2022 wiper blade replacement.
Discussion in '3rd Gen Tundras (2022+)' started by Weimer369, Jan 13, 2023.
  1. Feb 28, 2025 at 10:16 AM
    #61
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My passenger side wiper has never fully cleared the windshield towards the upper third of the wiper blade, even when brand new. I notice it most when I need to clear dirty road spray off the windshield. Driver's side works as it should.
    I just pulled the wipers off, and I can't find any visible wear, or reason for the faulty performance of the passenger side. The original inserts appear to still be in great shape. I was hoping new inserts would make a difference, but now I'm not sure.
    Any ideas why my passenger side wiper has never functioned properly?
  2. Feb 28, 2025 at 12:33 PM
    #62
    Reubenski
    Reubenski New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    Tag
  3. Feb 28, 2025 at 12:48 PM
    #63
    Matt2015Tundra
    2023 1794 CrewMax
    I might have figured out why my passenger side wiper has always been faulty.
    Upon closer inspection, I found a slight bend in the wiper body. I bent it back the best I could, then replaced the insert. Hopefully that fixes it. If not I'll replace the entire wiper blade.
    Is it just me, or do the OEM wipers seems extremely flimsy compared to other wiper blades?
  4. Mar 1, 2025 at 5:09 PM
    #64
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    Not just you, I agree…
    While snow brushing off the windshield I must have gotten the brush behind the wiper and bent it enough that it would leave a streak in the middle.
    I tried to adjust it back but no go with that.
    So, I just moved it to the passenger side and let my wife enjoy it.
  5. Mar 2, 2025 at 5:12 AM
    #65
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    Just replace the entire blade which comes with a new insert. It's the same price ($25) as a Bosch wiper blade
    https://partsouq.com/en/catalog/gen...-SgobIAAAAABoJyOg=$&vid=0&cid=3&uid=449310&q=
  6. Jul 3, 2025 at 7:20 PM
    #66
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Is it pretty obvious how to swap out the inserts? They look like one solid piece?
  7. Aug 6, 2025 at 12:03 PM
    #67
    Ben550
    Ben550 New Member
    Tundrastruck91 and snogirl like this.
  8. Aug 7, 2025 at 6:33 PM
    #68
    snogirl
    snogirl New Member
    judy
    Vermont
    2024 TRD Sport Premium Crew
    Thank you! I just ordered a pair from Rock Auto $47 to my door. My passenger blade has never fully cleared since truck was new as others said in this thread. Now at 16 months in, I will just put new blades on before another Vermont Winter rolls around.
  9. Aug 8, 2025 at 9:04 AM
    #69
    Ben550
    Ben550 New Member
    I want to see how these trico silicone ceramic blades hold up. See if they last as long or longer than the bosch icons
    snogirl[QUOTED] likes this.
  10. Aug 8, 2025 at 9:16 AM
    #70
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Can’t go wrong with the Toyota OEM for longevity and ease of install. Put the first replacement pair on in June of this year and Safelite is trying to sell me a new pair at 35.00 because “ the crack probably released shards of glass that will scratch the new windshield.”
    I do clean with alcohol and apply some protectant to the blades every once in a while if I notice streaking on the windshield. This helps a lot with the performance of the blades as well.
    TundraDan723 and raylo like this.
  11. Aug 8, 2025 at 9:25 AM
    #71
    75tranzam
    Midlothian, Va
    I've used them for both my truck wiper inserts as well as some 2017 Toyota Camry parts I've needed. Usually ships within a weekend the products are packed well and in original Toyota packaging including part #'s. I hate paying for an OEM part and getting it and it's been taken out of it's original packaging, no reason for that!
  12. Aug 14, 2025 at 5:37 PM
    #72
    a71rambler
    a71rambler New Member
    Kitsap County, WA
    '25 Lunar Rock Limited w/TRD OR and Performance Package
    A bunch...
    Reporting back on some testing.
    As posted a few months ago in this thread, I have had PIAA Silicone wipers on past cars and trucks. I have never had any issues with them and they always perform brilliantly here in the PNW (wet).
    I bit the bullet and ordered these from Amazon - PIAA 97060 https://tinyurl.com/2ane5gq9 They fit perfectly using the correct adapters.
  13. Aug 22, 2025 at 12:22 PM
    #73
    sc taco
    sc taco New Member
    2023 Tundra 1794 TRD
    Thanks.
  14. Aug 24, 2025 at 12:29 PM
    #74
    stretch2323
    stretch2323 New Member
    So they are both the same size 24”?
  15. Aug 24, 2025 at 3:24 PM
    #75
    TundraDan723
    This is my understanding. I can not find the drivers side refill part listed on the Toyota parts website. They are both 24" blades, so I just ordered two right side refills in hopes one fits the left. They haven't arrived yet, so I can't confirm. Will post update when I receive them.
    Korj26, Tundrastruck91 and kirkb like this.
