Service recommendations for 2012
Discussion in '2nd Gen Tundras (2007-2013)' started by Jjcjmc2323, Aug 21, 2025.
  1. Aug 21, 2025 at 5:52 PM
    Jjcjmc2323
    Jjcjmc2323 [OP] New Member
    2012 Tundra Crewmax Platinum 5.7L 4x4
    I just inherited my father's 2012 Toyota Tundra Crewmax Platinum edition 5.7L 4x4. It has 85,000 miles. I know my father kept the oil changed on a regular schedule. I don't think he has done anything outside of that other than new brakes. What preventative maintenance do I need to have done at this mileage? Plan on keeping the truck for a long time.
  2. Aug 21, 2025 at 6:20 PM
    TRDGoodness
    TRDGoodness Not new, but not old either
    East Coast
    2020 Ram 2500 Tradesman 6.4L gas; ZF 8 spd Transmission
    Front and rear diffs fluid change. Transfer Case fluid change. Check your belts, Tension pulleys, belts (timing belt for sure and the pully for this. Mine blew and the only thing keeping it on was prayer. Ran it for about 500 miles before finding that one!) Air filters. If you want to go even more, do an engine clean, and then have your fuel injectors cleaned as well from carbon.
    Others, that know more can help better, but there is a lot of wisdom here. This would be my start list.
    Also check tires to see if needed to be rotated.
  3. Aug 21, 2025 at 8:05 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    If it’s a 5.7 it has a timing chain, not a belt. I would do the above, and add in new coolant, plugs either now or at
    100k, brake fluid, and a transmission drain and fill. Sorry about your dad…
    Tripleconpanna likes this.
