  1. Aug 22, 2025 at 6:23 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Be sure and go OEM on gauge sensor. I bought a cheap one for my old camry a long time ago and the gauge reads way off.
    As stated if you can hook up an OBD scanner and temps show proper you don't need to replace the ECU sensor only the gauge.
    Voss[QUOTED] and BroHon like this.
  2. Aug 22, 2025 at 2:00 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Ya it’ll be OEM. Gonna change both since I’m in there.
  3. Aug 22, 2025 at 3:12 PM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I just ordered a Prinsu rack for it, nice to have the extra storage.
  4. Aug 22, 2025 at 3:31 PM
    Your gas mileage will say otherwise
  5. Aug 22, 2025 at 3:33 PM
    Aerindel
    Aerindel New Member
    Montana
    It's a tundra.....as long as MPG is a positive number it's good.
  6. Aug 22, 2025 at 3:36 PM
    On our 4r I’d say we took a 3-4mpg hit putting a hipster gobi rack and ladder on it; the ladder is absolutely useless and we use the rack on average .5 times a year(before the tundra we used it more)
    FirstGenVol likes this.
  7. Aug 22, 2025 at 4:08 PM
    Voss
    2003 AC TRD 4x4
    Interesting. My MPG improved with my roof rack. Then again I had my tent up there free ballin b4. Feel the rack eased the hit on the tent. Got like 1mpg better
  8. Aug 22, 2025 at 4:09 PM
    CORNELIUSGUN
    CORNELIUSGUN New Member
    2006 DC SR5 TRD 4x4, Blue
    EZ Lift ARE High-rise Camper Topper
    Timing belt and sway bar links put in at 183k miles!
    BE WARNED: the seller of mine said he changed it at 100k. The condition of the belt did not look like it…. Looked original - I gasped when inspecting. Be sure to look at that!
    shifty`, G_unit3000 and Voss like this.
  9. Aug 22, 2025 at 4:49 PM
    ATundraPersons
    ATundraPersons Lessons Learned, Money Burned...
    2001 Thunder Grey Tundra SR5 Access Cab 4.7
    Bilstein 4600s
    Parts came in and I've dealt with my window problem. Windows now work fine. Also had time to restore the plastic on the bumper and side trim. Used Solution Finish Plastic Restorer recommended by JDMDriveway on Youtube. Worked great. Truck looks way better with the plastic restored.thumbnail_IMG_2661.jpg
  10. Aug 22, 2025 at 5:17 PM
    manofsteele2003
    Eh, not concerned with gas mileage, all my shit is in the teens anyways.
  11. Aug 22, 2025 at 5:20 PM
    Same on my wife’s JGC. Dropped from 23mpg hwy to 19mpg.
  12. Aug 23, 2025 at 10:50 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Pulled the starter out, and cleaned up a bunch of mouse poop. Seems like a good time to replace the O ring in this crossover pipe too...
    jerryallday, shifty`, BroHon and 7 others like this.
  13. Aug 23, 2025 at 12:10 PM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    Love these updates. Keep em coming! Great for documentation as well.
  14. Aug 23, 2025 at 4:40 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Picked up this clean ARE cap for $300, from a junkyard in Killeen, TX today. Thanks for the hot tip @Mohoman
    Also got my truck re-tuned, so I could remove the Hewitt bypass.
  15. Aug 23, 2025 at 6:09 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I bought these with some self tappers. Work great. I run 3 laches at the top. You should be able to use just the tops since your laches are still good. They do break over some time if you drive a lot on dirt roads and like to party. so I replace them like every year as they break/needed
    Prime-Line F 2532 Slim Line...
  16. Aug 23, 2025 at 9:10 PM
    Mohoman
    Mohoman TTC 165
    Hell yeah, glad you were able to find pick one up!
  17. Aug 23, 2025 at 9:44 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    All the cogs worked together to make it happen. Casey let me leave the old blue one on his property and Beau is going to come get it eventually.
  18. Aug 23, 2025 at 10:35 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Seen this on OfferUp today during my daily search for 1st gen parts or deals
    been seeing a lot of broken radiator caps recently were the spring breaks and falls into the radiator. looks like this guy got it bad. I seen other post say it ends up by the thermostat when it breaks. I wonder what cost it to lock up
    Check out this item on OfferUp. https://offerup.co/VFG0j1Sn5Vb
