Brake Rotors and Pads
Discussion in '3rd Gen Tundras (2022+)' started by lstundra, Nov 10, 2024.
  1. Nov 10, 2024 at 5:55 PM
    lstundra
    lstundra [OP] New Member
    2022 Blueprint Tundra Platinum 4x4
    Wheels and tires
    I currently have a 2022 Tundra Platinum 4x4 (it's new to me) and the brakes started squealing. It currently has 44k miles on it and I wanted to upgrade the brake pads and rotors front and rear for this coming winter season. I did a lot of google searching but everytime I click a link, it shows "This Product is NOT compatible with the 2022 Toyota Tundra" or it is sold out. I also read some threads in here to see if somebody left a link somewhere for what they got. Why is it so hard to look online for a brake rotor and pads for 3rd gen Tundra? Can anybody share a website where they get their brake parts off? I am not considering OEM replacement for now.
    P.s. New to this forum pls be kind lol
    Spartanfam likes this.
  2. Nov 10, 2024 at 6:00 PM
    lstundra
    Wheels and tires
    Do I need to be worried about compatibility for the rotors and pads or can I just slap on any Akebono pads to any Powerstop rotors?
  3. Nov 10, 2024 at 6:04 PM
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
    Ditto… striking out on too much selection of aftermarket rotors and pads on RockAuto or other sites. No Centric or StopTech offered yet either.
  4. Nov 10, 2024 at 6:07 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I have always gone with oem rotors and pads…..never allowed dealers to turn them; just asked to replace them. RAV4, 4Runner and tundra - hasn’t let me down and they last so much longer
    mverkaik and Tundrastruck91 like this.
  5. Nov 11, 2024 at 8:45 AM
    smileytn1
    smileytn1 New Member
    Hello everyone! I have a 2022 Limited and the pads and rotors are a little different due to the hold feature on the truck and the front rotors pistons are different from the back that is just my understanding.I complained to the dealer about the squeal and they are going to do a recall on it with new pads. I have been use to hearing a squeal on gm and fords after it setting a little while oxidation would have to wear off the rust but this one they assured me they could fix. Just for what its worth will know more in a couple days after the mechanic does the work and shows it to me.
  6. Nov 11, 2024 at 9:17 AM
    Spartanfam
    West Michigan
    ... I have a theory on my rotors/pads. My truck shakes it's tail when I stop which tells me I have hot-spots on my rotors.
    1) I've read that many radar cruise controls utilize the rear brakes to control speed
    2) The APB (automatic parking brake) utilizes the rear brakes, although you can disable the APB.
    I (stupidly) used the radar cruise towing my camper through the App Mtns this past spring, not realizing the engine braking was doing less than the rear brakes to control my speed. At every rest stop, gas station, etc... my APB engaged the same hot rear rotors and VOILA... hot spots.
    Just my own theory, but I'll be replacing my rotors and pads once I find some aftermarket ones worth a hoot. Not sure if DFC (Dynamic Friction) or PowerStop are great, or not. I've always used Centric/StopTech or Brembo.
    Tundrastruck91 likes this.
  7. Nov 11, 2024 at 2:24 PM
    RVer
    RVer New Member
    2023 Platinum CrewMax
    That is correct. When I'm towing my trailer and running cruise control I select the brake controller display on the left info screen. When I see the truck actuating the brakes I suspend the cruise control until I'm on a straight section of road again not requiring braking.
    Spartanfam[QUOTED] likes this.
  8. Nov 11, 2024 at 2:49 PM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    https://autoparts.toyota.com/search...DRA&model_year=2022&model_year_code=2022:8341
    23 Platinum and Spartanfam like this.
  9. Nov 13, 2024 at 6:50 AM
    Platinum_Tundra
    Platinum_Tundra New Member
    2023 Platinum Tundra
  10. Nov 13, 2024 at 5:11 PM
    Spartanfam
    West Michigan
  11. Nov 14, 2024 at 3:56 AM
    Platinum_Tundra
    Yes, I have used them on my 2010 Tacoma and 2019 SRT. They have outstanding stopping power and minimal brake dust; the rotor and pads last a long time.
    If you upgrade to these brakes and rotors, you will feel the difference. For ultimate stopping power, add steel brake lines.
    Steel brake lines makes a significant difference even on OEM pads and rotors because they don't heat up as fast as the rubber OEM brake lines and will eliminate brake fading.
    Tundrastruck91 and Spartanfam like this.
  12. Nov 14, 2024 at 6:37 AM
    David713
    David713 New Member
    2023 Tundra Platinum
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    I'm a very big fan of Porterfield 4S pads for my trucks and put them on my '23 Tundra shortly after I got the truck. I think they're better than OEM and do recommend them even tho they're pricy but I did not find them to be dramatically better than Toyota pads unlike when I've put them on my Chevys.
