Low Fuel Warning
Discussion in '3rd Gen Tundras (2022+)' started by RDean, Apr 5, 2025.
  1. Apr 5, 2025 at 9:19 AM
    RDean
    RDean [OP] New Member
    2025 SR5 4x4
    My 25 Tundra has the larger 32 gallon fuel tank. However distance to empty can be under 25 miles and the most I can put in the tank is around 25 gallons? With 7 gallons in the tank why is distance to empty less than 25 miles?? I would expect to put closer to 30 gallons in the tank at full up.
  2. Apr 5, 2025 at 9:35 AM
    Maine TRD PRO
    Maine TRD PRO New Member
    2023 Ice Cap Tundra TRD PRO(Rioja Red interior)
    Asked and answered
  3. Apr 5, 2025 at 9:40 AM
    Observer
    Observer New Member
    Not a mechanic but for the sake of discussion: Quick search states:
    "When the fuel gauge on a 2022 Toyota Tundra (with a 32-gallon tank) indicates "empty," there are typically around 4-6 gallons of fuel remaining in the reserve." As I understand fuel pump is in tank and part of the reason is that the fuel keeps you fuel pump lubricated and cooled. Another search states Toyota keeps approx. 10-15% of fuel in reserve, which would be about right for your 32 gal. tank.
    addition 04/06/25 : Thinking back my dad had a old rambler and I distinctly remember a trip in which he put somewhere around 90 miles on the car after the gauge read empty. He pretty much knew how far he could get on empty. He ran out of gas just as he pulled up to the gas pump.
    RDean[OP] and Raven67 like this.
  4. Apr 5, 2025 at 10:27 AM
    kjinxx2
    kjinxx2 New Member
    If you're towing heavy you'll be thankful for the reserve 7 gallons especially if you get caught in traffic or the middle of nowhere - I believe that is the primary driver to the massive reserve... the mileage can vary so drastically w/ these trucks that people who aren't really paying attention would run out of gas and then blame it on Toyota.
    RDean[OP] and Breathing Borla like this.
  5. Apr 5, 2025 at 11:27 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I'd rather have roo much than too little! Although I never let my truck get below 1/4 tank anyway.
  6. Apr 5, 2025 at 2:05 PM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
  7. Apr 5, 2025 at 5:27 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Long as I drive mine I will never know if low fuel light works or not. I refuse to pump $100 in it all at once.
    CHESSIEMAN likes this.
  8. Apr 5, 2025 at 5:51 PM
    Breathing Borla
    AZ
    this ^
    towing , you’ll be happy to have that reserve fuel
    RDean[OP] and PNW Tundra Mike like this.
  9. Jul 26, 2025 at 8:16 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Just resurrecting an old thread to include my recent experience.
    Yesterday, on our return trip to Colorado from a fly fishing adventure in Montana, with our drift boat in tow, I tested the limits of my '23 Tundra's fuel tank further than ever before. I ran it until it was showing 4 miles to empty. At the pump, I put in 29.8 gallons.
    So, at least on my truck, it appears to have about 2 gallons of reserve fuel when the MTE is at 0, not 6-7 gallons that others have reported.
    oddhours and Reciprocal like this.
  10. Jul 26, 2025 at 8:36 AM
    kjinxx2
    kjinxx2 New Member
    When did your low fuel light come on though - that is when I would consider that you're running on 'reserve'. When the low fuel light comes on you have ~6-7 gallons left. The MTE is unreliable especially while towing. If you weren't towing during the entire calculation period then MTE will bias toward more miles than are actually available (because your average MPG is biased up).
    Nm6300'asl likes this.
  11. Jul 26, 2025 at 9:59 AM
    Matt2015Tundra
    2023 1794 CrewMax
    The low fuel light came on at 20 MTE. At that time, the display was showing 15.1 mpg due to towing into a stiff headwind. Any way I slice it, there was no more than 3 gallons in the tank when the low fuel light went on, not 6-7 gallons.
    I actually pushed it a lot closer than I normally do because I remembered guys claiming the reserve was 6-7 gallons. That wasn't the case for my truck, yesterday.
    I just wanted to forewarn folks that there might not be as much reserve as you think.
  12. Jul 26, 2025 at 11:04 AM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    Farmers Branch , Texas
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    I dipped mine down to 8 mile till empty last week. Was going to the field and back to field trailer for important work and kept forgetting to get fuel till it said 8 miles till empty
  13. Jul 27, 2025 at 5:52 PM
    kjinxx2
    kjinxx2 New Member
    That's why I asked if you were towing the boat for your entire tank of gas. 15.1 MPG seems high for towing.
  14. Jul 27, 2025 at 7:14 PM
    Matt2015Tundra
    2023 1794 CrewMax
    It’s a small drift boat.
    Tundrastruck91 and 22whatwedo like this.
  15. Jul 27, 2025 at 8:12 PM
    kjinxx2
    kjinxx2 New Member
    Got it - you got me scratching then.
    The way I solve for gallons left is taking my miles per tank (I reset TRIP A each fill) divided by average mileage per tank (which automatically resets each fill as well). That tells you how many gallons you've consumed - it's been reliably at ~25/26 gallons each time the low fuel light has gone and it's confirmed then when I fill up. I don't follow MTE at all, period.
  16. Jul 28, 2025 at 6:37 AM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    My experience has been 2-3 gallons as well once the low fuel warning comes on
    Matt2015Tundra likes this.
  17. Jul 28, 2025 at 9:33 AM
    Matt2015Tundra
    2023 1794 CrewMax
    On page 516 of my '23 Owners Manual it says the Low Fuel Warning Light..
    "Indicates the remaining fuel is approximately 3.4 gallons, or less".
    This is consistent with my experience.
    Tundrastruck91 and MAC25Tundra like this.
  18. Jul 28, 2025 at 11:07 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Thanks Matt. Good to know there is a light. I’ve not pumped in more than 28 yet and that still wasn’t on empty. I think MTE was about 80.
  19. Jul 28, 2025 at 11:58 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Your weellcome. Theres a low fuel light and a Low Fuel warning message that pops up. Both came on at 20 MTE on my truck. You can get rid of the warning message by hitting the Back button on your steering wheel. The low fuel light remains on until you add fuel.
    I travelled 16 more miles after the warning light turned on. That should have consumed about a gallon of fuel at the mileage I was getting at the time. I filled the tank at 4 MTE, and put in 29.8 gallons. So, the Owner's Manual's claim of 3.4 gallons, or less, of reserve when the warning light comes on appears to be spot on.
  20. Aug 22, 2025 at 10:55 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Grand Highlander HV is getting a software logic update for low fuel warning light. They have similar complaints as some tundra owners have with the low fuel light coming on earlier than they like.
