General Supercharger Thread
  1. Aug 16, 2025 at 12:46 PM
    nags
    nags New Member
    Sent:monocle:
  2. Aug 16, 2025 at 1:25 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    It's yours, PM me where to send it.
  3. Aug 16, 2025 at 7:08 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    What pulley size was in your kit @nags ?
    Nice to finally see these kits getting installed, had mine in since the previous Friday. Had a fitment issue with the intake box, figured that out(was the sabm/whipple bracket changing the two lid angles coming together). Then I've been having slow starts, truck turns over 2-3 times then fires up. Drove it today and initially had a slow start, then when leaving the hardware store it fired right up.
    Also, I have the morimoto headlights, so we put the IC pump tap on the injector fuse. I swear I heard/obseved the pump running as the resi was bubbling. So unsure why power would be hitting that fuse with no key in..
    Haven't got on her to much since I only had time to correct the intake issue this morning, but prior saw highest of 6.8 psi and dipped into 10.8 a/f on a different little pull where I actually was paying attention.
  4. Aug 16, 2025 at 7:15 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    GX460 can take the longer 2UR GSE IS F oil filter cap. This allows the 5.7 oil filter to be installed on the GX.
  5. Aug 16, 2025 at 8:10 PM
    blenton
    blenton New Member
    What tune are you running? the canned Whipple tune?
  6. Aug 16, 2025 at 8:50 PM
    LILTRD
    LILTRD New Member
    2013 Tundra RCSB
    Yes, canned tune. But, with the walbro pump as I didn't want to drop the tank again. So, I was thinking it may be due to that pumps configuration in the basket.
    HulkSmurf14 likes this.
  7. Aug 16, 2025 at 11:01 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The only issue with using the walbro 450 mod 267 in a non-flex canister is the venturi size. The 267 model fits nicely in there but the venturi can be slower to fill. Reason why they recommend using the flex canister as it has a bigger venturi to keep up either the 450. I have this setup and have not had any issues. Not sure if they still have you make holes in canister but to me that's not a proper setup. Not that's your issue?
  8. Aug 17, 2025 at 9:16 AM
    e30cabrio
    I don't have rebuilt motor filter experience, but this is less metal than I expected.
    Also, is dyno oil darker than synth? This seems really dirty for under 500 miles.
    mustang67408, reywcms and Mdl like this.
  9. Aug 17, 2025 at 11:07 AM
    centex
    centex New Member
    Funny you mention break in oil. I just changed the oil in my blazer and it was way darker than I expected. 40 miles on a fresh build 383 with Driven 10w-30 break in oil. It was dark and dirty but no glitter. Just some mud on the magnet.
  10. Aug 17, 2025 at 11:16 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Lots of assembly lube will turn the oil dark. I wouldn't worry.
  11. Aug 17, 2025 at 11:22 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    This
  12. Aug 17, 2025 at 11:27 AM
    e30cabrio
  13. Aug 17, 2025 at 12:16 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Appreciate this reference. Fingers crossed there will be a few break-in oil changes happening on my end over the next few weeks. Driven 5w-30.
    mustang67408 and centex[QUOTED] like this.
  14. Aug 17, 2025 at 12:26 PM
    centex
    centex New Member
    I did a dozen runs from 2500-5000 in second gear and then 40 miles of spirited driving and changed it for Mobil 1 15w-50 per my engine builder. It’s a different additive package than the regular 5w-30 Mobil 1. Ill do another change in a 100 miles and then let her run.
    mustang67408, e30cabrio and bflooks like this.
  15. Aug 17, 2025 at 12:55 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I've got the XAT recommended. I'm opting in for the additional 250 miles of low load, moderate RPM on break-in oil for a total of 500. Then big boi fueling, exhaust, and Dyno session nearly immediately after. Goal is to be completely done and dialed in by mid-September so I have a few weeks to use it before returning to the office
  16. Aug 17, 2025 at 2:54 PM
    e30cabrio
    I'm on 5-40 Mobil 1, builder didn't give me a next change interval. What do you guys think I should do?
  17. Aug 17, 2025 at 3:14 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I use assembly lube on absolutely everything, then when the top end is together pour a quart of more over everything. Break in oil I'm not super anal about, on my LS I used amsoil I think straight 30W break in oil, on my 2JZ I didn't use anything. Changing the oil sooner rather than later was more important imo. First oil change I did like three drives in. Then next at maybe 500-1000 miles. Then 5000 miles after that assuming the oil is looking clean and happy. I figure assembly lube is extremely important, followed by flushing as much oil through and changing it out just since there's bound to be shit in the engine.
