Transmission
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jake.Stoefen, Aug 24, 2025.
  1. Aug 24, 2025 at 6:39 PM
    Jake.Stoefen
    Jake.Stoefen [OP] New Member
    Jacob
    2015 tundra SR5 with 292K
    None
    2015 Tundra has 292K. Today I put it in drive and it didn’t feel like the transmission engaged (converter slip) I out the trans back in park and then drive again. Drove off with no issues. I have also noticed what feels like a miss or converter slip. I notice this as a couple short jerks and then all is better. This only happens between 1200 and 1900 RPM. Anyone else have this issue and if so, what was the fix? Help appreciated.
  2. Aug 24, 2025 at 6:59 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I'm sure this'll get moved by moderators, but: you're in the 1st gen Tundra section of the forum. 1999-2007.
    But I hope you get your tranny issues resolved!
    Bob likes this.
  3. Aug 24, 2025 at 7:14 PM
    Have you checked the fluid level?
    Jake.Stoefen[OP] and blenton like this.
  4. Aug 24, 2025 at 10:03 PM
    blenton
    blenton New Member
    ... or changed the fluid ever?
    Mdl and reywcms like this.
  5. Aug 25, 2025 at 3:19 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I think that the questions about transmission service (fluid change) are valid. These transmissions are rock solid but if the fluid is neglected it can cause wear in the valve body. This wear causes sticking solenoid valves which lead to hung up and incomplete shifts. You have to give us more to go off from if you want help.
  6. Aug 25, 2025 at 7:04 PM
    4.7L2UZFEbestengine
    4.7L2UZFEbestengine New Member
    2021 Tundra SR5 SX Doublecab
    If your AT fluid is the factory original, your only option is to do a simple drain and fill. And afterwards pray that fixed the issue because if the problem remains, chances are you’re going to need a whole new transmission. No such thing as lifetime ATF.
    Jake.Stoefen[OP] likes this.
  7. Aug 25, 2025 at 7:24 PM
    Jake.Stoefen
    Jacob
    None
    ATF has been changed in the trucks lifetime. The last one I can 100% remember is at 115K. I cannot remember doing it at 200K. I added some seafoam trans tune to it tonight and will run that for a few days then change the fluid. The tranny slipping is a guess. I suppose this could also be a mid rpm misfire. However, no code is thrown.
