Grease questions
Discussion in 'Off-Topic Discussion' started by Bayou Spartan, Aug 20, 2025.
  1. Aug 20, 2025 at 11:04 AM
    Bayou Spartan
    Bayou Spartan [OP] New Member
    Black 2019 TRD PRo
    None
    Good Day everyone.
    I thought that at one point i had read on here the best general purpose greases but I can not seem to find it via search.
    I have two things that I’m looking for feedback on.
    one is what General purpose greases do you use and what do you look for when selecting the greases based on purpose
    second.
    I have an echo weed eater that has a grease point. Have you ever taken the time and disassembled cleaned and lube / grease your weed eater.
    What’s your frequency and did you see any noticeable improvement ?
  2. Aug 20, 2025 at 1:47 PM
    AZBoatHauler
    So.Arizona
    I use red and tacky for most applications.
    I live in the desert so I can't help you with weed eaters. Just rocks, dirt, cactus and fake grass around here.
  3. Aug 20, 2025 at 2:06 PM
    CoffeeAddict
    CoffeeAddict New Member
    2016 Tundra CrewMax
    Mystik JT-6 High Temp #2 Grease for pretty much everything unless you're talking specialty stuff or marine applications. Easily one of if not the best general purpose greases available. Red and tacky separates just sitting there.
    https://www.mystiklubes.com/Product.do?code=665005002
    Can't help you on weed eaters. I don't put huge time on mine so when I say they last ten years with no grease maintenance that may not help you at all.
  4. Aug 20, 2025 at 2:21 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I have a stihl kombi weed eater attachment. I actually do grease it with stihl grease. It has a bolt you back out, grease tube (like toothpaste) threads into it and squeeze. I dont know what kind of grease it is though.
  5. Aug 20, 2025 at 2:48 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    I’ve been using marine grease if I remember right, it’s been working well
  6. Aug 20, 2025 at 2:58 PM
    2mchfun
    Screenshot_20250820-171433.png When the grass gets too tall, I soak the yard and do donuts in the Tundra for ten minutes. No weedeater needed, but it takes three days to wash my damn truck!:mudding::headbang:
  7. Aug 20, 2025 at 7:30 PM
    Bayou Spartan
    Black 2019 TRD PRo
    None
    Thanks ALL
    just made it in and was watching Foghorn Leghorn compilation. That was effortless laughter.
    I will get both the red tack and the Mystic
    I appreciate the input. Outside of the weed eater , it’s just generic stuff to grease up.
  8. Aug 20, 2025 at 7:36 PM
    centex
    centex New Member
    Lucas red and tacky for everything. Wheel bearings, suspension, steering, if it requires grease, it gets red and tacky. 25yrs with no issues so I’m gonna say it’s fine.
    AZBoatHauler likes this.