  18. Aug 17, 2025 at 3:21 PM
    e30cabrio
    So 1k on this oil or since the break in was so dark & filter so clear go 5k?
  19. Aug 17, 2025 at 3:49 PM
    snivilous
    SW UT
    I would change the oil in another 1000 miles if it was me. Like the others said, it being dark isn't necessarily bad, but I'd rather keep changing it at premature intervals until it's looking good. That's probably extremely conservative though.
  20. Aug 17, 2025 at 4:00 PM
    e30cabrio
  21. Aug 17, 2025 at 5:46 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I've posted this before, but the oil change intervals seem to be what is key. Mind you, break-in oil is not your normal oil, so mileage will vary. I'll be off Driven at 500 miles (I'll be doing a total of qty 3 Driven oil changes during this time) and into Mobil 1 5w-30 for probably 1500 OCI, then to a traditional 5k mile OCI starting at 5k miles. Oil is cheap, IMO.
    My build will also be fogged prior to start up.
    https://drive.google.com/file/d/1odDExk3-MLRrAlGBnftJH8tIWAkq32cW/view?usp=drivesdk
  22. Aug 18, 2025 at 7:16 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    Okay I've finally installed the Valve body from the group buy and now I'm in the filling process. What is correct process of filling up the oil? I'm switching to dex III and will do 30k drain and fills. From the video from wholesale automatic filling up the trans on a 200 series cruiser it is unclear what the proper process is. I get the final level needs to be checked at around 100*, but how much do I put in there before I start and does it need to be running while filling? What have those who have done this before done?
    Thanks!
    Josh
    Mdl likes this.
  23. Aug 18, 2025 at 7:34 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    https://www.tundras.com/threads/2nd-gen-transmission-drain-and-fill-diy-how-to.137487/#post-3826805
    You'll also want to overfill by a quart
  24. Aug 18, 2025 at 7:35 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Snagged a flex fuel basket setup etc to swap to pretty cheap on eBay figured might as well since @snivilous is throwing in a fresh fuel pump and lines etc in.
  25. Aug 18, 2025 at 7:55 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Are you doubling up some 450s in it?
    e30cabrio likes this.
  26. Aug 18, 2025 at 7:58 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    Yeah, I did not measure how much came out, drained it into my 20 gallon cart. Ugh. Guess I can start with 4 quarts and keep filling while it's running until it starts coming out the fill plug from what I seen in videos from IPT and wholesale auto. Then do the shifting through gears and bring up to temp and check level. If nothing comes out add 1/2 a quart at a time, spit rinse repeat. Seem logical?
  27. Aug 18, 2025 at 8:13 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Was planning on one but I'll leave it to @snivilous if we run 2. I have two there lol More fuel than needed is not a bad thing.
  28. Aug 18, 2025 at 9:10 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Can use 9 qts with PML pan or 6qts with stock with VB swap. Do you have a cooler for the trans? I'd at leat would want to get as much WS out as possible. Fill it with about 5qts just before it starts dripping out of fill. Disconnect the return line into a bucket, start it up shift gears and shutoff when it starts sputtering. Fill with 3 more qts and start it up stop when clean dex is seen coming out then re-attach line to t-stat. You can fill until it comes out of check port. As the oil will expand when heated and recheck amount needed. You may go through 12-15qts to soft-flush out the old stuff. Drive a bit and drain pan to get as much WS out.
    I filled mine with Idemitsu TLS IV. It has the same viscosity as DEX 3 but with an additive package like WS. But my Trans is on its way out...been too hard on it and had issues before.
  29. Aug 18, 2025 at 10:06 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    Welp I added about 6 or so quarts to the stock pan and that was enough to get the proper level at 106*. Since I did not clear out the cooler lines and I had pinned it open I'm going to do drain and fills until the fluid is clean. Drove the truck and it is not much different, it does seem a tad firmer now which is good. Stock fluid at 70k was nasty dark.
    HulkSmurf14, Mdl[QUOTED] and reywcms like this.
  30. Aug 18, 2025 at 10:52 AM
    nags
    nags New Member
    I'm not sure. It's a friends truck so I don't have anything in front of me. It's currently running like poop and I'm pretty sure the installer did not install the Whipple provided tune properly. He did email it to me and I'm going to (re)install it and see how it works and grab some more logs for Sniv before finally having Sniv do the full tuning for us.