  13. Jan 31, 2025 at 10:05 AM
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    Have you found Steel brake lines for 3rd gen? All I can find are extended lines for lifted trucks.
  14. Jan 31, 2025 at 10:21 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    I am a big EBC fan but there are no parts listed on their website for 3rd gens??
    Edit: OK, I see some brakes listed at those other links but not the first link. Odd. But good to know they seem to have them.
  15. Jan 31, 2025 at 10:59 AM
    bailey bulldog
    bailey bulldog New Member
    I have used Frozen Rotors in the past with excellent results.
  16. Aug 19, 2025 at 12:09 AM
    counterattack
    counterattack New Member
    Did the initial bite become stronger? Most important to me, did the pedal become firmer upon application of the brakes. I think Toyotas have a lot to e desired in terms of brake feel. Ford and Chevy have a very nice a firm brake pedal that is reassuring
  17. Aug 19, 2025 at 6:56 AM
    JerseyGeorge
    JerseyGeorge New Member
    2024 Platinum
    I converted my 2012 4 Runner to all Powerstop. Rotors, Calipers, Pads. I could tell the difference in braking, especially with trailer. Sadly that same option not available for our Tundra. I would go with them in a heart beat.
  18. Aug 19, 2025 at 7:02 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Mine is at the dealer as I type. Decided to replace pads and rotors with OEM as I couldn’t find any rotors that clearly stated they were more durable. Also, nobody I talked to would put brake parts on I supplied. Fresh off shoulder surgery so me fixing it is a no go. Frustrating.
    Frustrating.2 is the dealer telling me it’s the way I drive.
    raylo likes this.
  19. Aug 19, 2025 at 7:08 AM
    David713
    David713 New Member
    No, pretty much same pedal feel as stock. I don't have any high speed braking comparison between stock and Porterfield to compare but that's where I really noticed the difference on my Silverado.
    The disks and calipers seem big enough on the Tundra for most driving. I wonder if there's a master cylinder with a larger piston that would be a direct replacement?
  20. Aug 19, 2025 at 8:56 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Might have been a while since you checked but rock auto is offering a lot of options for the tundra (usually helps to put in a little older model like 2022 or 2023 b/c Rock auto usually doesn't update the newest models for a while). No calipers yet but rotors and pads are there.
    JerseyGeorge[QUOTED] likes this.
  21. Aug 19, 2025 at 9:04 AM
    raylo
    Frederick, MD
    Good luck, I hope it works out. Shoulder surgery sucks for sure, I had a torn subscap muscle repaired once upon a time and that was worse than knee replacement sugery. I had to shovel snow before I was fully healed after we had "snowmageddon" that year. No fun.
    WILLINH and BoulderGT3[QUOTED] like this.
  22. Aug 19, 2025 at 11:52 AM
    BoulderGT3
    Glen
    Thanks
    $642 later with new factory rotors and pads the truck drives perfectly. The shudder in the right front was wild but it's gone now.
  23. Aug 19, 2025 at 2:12 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    How many miles on your truck at the brake service?
  24. Aug 19, 2025 at 2:21 PM
    BoulderGT3
    Glen
    17,000 the first time when they were resurfaced. 30,000 today for replacement of pads and rotors.
    PGW85706[QUOTED] likes this.
  25. Aug 20, 2025 at 9:49 AM
    AND
    AND New Member
    Washington, PNW
    Here it is, just did mine front and rear.
    https://www.powerstop.com/product/power-stop-z36-brake-kit/
  26. Aug 20, 2025 at 10:53 AM
    JerseyGeorge
    2024 Platinum
  27. Aug 20, 2025 at 11:49 AM
    teab
    Ty
    Denver
    Paint your's red and then you'll have powerstop calipers. Powerstops are usually just remanufactured calipers and they paint them red to give them some flare. They seem to rebuild them well, but no improvement over an OEM caliper other than it being red (the powerstops might be an aftermarket rebuilt unit). That's probably why they don't exist yet because there aren't enough core's floating around out there yet for the 3ed gen.
  28. Aug 20, 2025 at 12:02 PM
    JerseyGeorge
    2024 Platinum
    So obviously you are unaware of the stopping power of red paint. That’s the problem with the internet in a nutshell.
    actually, I read reviews about bicycles, fly rods, tools where folks describe attributes I never experienced. It has full flex, stable, good in midrange but the taper not perfect. All these folks describing sh&t I don’t experience. But the power stop brakes on the 4 runner. I did their calipers, pads, rotors. Ang hot damn. I could tell the difference.
    AND likes this.
