Rock Warrior club
Discussion in '2nd Gen Tundras (2007-2013)' started by Medicth, Jan 6, 2014.
  1. Jul 17, 2025 at 11:27 PM
    #781
    Ashante94
    Ashante94 New Member
    2011 Rock Warrior
  2. Jul 24, 2025 at 1:14 PM
    #782
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  3. Jul 24, 2025 at 1:14 PM
    #783
    ToyoMafia
    Magic carpet.
  4. Jul 24, 2025 at 1:28 PM
    #784
    ToyoMafia
    Magic carpet.
  5. Jul 24, 2025 at 2:10 PM
    #785
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    COTundra23 likes this.
  6. Jul 24, 2025 at 2:32 PM
    #786
    COTundra23
    COTundra23 New Member
    Looks so good
    ToyoMafia[QUOTED] likes this.
  7. Jul 24, 2025 at 6:12 PM
    #787
    ToyoMafia
    Magic carpet.
    :fistbump:
    COTundra23[QUOTED] likes this.
  8. Jul 24, 2025 at 6:55 PM
    #788
    ToyoMafia
    Magic carpet.
  9. Jul 25, 2025 at 10:47 AM
    #789
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    those red beadlocks are a choice. keep on truckin'
  10. Jul 25, 2025 at 7:42 PM
    #790
    ToyoMafia
    Magic carpet.
    You prefer pink?
    TRDFerguson likes this.
  11. Jul 25, 2025 at 7:45 PM
    #791
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    “Beadlocks”
    OldGuy03 and ToyoMafia like this.
  12. Jul 25, 2025 at 7:46 PM
    #792
    ToyoMafia
    Magic carpet.
    All show no go.
    OldGuy03 and TRDFerguson[QUOTED] like this.
  13. Jul 25, 2025 at 8:30 PM
    #793
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    Only your mom’s
    OldGuy03 likes this.
  14. Jul 25, 2025 at 8:41 PM
    #794
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I did a few days in Sedona at about 8.5-9 lbs which I think basically means they are the real deal.
  15. Jul 25, 2025 at 8:44 PM
    #795
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Definitely something like that :rofl:
  16. Jul 26, 2025 at 4:16 AM
    #796
    ToyoMafia
    Magic carpet.
    Perfect research
    OldGuy03, TRDFerguson and Leo's first like this.
  17. Jul 31, 2025 at 9:09 AM
    #797
    rphass17
    rphass17 New Member
    What Brake parts did you end up going with? Also did you replace the cam bolts ow did that go?
  18. Jul 31, 2025 at 9:20 AM
    #798
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    cam bolts are easy to replace. It's getting them off that's the hard part. slather 'em in PB blaster for a few days and wish for the best. mine had been replaced at some point and luckily the previous owner covered everything in anti-seize so i was able to use three of the four sets of bolts.
  19. Jul 31, 2025 at 12:07 PM
    #799
    gelsi2033
    gelsi2033 New Member
    2011 TRD Rock Warrior MGM
    Bilstein 6112/5100 Archive Lift Shackles
    OEM pads/rotors and calipers. Stop tech steel brake lines. Breaking it all down next week to start this, but I am expecting it to take a few weekends. I will post an update when I am working on it. Just have not had the time yet. I fully expect to have to cut the LCA cam bolts. Even bought some new blades for the Sawzall. No doubt they are seized after 14 years.
    grave likes this.
  20. Aug 12, 2025 at 7:55 AM
    #800
    gelsi2033
    Hello everyone. Update to 2011 RW I purchased 8 months ago. Finally got around to tearing the front end down only to realize I needed help. Everything was original and 14 years old and needed a little extra attention/persuasion.
    There were too many areas in need of extra attention requiring skills beyond my ability, so I enlisted the help of a local fabricator and friend who has helped me build out my Tacoma over the years.
    Front end is complete. Rear is next.
    Front end refresh includes new Bilstein 6112, notch 2 = 1.3", new lower shock bolts, new OEM UCA, LCA, new UCA bolts, new LCA to spindle bolts, new SPC cam bolts (they were seized and required cutting).
    He had to cut into frame for sway bar brackets and weld in new plug nuts to secure brackets. Also had to cut into bump stop mounts and reweld/patch to remove stripped welded nuts and weld in new ones. New inner and outer tie rods installed. New calipers, rotors, pads and steel brake lines. Dust shields were corroded enough that they needed to be removed so we cut most of it out and just left a small square to remain as a spacer between hub assembly and spindle. Hubs/bearings, seals all in good shape and were not replaced.
    I will post before and after pics when it is all done.
    Leo's first, rphass17, AZEric and 2 others like this.
  21. Aug 13, 2025 at 6:17 AM
    #801
    rphass17
    rphass17 New Member
    Looks really good I have yet to do my front shocks and bump stops hopefully I can get the old ones out.
    Are the cam bolts not available from Toyota or reason for going with SPC cam bolts?
  22. Aug 13, 2025 at 6:32 AM
    #802
    gelsi2033
    No issue really getting any parts for this year truck from my local Toyota dealership. Some items would have been special order (inner and outer tie rods for example so I went with Moog to get them quickly). SPC only for the front, OEM in rear. Only reason I put SPC up front is because there is less chance of them seizing. We did coat in anti seize before installing so either way should be fine.
  23. Aug 25, 2025 at 6:02 AM
    #803
    gelsi2033
    Before and After of my 2011 RW. Suspension and Brake refresh complete.
    I test fit some 1.25 spidertrax, but did not like the stance, so I removed them.
  24. Aug 29, 2025 at 4:43 AM
    #804
    rmiller139
    rmiller139 New Member
    2011 Tundra DC
    Eibach 2R kit w/ Icon UCA BAK revolver
  25. Aug 29, 2025 at 6:57 AM
    #805
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    The biggest upgrade is the wheels. Having those, you're no wanna be.
  26. Aug 29, 2025 at 10:41 AM
    #806
    rmiller139
    2011 Tundra DC
    I just picked up a SR5 Grill from the junkyard. I'm planning to get it painted along with the mirror caps and door handles. Slowly but surely it will look the part!
    OldGuy03[QUOTED] likes this.
