Disable Day Time RL’s ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockanock, Dec 15, 2019.
  1. Dec 15, 2019 at 7:15 PM
    Rockanock
    Rockanock [OP] 21 Chevy 2500
    I am curious, is it possible to turn off your daytime running lights and blinkers still work? I actually think they look cool but I’d like to be able to turn them off and on at will.
  2. Dec 15, 2019 at 7:28 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Put the foot brake on 1 click before you start up the truck. Then let us know.
    Rockanock[QUOTED][OP] likes this.
  3. Dec 15, 2019 at 7:42 PM
    Whocares
    Whocares Member
    wyoboypt likes this.
  4. Dec 15, 2019 at 8:35 PM
    Rockanock
    This won’t hurt anything? And blinkers will work?
  5. Dec 15, 2019 at 8:41 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    1 click? Probably wouldn’t even really engage much. Doubt it would hurt. But now that I think of it you’d probably have the dash beep at you with the audible brake engaged warning.
    It will kill the DRL feature. That’s all I know. That’s why I said “let us know.” :p
  6. Dec 16, 2019 at 11:50 AM
    Rockanock
    Lol that’s true. I think I’ll pass on that route!
  7. Dec 16, 2019 at 11:52 AM
    Rockanock
  8. Dec 16, 2019 at 1:37 PM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    I added a disable switch to my second gen when I added a usb plug, added tire pressure sensor system and moved my rear window switch.
    Everything works like normal wether they’re on or off.
    Very easy job. Only had to splice into one wire. Even with soldering the new switch wires in the job only took about 20 minutes.
    I used a $1 rocker switch, some wire and heat shrink.
    longest part was getting a perfect fit for the new switch. I think I made a write up on it here or on another forum. I’ll see if I can find the link...
  9. Dec 16, 2019 at 1:40 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Couldn’t see what headlights you have but I used a @iHacker harness and was able to splice a wire under my dash to disable my DRL lights but they still work as blinkers. I have a 2016 SR5. I am running the OEM led headlights but I think this will work for halogens.
  10. Dec 16, 2019 at 2:15 PM
    Arcstriker29
    Arcstriker29 New Member
    Ben
    2020 Toyota Tundra SX Double Cab
    Side steps, Bed cover, Bed LED light strips under rail. More to come
    On my 2020 Tundra, I thought I saw an option for them in the settings using the steering wheel controls in the mini display in the instrument panel. I could be wrong tho
  11. Dec 18, 2019 at 5:31 AM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    The video probably shows it the same as I searched and found. That gray module you see in the eBay link is the same one you have under your dash. under the switch panel to the left of the steering wheel. There is a gray wire you cut and it will disable the DRL. Everything else still works as normal. if you want it to be an on and off feature, just put a toggle switch of some sort in-between the wire once its cut and it can be turned on and off. Not sure for whatever reason you want it to do that though.
    https://www.tundras.com/threads/help-with-disabling-the-orange-drl-on-2016-sr5.16347/
    That is the link I followed to disable mine.
  12. Dec 18, 2019 at 5:35 AM
    If memory serves me right, it only works until you place it in drive.
    Rebel Tundra Man likes this.
  13. Dec 18, 2019 at 9:23 AM
    SIMPLYTHETRUTH
    SIMPLYTHETRUTH THE ALBINO RHINO
    PA
    2020 Cement TRD
    S&B Cold Air Intake, Recon light bar, Rough Country light bar, Cali ditch lights, aFe throttle spacer,
    On my way 19 on the radio setting setup vehicle setting under lighting I can turn off drl.
  14. Dec 18, 2019 at 10:28 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    My headlight switch on my 2018 turn signal column has a "DRL Off" setting. Does yours not have this?
    NorthWoodsTundra likes this.
  15. Dec 18, 2019 at 6:27 PM
    SIMPLYTHETRUTH
    PA
    2020 Cement TRD
    yes mine has a switch, can also turn off in apps, vehicle, vehicle customization, light settings
  16. Dec 18, 2019 at 7:17 PM
    biebs96
    PA
    I did this on my 2010. I would like to know how to do this on my 2017.
  17. Aug 18, 2025 at 3:23 PM
    subspd
    subspd New Member
    Seth
    SW Florida
    2015 Tundra Platinum 4x4
    Magnuson Supercharger - TRD Exhaust - TRD BBK
    Is this grey box on a 2015 as well?
  18. Aug 19, 2025 at 12:50 PM
    Shadowfax1
    Shadowfax1 New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    Why? Just curious.
