475
    sudobash
    sudobash New Member
    You're talking about two different things. The switch for the A/C refrigerant did, in fact, require a large condenser.
    Switching to a larger condenser does not negate the fact that a transmission cooler could've been included, but was not.
    GODZILLA likes this.
