  1. Aug 26, 2025 at 3:34 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Cool flag decal, where did ya get it?
  2. Aug 26, 2025 at 4:20 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Here is the link. If you order it, leave the seller a note saying you want 1 standard and 1 mirrored.
    RUSTIC AMERICAN FLAG 959 (2-pack, Size: 7") Full Color Printed Vinyl Decal Hard Hat Helmet Window Sticker - Etsy https://share.google/vPLhhqUD9hB75aTXR
  3. Aug 26, 2025 at 4:30 PM
    Damn POS. It started for her after work. She got home, hour and a half later it won't start again. Once it starts shes bringing it down so I can swap the battery.
  4. Aug 26, 2025 at 5:01 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    That’s sick, how’d you do the American flag
    edit: I see your link lol
  5. Aug 26, 2025 at 5:06 PM
    easleycrawler
    Travis
    Pull the shifter part of the console out, and the gear selector part clips around the shifter with 4 clips, place whatever sticker you want on it and take a hobby knife to cut it out. Hope that makes sense.
  6. Aug 26, 2025 at 5:07 PM
    Father in law tapped on solenoid and it started. We are going to the shop now to change the starter and battery.
  7. Aug 26, 2025 at 6:00 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Thank you!
  8. Aug 26, 2025 at 6:12 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    Swapped out my cheap a battery terminals for some with extra spots to connect wires.Also added to my CF accessories....lol I might be a redneck
  9. Aug 26, 2025 at 6:31 PM
    Swapped out the starter and the battery on the kids 4Runner. Starting issues should be good now. I'll have the old starter tested when I return the core.
  10. Aug 26, 2025 at 7:20 PM
    Took a night shot of my SS3 Pro backlight when I stopped by my camper to check on my EcoFlow. @memario1214
  11. Aug 26, 2025 at 7:39 PM
    joseph_womack
    Joe
    Louisiana
    I am a whore for amber, looks good :fistbump:
  12. Aug 26, 2025 at 7:45 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Hahaha, I was just thinking we had a Subaru that you needed to tap the starter with a 2x4 piece and it would start…20+ years ago.
  13. Aug 27, 2025 at 3:34 AM
    Thanks. I like it. :D
  14. Aug 27, 2025 at 7:11 AM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Not 100% of the time, but usually when I put it up on the truck I plan to keep it up there for a while. We’ve been hitting the beaches and springs a lot this summer so I’ve been using it quite frequently washing sand and salt water off of grandkids, dogs and feet. I really like the convenience of the roof mount as it keeps it secure and out of the way.
  15. Aug 27, 2025 at 7:55 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Not today but here anyway…
    FN Five Star 17 inch wheel with P285/70R17 Nitto Terra Grappler G3…installed a few weeks ago.
    IMG_0218.jpg Hayden 689 transmission cooler with a high quality @Jmunk custom bracket. My mechanic did all the plumbing on Monday. These were just the install pictures I took when I installed the bracket/cooler.
    My temps with the NEW tire setup was 217. Stock tire setup was 207.
    Post cooler, 190 at the pan.
  16. Aug 27, 2025 at 7:56 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Those are solid upgrades!
    Tripleconpanna and Oey12 like this.
  17. Aug 27, 2025 at 8:04 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    Thanks!
    Truthfully I wasn’t comfortable with an average temp of 217. It just made sense to do the cooler once I committed to the tires…. The truck really does handle 33”s nicely.
  18. Aug 27, 2025 at 8:12 AM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    Nothing major today, just drove to get a haircut and parked in good company.
  19. Aug 27, 2025 at 11:41 AM
    Mikey Two Tones
    Mikey Two Tones New Member
    2019 DC SR5
    Yes sir, grabbed a 6" patch cable from work which worked fine but if you could get your hands on one that was just a little longer it would give you some more slack.
  20. Aug 27, 2025 at 2:06 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I just ran out and gave it a kiss. CR put the 2025 at a 30/100 for reliability and theres a video on r/tundras right now of ones engine on fire :rofl:
    "From my cold dead hands"
    NWPirate, bulldog93 and BR73 like this.
  21. Aug 27, 2025 at 4:05 PM
    Bowzer
    Bowzer New Member
    Assuming you went with Dexron III tranny fluid as replacement? (Fell down a rabbit hole recently looking at a bunch of back forth discussions about that...)
  22. Aug 27, 2025 at 4:42 PM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Update: got truck back today. Tires were delayed which is why it took forever. Sucks. It’s always me lol. Either way dropping down from 37s to 35s is nuts. Tires look soooooo small, like laughably small. They ride a lot smoother C range than E range. Overall happy.
    As far as the King 3.0s — driver side max height. Passenger side lowest height. I STILL have a driver side lean of 0.5 inches. Emailed kings again to figure it out. Just doesn’t make any sense to me (still gotta throw on my duro bumpstops whoops). No extra weight on drivers side neither. Beyond Stumped, it was 1.75 inches difference before and it was unbearable. Now it’s very livable. Truck is “done” now.
    forgot to update this thread but in supercharger thread I took it to national speed first week of August to go from stage 1 to stage 3. Long story short we have 499.03 wheel horse power on the 37 inch tires on 93 pump gas when it was all said and done. Trucks fun to drive. On to next project. Saving for a new house (I need a garage. My townhome isn’t cutting it)
  23. Aug 27, 2025 at 4:47 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
  24. Aug 27, 2025 at 5:37 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    I actually used Valvoline Maxlife Power Steering Fluid since that’s all I could get my hands on locally. I plan to swap out for Valvoline Maxlife ATF soon though. That’s what I’ve always used in previous vehicles
    HulkSmurf14, BR73 and joseph_womack like this.
  25. Aug 27, 2025 at 6:25 PM
    joseph_womack
    Joe
    Louisiana
    What’s the recommendation for power steering? Maxlife ATF? Toyota branded PS fluid?
    HulkSmurf14 likes this.
  26. Aug 27, 2025 at 6:26 PM
    joseph_womack
    Joe
    Louisiana
    Just toss a coachbuilder shim on the driver side and be done; but if they did adjust the shocks give it a day or two to settle
    BR73 likes this.
  27. Aug 27, 2025 at 11:15 PM
    Trd_Jason
    Trd_Jason New Member
    2021 Tundra sr5
    Come a long way in the last 5 years of ownership. Love it more now than my first drive home.
  28. Aug 28, 2025 at 12:58 AM
    WinterWarlock21
    South Jersey
    have them but they don’t fit. Bolts on the top of coilover don’t have enough length to throw a shim in and then get a nut on the top. That was my first solution lol. Only thing left is buy a new top hat from kings without the bolts pressed in and do that myself with longer bolts. Pain in the butt.
