abs light traction light brake light
Discussion in '2.5 Gen Tundras (2014-2021)' started by jeff33, Aug 22, 2025.
  1. Aug 22, 2025 at 4:11 PM
    jeff33
    jeff33 [OP] New Member
    jeff
    2014 toyota tundra 1794
    no
    2014 tundra 1794 dash light all on abs -traction - brake - 4hi low - tpms - truck was in minor crash damage to right rear corner
    no communiation with brake mod skid mod vdc mod
    codes p0500 - u0129 - u0122 -
    any help would be great
  2. Aug 22, 2025 at 9:18 PM
    Fergie
    Fergie New Member
    Check out this link here:
    Flashing 4lo/4hi is now a no start, stuck starter issue?
    Use a good bi-directional scanner to determine the codes from each wheel sensor. If it was in crash, that right rear harness to the sensor, and the wheel speed sensor itself could be damaged.
    The scanner at Oreillys, Pep Boys, or Autism Zone typically aren't sufficient for what you need.
  3. Aug 22, 2025 at 10:00 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I second wheel sensor as well.
    Fergie likes this.
  4. Aug 23, 2025 at 5:01 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Wheel speed sensor or abs sensor is either broke, or the wiring for it is.
